01-10-2009, 04:12 AM
#1 |
NorthWest Adventure Rider
Oddometer: 1,685
Better Electrical Connections
If you are installing wiring on your bike consider these connectors. They are made for RC aircraft and are extremely reliable, easy to connect and disconnect, can take high loads and they are very solid. WAY better than the cheap automotive style connectors that you buy at napa, shucks, ect. I just installed my 200W Ricky Stator and used these connectors to replace the ones that came on the stator assy, wires going to the lights, switches, ect ect. When you are in the middle of know where it pays to have solid electrical connections.
![]() These are the connectors, available at any Hobby Shop. ![]() Here they are out of the bag. They are solder on connections. ![]() Here is a 14 guage wire soldered onto the male connector. ![]() Add the heat shrink tubing to prevent shorts. ![]() Connect the two halves and your done. Nice solid connection that you won't have to worry about. ![]() Here's a shot of my Ricky Stator harness with the new connectors installed on my XR650R. Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE Hodakaguy screwed with this post 01-11-2009 at 05:05 AM |
01-10-2009, 05:09 AM
#2 |
Oddometer: 1,016
Those look pretty nice! I also like posi-lock connectors. Especially the posi-tap ones. So easy to tap into a wire.
late-braker Guaranteed not to cause eternal torment in the place where the guy with the horns & pointed stick conducts his business...Frank Zappa |
01-10-2009, 05:49 AM
#3 | |
Oddometer: 21,547
01-10-2009, 05:56 AM
#4 | |
Oddometer: 1,685
Thanks Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE |
01-10-2009, 10:40 AM
#5 |
Oddometer: 1,852
they look like a joy to work with, and the finished connection looks very professional too. but i wouldn't think that it would pass too much in the way of amps thru it. does the manf. state what loads it will handle?
01-10-2009, 03:19 PM
#6 | |
Oddometer: 1,685
Hodakaguy
01-10-2009, 03:40 PM
#7 |
Red Clay Halo
Oddometer: 11,170
Nice find, I like those much more than crap automotive connections.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
01-11-2009, 06:31 AM
#8 |
n00b and improved!
Oddometer: 92
Those are good looking connectors, I like how compact they are.
I am in the middle of redoing a DSK install on my BRP, I wanted to stay with the standard bullet style connectors, found out that Aerostich sells a kit for $17 that has these in a open barrel style crimp, even comes with the little clear plastic covers to make everything tiddy. http://www.aerostich.com/catalog/US/...t-p-20274.html Another type of connector I have used a bunch on cars is from these folks: http://www.weatherpack.com/ These are the same as the fuel injection connections on all late model cars, and end up being pretty trick. I have used them on a complete car rewire, and they are a bit more work, and maybe a bit bulky for bike applications, but you end up with a water tight, factory quality connection. Dane
Buy it, use it, break it, fix it We learn nothing from the things we do right the first time. |
01-11-2009, 01:24 PM
#9 |
Traveller
Oddometer: 6,593
Any connection will last longer if you put a little grease on it to keep air/moisture away from the connection area.
01-11-2009, 06:03 PM
#10 | |
Oddometer: 5,072
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me? Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1 |
01-12-2009, 08:39 AM
#11 |
zipper suited sun god
Oddometer: 1,348
Very cool stuff. I'm always interested in finding out about better connectors.
I've heard from experts (whatever that means) in the aviation world that soldering can be a problem due to solder wicking up the wire under the insulation, making the end of the wire into a brittle stick that can break. I just don't like soldering - it's a pain, and I've had good luck with my connections so I haven't been motivated to do it yet. When I wired up the heated grips for my v-strom, I used generous amounts of shrink tubing and careful routing and I feel that I have a reliable set up, except I used the frame for a ground and I hear that's a no-no with Al frames. The Autozone where I live has some better crimp connectors with integrated shrink tubing. I've found that if I use channel locks to do the crimp instead of a crimping tool, I don't tear the connector's covering and I get a more controlled crimp. Maybe I need to find a better crimping tool. With Posilocs, I squirt silicone inside to seal them up. I used plain old automotive connectors and posilocs when I buried the wire for my dog's invisible fence, and it still worked fine even after 4 years, winter, frost heaving etc. buried only 3" deep under the sod. My 20 year old utility trailer is still working fine, too, even with the most hacked together wiring - blue crimp connectors and electrical tape. |
01-12-2009, 12:21 PM
#12 |
Barley Adventurer
Oddometer: 943
I love Anderson powerpoles http://www.andersonpower.com/product...onnectors.html
They stay together, you can gang them into as many conductors as you need, and they are genderless. |
01-12-2009, 01:01 PM
#13 |
Gutless wonder
Oddometer: 4,705
If you want another alternative connector (again from the RC community) try DEANS Ultra plugs.
![]() The industry standard in high performance connectors. Rated number one by R/C Car Action, The Ultra Plug actually has less resistance, including the solder joints, than an equivalent length piece of 12 gauge wire. We use them on LiPo batteries to the Electronic Speed Controlers/Battery Elimination Circuits (ESC/BEC). It's amazing how many AMP's these guys can handle, also how well they stay connected. True Deans, can be a bit expensive. So I order them from China (called T-Connectors) 10 pair T Connectors $6.95 HobbyKing/HobbyCity It takes a bit of skill/work to solder up, but well worth it
09-28-2010, 11:11 AM
#14 |
ADV Demo Rider
Oddometer: 1,228
Yea my Dad runs 6.5KW through them
But he's not normal in the RC world Sermos are also pretty good and relatively cheap and easy to solder
Yes, I'd love to try What ever happens to be in the stable at the current time. H-ADV in fabrication
09-29-2010, 12:01 PM
#15 | |
Oddometer: 102
