Old 03-11-2013, 06:14 PM   #1021
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,244
Originally Posted by babuja View Post
No voltage regulator except the rect/reg device in the image. I believe it does some kind of voltage regulation.
Yep, GPS (Garmin 60csx) accept AC or DC power 12V.
No battery...Ok, I'll try to use multimeter and see if the voltage have large flutuation. Tnks
That's honda's non-us dc system, it actually works very well. Europe has no requirment to have the lights stay on after the bike stalls like the US (I think AUS is the same) so they use that small DC rectifier/cap unit instead of a battery. The same unit is used on the street legal XR400s. That sytem is regulated for over voltage with Honda's standard A/C regulator (shown in wiring diagram above) wired into system prior to the DC rectification. That small black box converts (rectifies) the AC to DC and the cap cleans up the power during low output. Not sure of the system's output but I'd think you'd be ok to run some lower power stuff off it along with the bike's stock lighting system.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-11-2013, 08:01 PM   #1022
jm-2008
jm-2008's Avatar
Oddometer: 513
[QUOTE=RideFreak;20923407]That's honda's non-us dc system, it actually works very well. Europe has no requirment to have the lights stay on after the bike stalls like the US (I think AUS is the same) so they use that small DC rectifier/cap unit instead of a battery. The same unit is used on the street legal XR400s. That sytem is regulated for over voltage with Honda's standard A/C regulator (shown in wiring diagram above) wired into system prior to the DC rectification. That small black box converts (rectifies) the AC to DC and the cap cleans up the power during low output. Not sure of the system's output but I'd think you'd be ok to run some lower power stuff off it along with the bike's stock lighting system
RF
Certain the indicator flasher can is supplied from the same source on the Oz versions.
If it can supply 2 x 21W lamps per side (42W approx) should be a handy source for other items.
Use it to supply my TT Vapour and have had no issues.
Would be inclined to have a look at the output on a CRO before I'd want to run my GPS off it (or add a big CAP to help smooth any transients).
Maybe some of the other lads here in Oz have done so already.
JM-2008
jm-2008 is offline   Reply With Quote
Old 03-11-2013, 08:07 PM   #1023
crypto666
Oddometer: 1,383
Originally Posted by Jayrod1318 View Post
Incandescent front turns and led rear turn signals.
By my calculations this should work just fine on my all AC system. I broke the incandescent rears off and I'm trying to shave some watts using the stock stator. My 55 watt headlight dims a lot with the use of the turn signals. I also have the wheeling cycle supply led inner brake tail light.
Comments suggestions?
Is it dimming when idle?
And what is the rpm of said stator's rated output?
crypto666 is offline   Reply With Quote
Old 03-11-2013, 10:18 PM   #1024
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
It is the stock stator, I have no idea.
I know it works now, it just dims the headlight alot. by dropping one of the incandescent bulbs it should help a bit.
I think I don't need any LED flashers, or resistors because I also have a regular 21 watt bulb thats pulling a enough current to get the flasher to work?
Jayrod1318 is offline   Reply With Quote
Old 03-11-2013, 11:40 PM   #1025
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
you could run a small batt of that reg/ then run your gps fan from there it will give much smoother pwr .....
Sean-0 is offline   Reply With Quote
Old 03-12-2013, 12:35 AM   #1026
babuja
babuja's Avatar
Oddometer: 353
I'll check this ;)
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 03-12-2013, 07:05 AM   #1027
crypto666
Oddometer: 1,383
RF
JM-2008
Like was said earlier, a battery does a better job of conditioning the power.
With a 1.1Ah LiFe battery and a capacitor about the size of the one shown in earlier I still can detect voltage spikes over 16v, with no load on the system. However, I run a secondary switching power supply for gps/phones charging and stuff. With the HID lit the dc system holds a steady 13-13.5V.
Old 03-12-2013, 08:48 AM   #1028
babuja
babuja's Avatar
Oddometer: 353
And do you know of any small battery like that?
Cheers guys
Babuja
________
KTM 950 ADV
babuja screwed with this post 03-12-2013 at 10:14 AM
Old 03-12-2013, 02:54 PM   #1029
crypto666
Oddometer: 1,383
Yeh, the battery in the pic is about the size of mine, but mine is only 4 cell (LiFe 18650 cells 1.1Ah @ 3.3v each). I split it into two packs of two cells each to make it easier to tuck away.
I think you can get away with a NiCd as well. And I think the one in the pic is a 6 cell NiCd.
There are also little tiny Pb batteries too.
Old 03-12-2013, 09:04 PM   #1030
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
I think I don't need any LED flashers, or resistors because I also have a regular 23 watt bulb that is pulling enough current to get the flasher to work?
Ok, so for reference the cheapo Tusk Brand LED turn signals from RMATV will work on AC current. They are incredibly bright and I shaved a good 22 watts off of my operating usage when using the signals. Mind you I still have regular ol incandescent signals on the front. One of the 23 watt bulbs is enough to operate the flasher.
I searched around a lot and couldn't really find conclusive evidence that this would work, but it does.
Now I'm wondering if I can find a LED flasher that will Run on AC? to go full LED turn signals front and rear. that would be bitchin.....
Old 03-12-2013, 10:42 PM   #1031
sintax
Oddometer: 495
The one in the pic is the default BD battery. It comes as 10 x AA nicads (700 mah)
I ordered up one from a company online that should be 10 x AA nicad (1200 mah)
If it passes the test, i'll post up where i got it.
sintax is offline   Reply With Quote
Old 03-13-2013, 07:49 AM   #1032
crypto666
Oddometer: 1,383
Cool, yeh I bought a NiCd also, but it was so freakin huge (c cells) and heavy I never used it except for testing.
And yeh, 10 NiCd cells would be 12v, not 6 (Pb).
Old 03-13-2013, 07:57 AM   #1033
crypto666
Oddometer: 1,383
All LED lights will work on AC, and they will also act as a half wave rectifier at the same time.
SO if it is bright on AC, it should be really bright with full-wave rectified DC.
I used the led flasher sold by http://www.radiantz.com/ and it has worked well. Even with unbuffered dc they work well. It has been abused with over voltage and ac voltage and still works after 5+ years.
Old 03-13-2013, 02:55 PM   #1034
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
This guy here?
http://www.radiantz.com/index1.html?c15.html&1
Old 03-13-2013, 03:26 PM   #1035
KYLEISCOOL
Who
KYLEISCOOL's Avatar
Oddometer: 144
Sorry to chime in on this but I called baja designs and for the squadron he said I HAVE to convert to DC for it to work. Is he bs and just wants me to purchase more stuff from them?
Gotta ride something! 02' XR650R slightly personalized
KYLEISCOOL is offline   Reply With Quote
Times are GMT -7.   It's 12:59 AM.
