Old 06-10-2013, 03:03 PM   #3526
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,332
I'm a tad over 9000 miles, I should hit 10k by this weekend. Then I'm doing an small overhaul valves, base gasket, fork oil, chains and sprocket, new tires( still running factory tread) , a vapor and hopefully the race light.
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
DingDangKid is offline   Reply With Quote
Old 06-10-2013, 03:10 PM   #3527
andy29847
Dirt Road Rider
andy29847's Avatar
Oddometer: 2,242
The Mighty TW
This bike broke 200 miles from home:
I went home and got this bike:
All Hail the Mighty TW - 3 days and 600 miles
Story here:
http://advrider.com/forums/showthread.php?t=890804
Andy Simons
ABC#8350
IBA#7647,
Trenton, SC
Smugmug coupon code = bQItjZEfrqLkI
MOAB Ride Report
andy29847 is online now   Reply With Quote
Old 06-11-2013, 05:13 PM   #3528
DingDangKid
El Lechero
Oddometer: 2,332
Any suggestions in how to stiffen up the front end with springs or heavier fork oil?
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
Old 06-12-2013, 07:13 AM   #3529
Uwdlk2no
Uwdlk2no's Avatar
Oddometer: 19
[QUOTE=SpencerCompton;21622468]Any suggestions in how to stiffen up the front end with springs or heavier fork oil?
Pro Cycle sells a kit that will do exactly what you're talking about...check them out http://www.procycle.us/bikepages/tw200.html scroll down to suspension.
Lance
Uwdlk2no is offline   Reply With Quote
Old 06-12-2013, 04:42 PM   #3530
DingDangKid
El Lechero
Oddometer: 2,332
Lance
I didn't realize ProCycle had a TW section
I would be perfectly content ordering just about every item they stock. My wallet not so much
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
Old 06-12-2013, 05:58 PM   #3531
Goofy Footer
Oddometer: 497
There is a good thread on the TW200forum.com about front fork modification. Lizrdbrth started it/provided the data and I don't want yo misquote him but I used the 135mm fork level mark and 15w fork oil (what was available) and it firmed up the front end and slowed down the pogostick-esque dampening. The old oil had been in there since '93! You could run lighter oil. Ymmv.
Goofy Footer is offline   Reply With Quote
Old 06-12-2013, 07:36 PM   #3532
DingDangKid
El Lechero
Oddometer: 2,332
I'm not really looking to spend a lot of money on the front end. The stock is ok for me but any improvement is acceptable. I will research that route.
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
Old 06-14-2013, 12:12 PM   #3533
wa_medic
Oddometer: 43
blasphemy
Okay, I really like my TW. Probably one of the best all around bikes out there. However, I've been thinking about changing that big rear tire to something smaller (along the lines of an 18 inch). Has anyone done this or know if it is possible.
I know many will say, what's the point and/or that I'm destroying what is special about the TW. That is not my intent, just wondering if it's "doable" and kind of curious about the looks and handling of such an option.
wa_medic screwed with this post 03-23-2014 at 02:04 AM
wa_medic is offline   Reply With Quote
Old 06-14-2013, 12:27 PM   #3534
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
The TW has a 32-spoke rear hub which kinda limts the options for rims, but they're around.
Depending on your riding abilities you'll probably lose a fair amount of ability to crawl at low speeds. But the results should at least be XT-like in that regard.
Lizrdbrth is offline   Reply With Quote
Old 06-14-2013, 10:08 PM   #3535
Spud Rider
Spud Rider's Avatar
Oddometer: 3,763
Originally Posted by wa_medic View Post
Okay, I really like my TW. Probably one of the best modern all around bikes out there. However, I've been thinking about changing that big rear tire to something smaller (along the lines of an 18 inch). Has anyone done this or know if it is possible.
My Honda XR650L has a 32-spoke, 18-inch rear wheel, so I know the rims are available. You will need to lace some custom spokes to an 18-inch rim.
The TW200 should handle great. I was running a pair of 18-inch wheels on my Zong before I switched to a 21-inch front wheel.
Spud
Old 06-15-2013, 06:11 PM   #3536
DustyPockets
Flatland wanderer.
DustyPockets's Avatar
Oddometer: 59
Gents
Dusty finally gets to join the TW200 club.
Been looking for a small dual-sport and came across this one, a 91 with 4000 well used miles.
Not pretty but I'm good with it, compliments my ugly as hell KLR.
Seller disclosed it may have charging issues, off hand I think it is just the battery but may ask for help later if needed.
Hitting some back roads tomorrow!
DustyPockets is offline   Reply With Quote
Old 06-15-2013, 06:15 PM   #3537
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
In here we consider that pretty. Gorgeous, actually....
Old 06-15-2013, 07:17 PM   #3538
Paebr332
Oddometer: 973
My TW is also a '91. Also the same interesting purple...
Paebr332 is offline   Reply With Quote
Old 06-15-2013, 08:22 PM   #3539
Old White Truck
Old White Truck's Avatar
Oddometer: 113
Okay, I really like my TW... However, I've been thinking about changing that big rear tire to something smaller
Now that's just crazy talk right there. :)
Old White Truck is offline   Reply With Quote
Old 06-15-2013, 09:02 PM   #3540
DingDangKid
El Lechero
Oddometer: 2,332
Blasphemy I say!
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
Times are GMT -7.   It's 12:40 AM.
