04-09-2012, 12:56 PM
#811 |
dirt relocation service
Oddometer: 75
Me too...
Funny, I was just working on this problem yesterday. I had posted to the XR forum and got no responses so I'll repost here....
OK, so the question is: If you can run both outputs together on a RS stator, you can do the same with a BD stator right? ![]() I don't think the stator wiring or high beam indicator are quite right yet but here's what I've got planned more or less (not including the CDI circuit and kill switch): ![]() K&S 12-0055 switch cluster, RS 250W reg/rec, BD 2X125W stator rewind, X2 dual sport Halogen headlight (70W?), DRC rear LED flashers D45-58-617, DRC LED license light D45-39-410, DRC LED inner taillight kit D45-DTL-9110 and hopefully soon HDB handguards with mirrors and blinkers..... I'm thinking 14AWG for the main power and grounds and 16AWG for the binkers, horn, taillights and others that split off of them should be good? Grip warmers, Gerbings and anything else will be on their own circuit from the fusebox..... Erndog screwed with this post 04-09-2012 at 01:03 PM |
04-09-2012, 02:01 PM
#812 | |
Oddometer: 12
Items running off the battery: Headlight, Turn Signals, Rear Running Light, Rear Brake Light, and TrailTech. The handlebar switch has an 'off' position for the headlight; the turn signals don't draw power unless they're left on; the brake light is only on with the brake engaged (should -always- function, even with 'power' off); and the Trail Tech draws negligible power. The rear running light runs off of the headlight circuit (wiring diagram shows it wired to low - now that I think about it, I need to edit my diagram so that the high-beam circuit powers it as well, with a diode in-line to keep the low and high beam circuits isolated). So, adding a key switch wouldn't gain me much, other than maybe shutting my signals or headlight off should I forget them, and then as you mention, I may have to add a relay (though if I did add one, I would merely run the headlight high/low circuit through it, not the main power to the HID ballast - that's fine being always connected). This is the same reg/rect. I used (I purchased it from another store but can't seem to remember where exactly): http://www.ebay.com/itm/Norton-Trium...#ht_500wt_1180 |
04-09-2012, 04:47 PM
#813 |
donkey
Oddometer: 74
Hi All,
I'm having a problem converting my system to DC. I wound my stock stator to a single wind of 200W and was running AC off the stock honda Reg with no problems. Now I'm trying to run DC with a SPI regulator (similar to Trail Tech/BD) and the issue is even my brake light dims as soon as I use something like blinkers. I'm running two 22,000 uF capacitors. Any advice? Will caps work or must I use a battery?
2012 KTM 250XC 2002 XR650R Plated 1981 XR80 |
04-09-2012, 08:40 PM
#814 | |
Oddometer: 12
Here it is:
04-09-2012, 10:04 PM
#815 | |
Torque Junkie
Oddometer: 3,565
Is that a BD HL handlebar switch? If so you might want to run the HL on a relay, I've replaced one (BD) for a guy that became a little deformed inside due to heat caused by the HL draw. I don't know if it's an issue with the HID, their inrush current can runs between 5.5 ~ 6A depending on the bulb brand and color temp but it drops down to about 3.5A fairly quick. They (HID) claim 35W (3A) but that's a little optimistic on their part, more like 42W. |
04-09-2012, 10:37 PM
#816 | |
Oddometer: 12
Technically it's the K&S 12-0055CN, but as far as I can tell, that's the switchgear BD uses. With the HID, the ballast/light itself draws power through independent power/ground leads (the two lead going to the top of the High/Low HID in my wiring diagram). The high/low output from the handlebar switch is merely used as a signal to trigger the HID, and then to trigger the activation of the high/low mechanism. So there will be negligible current draw through the handlebar switch itself. |
04-10-2012, 12:27 AM
#817 | |
Torque Junkie
Oddometer: 3,565
04-10-2012, 12:44 AM
#818 | |
Torque Junkie
Oddometer: 3,565
04-10-2012, 01:11 AM
#819 | |
Torque Junkie
Oddometer: 3,565
04-10-2012, 01:53 AM
#820 |
Just Over That Hill
Oddometer: 137
Curious why anyone would want to use capacitors vs a small cheap (10-15$) SLA batt or equivalent? Is it just an issue of size/weight? Seems like the sudden charge/discharge properties of caps makes them less than ideal for DS purposes. Those tiny SLA batteries seem to be extremely reliable, lasting easily for two or more years of riding, and help protect the electronics.
Gildus screwed with this post 04-10-2012 at 02:34 AM |
04-10-2012, 02:29 AM
#821 | |
Just Over That Hill
Oddometer: 137
04-10-2012, 06:04 AM
#822 | |
donkey
Oddometer: 74
I'm running a trail tech X2, led brake light, standard bulb blinkers, fan, heated grips, gps charger Quick help is appreciated as the bike ships tomorrow to Phoenix so I can ride the Continental Divide Trail back to Calgary. I may just ship down a battery, as I think it will be the most reliable option. My next question would be what size of fuse for the battery? 15-20A?
04-10-2012, 06:31 AM
#823 |
Big Red Bird
Oddometer: 1,657
Your Cap voltage rating is too low. Try 50 volt. Your are right at the working voltage of the cap at 16 volt. The dielectric may be failing & then it may get nasty. Small voltage spikes from the stator poke holes in the dielectric (could try your caps in series, check voltage to see if it divides evenly)
I have a 50 Volt Cap the size of a beer can, works fine.
2 XR650r(s) 2001 & 2002 Plated GL18HPM9 Titanium (Gold Wing) CRF230F for the tight shit! Baja Mexico Trail Ride Report Big Bend Ranch Drive and Ride Report |
04-10-2012, 09:02 AM
#824 | ||
Torque Junkie
Oddometer: 3,565
04-10-2012, 09:44 AM
#825 | |
Torque Junkie
Oddometer: 3,565
You going to pass right by (40mi) here on the CDT, weather has been really nice, 70s in the day and 50s at night. Not sure how soon you're headed up the CDT but it's a little early for southern Colorado, don't be surprised if you're detoured cause of snow just north of Platorio in the Summitville area, I didn't know it was even passable this time of year. I'd have an alt plan for that area just in case, east through Montevista is probably the best bet in case you get turned around. |
