06-09-2009, 07:33 AM
#61 |
Oddometer: 34
The risers that work on the F800GS are now online and ready to ship. Here is a link to them http://www.roxspeedfx.com/cgi-bin/ca...?subcat_id=268 They are the fifth set down # 3R-P2PP.
Let us know if you have any questions sales@roxspeedfx.com Thanks!
06-12-2009, 01:09 PM
#62 | |
just ridin somewhere
Oddometer: 81
Rox Risers
Just installed the 2" Rox pivoting risers on my ABS F8gs. Went on easily enough, I did unbolt the clip holding the clutch cable and took it out. I wanted the bars as far back as I could get them, just so they barely cleared the ignition plastics. The cables all work, but for as low as I have them, the brake line gets snug at full lock. I'm more worried about wear on it and for that reason may order a longer line. Very happy with the risers and sure make it more comfortable for me.
06-16-2009, 10:25 AM
#63 |
Oddometer: 34
Thanks for all the input here! We are glad they are working on the 800's, anyone else with input please share it.
Thanks Again. Ryan~
06-20-2009, 06:09 AM
#64 |
Beemer Virgin
Oddometer: 100
Hey guys, I'm looking at getting the 2" ROX risers. I don't need the bars to come back at all, just up. If I avoid going back and just head up, do I avoid having to reroute the cables??
06-20-2009, 06:19 AM
#65 | |
Dirt, Sweat & Gears
Oddometer: 442
http://www.happy-trail.com/Products/...OX3R-P2PP.aspx -
09 F800GS ABS Yellow/Black When you look like a rude, crude, scum sucking cretin, people tend not to ask you stupid questions! |
06-20-2009, 07:18 PM
#66 | |
Oddometer: 81
cbOwl screwed with this post 06-22-2009 at 08:42 PM |
07-21-2009, 05:31 PM
#67 |
Dirt, Sweat & Gears
Oddometer: 442
F800GS Rox Riser Update
I installed Rox Risers on my F800GS several weeks ago and somewhere, either here, the F800 Rider forum or both, I posted that they fit fine with no cable problems.
Moving the bike around earlier this week I discovered that, at full right lock, the clutch slipped almost to the point of completely disengaging. I rerouted the Clutch Cable to the outside of the fork tubes and this completely solved the problem. At full right or left lock I have a very slight play in the clutch lever before it begins to disengage the clutch. Just wanted to get this out here in case anyone actually paid any attention to my previous post.
07-31-2009, 02:04 PM
#68 |
Oddometer: 59
Anyone Installed/Used ROX for F800GS?
Anyone using the kit "specifically developed" for F800GS? Please share your thoughts on install and application?
Thanks, Chris |
08-21-2009, 01:10 PM
#69 |
Oddometer: 109
needing help
Hey all - I'm very curious if this install would work for the F650GS Twin.
I'm very frustrated with the fit of this bike for rides longer than 30 minutes. I really feel I need the bars back towards me. I can't imagine the reach works out for many women that are shorter than 5'6". Thanks for your input!
1999 Yamaha XT225 2009 F650 GS - Sold 1984 BMW R80ST |
08-21-2009, 04:09 PM
#70 |
Pro-Commuter
Oddometer: 928
I put them on my Uly and they work out great
Lets you roll the bars back will still getting the benefit of the rise. ![]() The biggest thing you have to make sure of is cable/brake line length. But i wouldn't see why BMW didn't build in some extra length on an enduro. The website doesn't have a specific model for your bike but i would just look to see what size your handlebars were and order the corresponding risers. http://www.roxspeedfx.com/cgi-bin/ca...?subcat_id=268 Heres an example from ADVrider http://www.advrider.com/forums/showthread.php?t=449135 Alternative http://www.advrider.com/forums/showthread.php?t=384922 Here is a helpful looking thread as well http://www.advrider.com/forums/showthread.php?t=415604
"Is it just me or did Erik Buell hire the same fungineers that Walt Disney did" me - just now YES THAT IS EVOLIFE IN MY AVATAR 2006 Buell Uly - barricade orange |
08-30-2009, 08:56 PM
#71 |
Oddometer: 59
+1 on BushWhacker's experience with clutch disengaging at full right with F8GS Rox Riser.
Will be attempting clutch cable reroute this week. |
09-12-2009, 12:10 PM
#72 |
Oddometer: 6
F650gs Twin Rox Risers
I completed installation of the Rox Risers (2" rise for 7/8"bars). Has improved seating position & comfort greatly. Needed a longer brake line, and at recommendation of dealer, I used Goodridge brake fittings.
14" Clear coated Brake Hose #036112 Shadow 90 degree 10mm Banjo fitting #036459 Shadow Straight 10mm Banjo fitting #036455 I did have to use 2 compression washers on each side of the banjo fitting at the handlebars. Brake bleeding was uneventful. I haven't had any problems with bars hitting the key area. Karl SE MN |
09-29-2009, 11:12 PM
#73 |
..must..build..something
Oddometer: 16
2004 DL650 Wee installed 7/8" to 1 1/8", 2" Rox Risers with no cable length issues. I have the F650GS bars on this bike, which is why it is 1 1/8. Only problem I had was removing the old 7/8 to 1 1/8 adapter. The screws it came with were not rust proof (wtf?) and I had to hammer in a torx bit and use an hand impact driver to extract them.
I have mine pivoted towards the rider side. I'm 5'11 and I was just on the edge of leaning over which was KILLING my back. I was out riding last weekend for about a half day with no problems at all, so the risers did the trick. Also note that I have them installed backwards so that they would line up with the rivets in the bars better. ![]()
10-10-2009, 04:37 PM
#74 |
No user title
Oddometer: 5
Torque
I also installed the rox risers for the F800GS. Low Pro 1 3/4"rise x 1 1/8" Stem Clamp x 1 1/8" Handlebar, Product number 3R-P2PPL. I have the risers forward about 15 degrees from staight up. The only problem I had is there is no possible method to properly torque the bottom set of bolts.
10-12-2009, 07:28 PM
#75 | |
Oddometer: 118
