Old 11-07-2011, 11:01 AM   #1636
Spud Rider
Spud Rider's Avatar
Oddometer: 3,763
Originally Posted by SpencerCompton View Post
I am going to start some pre-winter maintenance on the TW and need some advice. I will be pulling the carb and cleaning that. The carb rebuild kits seem to be junk from what I've gathered. Does anyone have a list of part numbers on the gasket's I will need? OEM or aftermarket is fine.
Also, has anybody here mounted givi(e21's specifically) to the cycle rack pannier kit? I have the givi lug kit and plan on making a metal bracket that mounts to the pannier rack when that arrives. Any insight on that too?
Do you own a later model bike with the Teikei, MV28, CV carburetor? If so, you probably won't need any gaskets.
Spud
Old 11-07-2011, 12:46 PM   #1637
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,332
Spud
It's an 06 so I doubt any of them will need to replace any of them. I've put nearly 5k miles on it in the last year and a half most of them being single/double track so I'm not sure what it will look like when I open it up.
-Spencer
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
DingDangKid is offline   Reply With Quote
Old 11-07-2011, 02:35 PM   #1638
frog13
frog13's Avatar
Oddometer: 1,315
The bikebandit part number for the bowl gasket is #1212790.....tried to find a Yamaha #...crazy computer day!.
frog13 is offline   Reply With Quote
Old 11-07-2011, 02:53 PM   #1639
Spud Rider
Spud Rider's Avatar
Oddometer: 3,763
-Spencer
If you haven't allowed fuel to sit in the float bowl for extended periods of time, your carburetor will probably look as clean as a whistle. Also, if you aren't having any fuel related problems, you probably won't need to replace any of the carburetor parts.
Spud
Old 11-07-2011, 03:37 PM   #1640
DingDangKid
El Lechero
Oddometer: 2,332
Spud
The only problem I've had is what I believe to be a dirty low speed yet. In order to get a proper start I need to leave the choke on for 15-30 seconds. After I ride the bike for a minute or two it's back to normal.
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
Old 11-07-2011, 06:19 PM   #1641
Spud Rider
Spud Rider's Avatar
Oddometer: 3,763
The TW200/XT225 engine is notoriously cold-blooded. If the engine is cold, even in the summertime, I usually need to ride the bike with the fuel enrichener slightly engaged for the first one or two miles. However, after the engine warms up a bit, it's happy, and so am I. If you don't need to do this, your carburetor is probably jetted too rich.
Spud
Old 11-07-2011, 10:49 PM   #1642
wayno
wayno's Avatar
Oddometer: 6,647
Spud
Seems mine always needs at least a little choke when starting up no matter the temp
Wayne
RIDE SAFE
"Never wrestle with a pig. You just get dirty, and the pig likes it. George Bernard Shaw
wayno is offline   Reply With Quote
Old 11-07-2011, 11:00 PM   #1643
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,992
Wayne
Mine was the same way.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 11-08-2011, 10:06 AM   #1644
bbagwell
Oddometer: 94
Mine is the same way as well. She is cold blooded!
bbagwell is offline   Reply With Quote
Old 11-08-2011, 11:07 AM   #1645
sKatZ
sKatZ's Avatar
Oddometer: 28
That's weird. My Tdub is a boy!
'03 TW200 QuasiMoto
sKatZ is offline   Reply With Quote
Old 11-08-2011, 12:23 PM   #1646
Rhode trip
guided by voices
Rhode trip's Avatar
Oddometer: 871
Pachaug Turtle Brigade: 11/5/2011
"Take the Puppy to the Beach..." A dirt route across southern New England
"...I Hear Banjos..." The Smokey Mtn 500
http://www.LapelPinPlanet.com
Rhode trip is online now   Reply With Quote
Old 11-08-2011, 02:54 PM   #1647
NewEnglander
NewEnglander's Avatar
Oddometer: 273
Ha Ha!
Now thats funny! looks like alot of fun too.
Originally Posted by Rhode trip View Post
If youre gonna be dumb ya gotta be tough.
[COLOR=Red]2008 BMW R1200 GS Adventure
NewEnglander is offline   Reply With Quote
Old 11-08-2011, 05:28 PM   #1648
frog13
frog13's Avatar
Oddometer: 1,315
My kinda folk!
Old 11-08-2011, 06:45 PM   #1649
turbodieseli4i6
turbodieseli4i6's Avatar
Oddometer: 448
Spud
I would bet it is jetted about right, These little bikes are lean from the factory.
turbodieseli4i6 is offline   Reply With Quote
Old 11-08-2011, 07:56 PM   #1650
wayno
wayno's Avatar
Oddometer: 6,647
Just fat enough not to blubber oops forgot this isn't the Harley thread
RIDE SAFE
Times are GMT -7.   It's 01:44 AM.
