Old 02-17-2013, 07:30 PM   #3181
frog13
frog13's Avatar
Oddometer: 1,315
Originally Posted by NJ-Brett View Post
Well, the tires do not hold air in, the tubes do.
The pressure is critical, low pressure works great in the dirt, i think I ran 7 psi or something like that, and it was fantastic in the dirt, sloppy on the street.
I also found the stock front tire to be very poor at everything and a real dual sport tire made things much better for both street and dirt.
Tire pressure used as a figure of speech....no doubt the tube has the actual air pressure... sounds kinda funny asking..."whats your tube pressure".
frog13 is offline   Reply With Quote
Old 02-17-2013, 07:35 PM   #3182
NJ-Brett
Brett
Oddometer: 6,394
I ran the Shinko tire that looks like the Kenda that looks like a trail wing, and it was a lot better at everything.
The stock tire is noisy and vibe's on the street, and does not have deep enough nobs in the dirt.
Originally Posted by bbagwell View Post
The stock front tire sucks. There is a lot of options out there. I run a Pirelli MT21 on the front of mine, it works well on pavement and in the dirt.
NJ-Brett is offline   Reply With Quote
Old 02-18-2013, 10:59 AM   #3183
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
http://tw200forum.com/index.php?/top...-tire-choices/
Lizrdbrth is offline   Reply With Quote
Old 02-19-2013, 10:56 AM   #3184
Kwizard
Conservative
Kwizard's Avatar
Oddometer: 20
Earls Leading Link front suspension.
Howdy Y'all,
Has anyone ever seen, used, or installed an Earls leading link front suspension on a TW200? I have several of these from my Sachs, and DKWs, and am strongly considering installing one on mine. It will of course need some mods to either the triple tree; or the Earls; or both. The advantages are: easy maintenance, strong and stable front end, huge variety of shock options, front rise with braking(great for knarly down hills) instead of diving, increased travel, adjustable trail. The disadvantage is difficult disc brake install.
I'm interested in all comments; pro, and con.
"I'll be your Huckleberry"
Kwizard is offline   Reply With Quote
Old 02-19-2013, 11:29 AM   #3185
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,097
Originally Posted by Kwizard View Post
Howdy Y'all,
I think you'll be a pioneer, but I'll sit back and watch.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Old 02-19-2013, 04:43 PM   #3186
deadbird
Very Large Bird
deadbird's Avatar
Oddometer: 149
Here you go, TW200 with a leading link
http://tw200forum.com/forums/77467/ShowPost.aspx
deadbird is offline   Reply With Quote
Old 02-19-2013, 06:24 PM   #3187
Kwizard
Conservative
Kwizard's Avatar
Oddometer: 20
TW Hack
Originally Posted by deadbird View Post
Thanks db; that'll be a good place to start.
Old 02-19-2013, 06:40 PM   #3188
epix1718
epix1718's Avatar
Oddometer: 713
Anyone have the part # for the idle shaft?
On the diagram it is the part on which #4, 5 etc are attached on.
http://www.partzilla.com/images/diag...ES/STARTER.png
Or if anyone knows where I can get and idle shaft it would be greatly appreciated!! (Need one for my BW200 on which shares quite a few engine parts)
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 02-19-2013, 07:18 PM   #3189
Old White Truck
Old White Truck's Avatar
Oddometer: 113
Here are the parts for an '89 TW transmission. If what you are looking for is not on this particular page, click on the "Assembly" drop down menu and it will show you all of the other parts.
Old White Truck is offline   Reply With Quote
Old 02-20-2013, 06:33 PM   #3190
epix1718
epix1718's Avatar
Oddometer: 713
Not listed under transmission either.. went thru a bunch of the diagrams but just can't find it! I'll keep looking, in the meantime I'll just keep push starting the bike.
Here is an actual pic of another persons bike but it shows shafts/gears.. the one I am referencing too is the short shaft that holes the idle gear, it is just slightly behind of the shaft that holds the clutch.
97 Suzuki DR650
98 Honda XR250R
epix1718 screwed with this post 02-20-2013 at 06:44 PM
Old 02-21-2013, 08:51 AM   #3191
Kwizard
Conservative
Kwizard's Avatar
Oddometer: 20
Getting the shaft
OK; the part you are alluding to in your diagram is the main shaft(part #15A-17411-01-00), and will require splitting the case to install. The idle shaft is part #5HO-15521-00-00. These are the same on both the TW, and BW.
Hope this helps.😎
Old 02-21-2013, 05:37 PM   #3192
epix1718
epix1718's Avatar
Oddometer: 713
Kwizard, much thanks for the info.. took off the clutch on gf's BW200 tonight and it appears the shaft that holds the idler gear is missing or just sheared off whatever the main bigger shaft is here..
Overall view of the case side, you can see the kickstart gear on the very left and the shaft that holds the clutch, but the one inbetween is now basically an empty "hole".
Close Up of the where the idler shaft/gear is suppose to be.
Previous owner did tell me he removed the kickstart and had to push start the bike, so this must be the reason why. Not sure if this is repairable (at least w/o splitting the case and putting in an all new shaft) so I'll just keep it push start I suppose.
97 Suzuki DR650
98 Honda XR250R
Old 02-21-2013, 07:39 PM   #3193
Kwizard
Conservative
Kwizard's Avatar
Oddometer: 20
You should be able to pull, and replace that collar without splitting the case. You should only need the three parts(idle gear, shaft, & collar). You might as well get a new sidecover gasket while you're in the neighborhood. Change the oil; get it hot, and change it again. Don't forget to clean the filter.
If push comes to shove; you can always go ahead and split the cases. It ain't rocket science. Go to the www.TW200forum.com look in the tech section, and download the service manual. It'll tell you everything you need to know. The TW & BW engines are almost the same, and I think the only difference is the BW has a compression release, and the TW doesn't.
Good luck, and have fun.
**note also that there is a tooth broken out of the gear behind the kick starter**��
Kwizard screwed with this post 02-24-2013 at 10:43 AM
Old 02-25-2013, 06:16 PM   #3194
tommu56
tommu56's Avatar
Oddometer: 1,328
TW hand guards
My wife dropped her bike and pretzeled the brake lever.
What are you guys using for hand guards????
tommu56 is offline   Reply With Quote
Old 02-25-2013, 06:42 PM   #3195
Old White Truck
Oddometer: 113
The Tusk D-Flex are fairly popular on the TW200 forum. I have 2 sets (on my 2 TWs). The right side needed tweaking but I can get them to fit. They are not very expensive.
Other options are Emgo and Cycra Probends.
Times are GMT -7.   It's 09:43 AM.
