04-12-2012, 05:21 AM
#841 |
Oddometer: 12
Really? Awesome! Thanks for the tip, I was kind of wondering if such a thermo switch existed (I can't imagine the SPAL fan draws more than an amp or so...).
04-12-2012, 05:27 AM
#842 |
Oddometer: 12
Then again... I want the fan to run off of a switched power source so that it shuts off with the bike. Which either means running the fan power through the key switch as well (which is already supplying power to the front and rear running lights, turn signals, plate light, horn, and headlight - or at least whatever minimal current the HID switching circuit draws), or using a relay. Wish I could find a current rating on that key switch. I think I'm going to reach out to K&S and see if they'll give me a spec. That would certainly simplify my wiring, but I don't want to fry an ignition switch.
If I do have to use a relay, I guess I should really just use it for all of the switched power, instead of just the fan (and run the fan as you say directly through the thermo switch). That way I could wire other accessories later to the +12V Switched and not worry about current draw. |
04-12-2012, 06:47 AM
#843 |
Oddometer: 503
Ride Freak is right, I've used the same switch on my ktm fan on the XR. 10,000km later it still works great. don't waste your time on a relay and manual switch...
Trans-Canol 2014ish |
04-12-2012, 07:11 AM
#844 |
Oddometer: 12
http://www.northernautoparts.com/Pro...ntoryId=666640
Is this the one you guys used? Do you have it on switched power or always-on? |
04-12-2012, 07:30 AM
#845 | |
Oddometer: 503
04-12-2012, 09:43 AM
#846 | |
Who
Oddometer: 140
Gotta ride something! 02' XR650R slightly personalized
04-12-2012, 11:45 AM
#847 |
Just Over That Hill
Oddometer: 137
04-12-2012, 03:18 PM
#848 | |
Torque Junkie
Oddometer: 3,540
I have mine wired in so it's enabled by the key and is activated by the temp, that's the only advantage I see to running the fan on a relay. When I come to a stop and shut off the bike the fan turns off, wiring the sensor to a 12V all the time would keep it running till the coolant at the sensor dropped below the threshold or the battery went dead, since flow stops when the motor is shutdown that might be a little while. The system works nice, I don't worry about cooling the bike, it's totally automatic I'd be a little concerned running an aftermarket CDI out here, too remote. The OEM is pretty reliable and if you want performance AND OEM reliability, you can always use the 86 XR4 CDI unit. RideFreak screwed with this post 04-12-2012 at 03:40 PM |
04-15-2012, 09:58 AM
#849 | |
Almost Lifelike
Oddometer: 1,151
Holy smokes, nice schematic!
XR650R Plated Supermoto XR628R Plated and highly modified CR500R Still rips after all these beers RZ350L Kenny Roberts Special "If it's hard to do, you're probably doing it wrong." |
04-19-2012, 08:15 PM
#850 |
Broken Filter
Oddometer: 505
Stator Wiring Grommet
I see that the wiring grommet on my stator is molded onto the wiring. If you order a RS or BD or other stator, does it come with a molded grommet? How about if you rewind your own? I am rewinding my own for dual outputs, and still figuring what to do for the grommet.
"Get the hell out of my way." - John Galt '78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
04-20-2012, 09:47 PM
#851 |
dirt relocation service
Oddometer: 75
Kevlar, I just had a small, maybe incorrect, thought. But here it is: Isn't the kill switch circuit AC and needs to be isolated (floating ground) from the DC circuit that appears to use the frame as ground? Or is it the other way around, floating DC ground?
Red Neck First Aid Kit- Superglue and Duct tape are great, if you need to step it up to the baling wire it's time to seek professional healthcare assistance.... |
04-20-2012, 11:12 PM
#852 | |
Just Over That Hill
Oddometer: 137
. Depends on how you've wired your bike. Many of us float the DC ground (per Ride Freak's model) and don't connect it to the frame at all (with the exception of the metal housing of the RS R/R (has it's own shielding circuitry for this). The ignition AC circuit and kill switch are direct frame ground. XRider suggests a different model for DC grounding and his way works too, just depends on your wiring philosophy.
04-21-2012, 02:18 PM
#853 |
Keep her pinned!
Oddometer: 601
Question? What would cause the horn/LED sigs to only activate when the rpm is up just a tad from idle and not at idle? Weak battery or bad rectifier?
If you think you're free, there's no chance of escape! 2008 R1200GSA |
04-23-2012, 09:35 AM
#854 |
Broken Filter
Oddometer: 505
Anybody? I'm considering trying to plug where the grommet was with high temp RTV.
04-23-2012, 12:03 PM
#855 | |
Oddometer: 12
My only question would be - doesn't the spark plug ground to the case? How does the ignition system work if it's not grounded to the engine/frame? Is the stator itself grounded? |
