Old 11-24-2012, 04:39 AM   #3016
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,546
Yanked the silencer/spark arrester out a while back and it sounds damn nice. The panniers make it a little noisy at a stop but when I'm moving its loud enough to be heard.
2006 Tdub
2006 Wee
DingDangKid is online now   Reply With Quote
Old 11-28-2012, 08:21 AM   #3017
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,687
Y'all put your T-dub's to sleep for the winter?
Need more big wheeled goodness...
Falcon86 is offline   Reply With Quote
Old 11-28-2012, 05:23 PM   #3018
frog13
frog13's Avatar
Oddometer: 1,342
If the road crew will stop putting salt down every time we get .5" of snow....no,I keep the TW going.
frog13 is offline   Reply With Quote
Old 11-28-2012, 07:54 PM   #3019
frog13
frog13's Avatar
Oddometer: 1,342
TW 200 counter shaft
The shaft has oil running through it to feed the outer shaft bearing(I believe that is correct).....was it designed that way because that is a superior set-up for the counter shaft(having the outer bearing) or was it the thing to do back then when the bike was designed(1980's)?.
Old 11-28-2012, 09:12 PM   #3020
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
The shaft is supported on the outboard end due to its extra length. The Tw has a longer output shaft than almost any other bike in order to clear the rear tire. At any rate loo long to go unsupported on the outboard end. Hardly antiquated. Proper engineering for the task at hand.
Lizrdbrth screwed with this post 11-29-2012 at 10:45 AM
Lizrdbrth is offline   Reply With Quote
Old 11-30-2012, 05:28 PM   #3021
frog13
frog13's Avatar
Oddometer: 1,342
As usual, a concise and clear explanation from sir Lizard!....Thanks!.
Old 12-02-2012, 04:00 AM   #3022
carlclaflin
Oddometer: 249
Originally Posted by frog13 View Post
Good info O.W.T.....I'm working OT as fast as I can get it!.
try checking out http://www.procycle.us/bikepages/xt225.html. not sure what the difference is between the tw200 and the xt225. it's worth a try to check it and maybe shot them an email. customer service is pretty fast to respond to emails.
carlclaflin is offline   Reply With Quote
Old 12-02-2012, 09:32 AM   #3023
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
The difference is in the kicker lever itself. The gears, springs , shaft etc. are the same, but the lever may interfere with the footpegs or frame tubes.
Lizrdbrth screwed with this post 12-02-2012 at 12:26 PM
Old 12-02-2012, 04:30 PM   #3024
Chillis
Iron toocus
Chillis's Avatar
Oddometer: 3,934
Has anyone done 2 up on the TW? Could she handle a second pax out tooling in the dirt?
Originally Posted by Skowinski View Post
Speaking of dumps, that coffee is working for sure, gotta scurry and perch on the thundermug...
Chillis is offline   Reply With Quote
Old 12-02-2012, 04:45 PM   #3025
xaman
Oddometer: 541
If you can fit two up on the seat, the TW will carry you
xaman is offline   Reply With Quote
Old 12-02-2012, 04:50 PM   #3026
AtlasExp
beer me
AtlasExp's Avatar
Oddometer: 437
No problem!
Dual Sport Luggage Racks for: DRZ-S, SM and E and KLR650 and DR650: http://www.moto-racks.com/ Find me on Instagram " ahtoxa007 "
AtlasExp is offline   Reply With Quote
Old 12-02-2012, 05:43 PM   #3027
frog13
frog13's Avatar
Oddometer: 1,342
Has anyone used the mirrors sold at Procycle?....who are they made by?....are they "longer" than OEM to see around your shoulder(s)?.
Old 12-02-2012, 06:02 PM   #3028
RebelYell
Oddometer: 498
one of these days Imight pick one of these up used as my bw 200 isnt street legal
RebelYell is offline   Reply With Quote
Old 12-03-2012, 02:35 PM   #3029
LarryW
Oddometer: 2
New To Riding
Hello all. New to riding dirt bikes here. I'm not really into it for the thrill. Just need to get from point A to point B so I can explore the deserts and mountains. Been doing that with a full size Blazer for over a decade but now the cost of fuel has become prohibitive. I have some fellow exploring friends who do it on dual sports and other types of bikes. I've decided on the TW200 as my choice of two wheeled vehicles. So here I am to learn all I can from you guys. Hope you're OK with that.
LarryW is offline   Reply With Quote
Old 12-03-2012, 02:50 PM   #3030
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,102
Don't get an '87 if you can help it. Click here for the TW200 forum to dive right in.
  • Cycleracks
  • Jimbo Shield
  • Lizard Cooler
  • Ricochet/Moose or TCI skidplate
  • Jets and shims (unless always at high altitude)
  • Shinko 244 front tire
  • Bigger pegs (read up on this)
  • Kickstart kit (if 2001 or newer)
  • Base Gasket replacement (if 2005-2008ish)
  • ATV rear tire (if preparing for war)
  • TTR225 stainless header (looks and longevity)
  • FMF Powercore 4 or DG O-series (looks and noise)
  • Tool tube
  • Clarke Tank
  • Replace most engine fasteners (and float bowl screws) with SS allen heads
  • JIS screwdrivers for carb work
  • Stock chain is pretty bad, get an o-ring one
  • Drill airbox
  • Webcam
  • Electrical stuffs (LED's, charging ports, shorter turn signals, etc.)
  • Walmart seat pad
  • Barkbusters
  • Stebel Horn(s)
  • Happy Trail hard luggage (expensive and counterproductive offroad)
  • Renthal bars/risers
  • Rear shock swap (Virago, Banshee, Blaster)
I think that's most of the things you might possibly ever want to do to the bike, but not many are necessary at all. Make a skidplate one of the first things you buy if you're offroading over branches or rocks.
Before any of that, get yourself educated on riding (MSF course works wonders) and purchase some decent riding gear for your style soon afterwards.
Welcome.
Some things shouldn't be left like you found them.
assquatch20 screwed with this post 12-03-2012 at 02:57 PM
assquatch20 is offline   Reply With Quote
Times are GMT -7.   It's 04:42 AM.
