Old 04-28-2010, 09:40 PM   #91
moe.ron
Poor Dumb Bastard
moe.ron's Avatar
Oddometer: 2,023
Originally Posted by ebrabaek
No worries... It is either the stock seat giving you e "wedge" or the bars being too short. The stock seat has a slope forward that methodically sends the rider forward......Most people over 5'8" need the 20mm riser at a minimum.
Erling
Thanks for the replay Erling, I should have mentioned I replaced the stock seat with a Sargent, same issue though. I am right around 5'9"ish so I guess I qualify.
Pig Can Fly.
R.I.P. S.A.S. 03/09-12/12
moe.ron is offline   Reply With Quote
Old 04-29-2010, 03:42 AM   #92
randolf
Oddometer: 15
Try loosening the the spring preload so the rear end is not so high up in the air
randolf is offline   Reply With Quote
Old 04-29-2010, 06:21 AM   #93
ebrabaek
Oddometer: 2,847
I have the new rox risers, but don`t use them. I`m not too fond of the design, and The clutch cable need to be longer along with the brake line. I use the $20 TT 20mm riser blocks for now, until I get a longer clutch cable. I think someone mentioned that the s model is 2 inches longer. I have long arms, and I when I had the rox on...my riding position was a little better than the 20mm risers. If you go the rox way, just make sure you address the clutch cable issue as well.
Erling
ebrabaek is online now   Reply With Quote
Old 04-29-2010, 07:10 AM   #94
moe.ron
Poor Dumb Bastard
moe.ron's Avatar
Oddometer: 2,023
I can do this while the bike is on the ground correct? I havent played with the suspension yet, I actually have a thread on it. Will this give me a mushy ride?
The TT risers is the way I was going to go, finally a part that does not cost a fortune.
Pig Can Fly.
Old 04-30-2010, 01:31 AM   #95
randolf
Oddometer: 15
Well, I was just kidding :) While the spring preload will move the tail of the bike upwards/downwards, it should not be that significant... but you might give it a try - turn the plastic handle all the way left (loose).
Old 04-30-2010, 07:57 AM   #96
moe.ron
Poor Dumb Bastard
moe.ron's Avatar
Oddometer: 2,023
I didnt think so nut never played with it so yep, you got me. But heck, even a half inch could make a bit of difference on a bike if its in the right spot. A half inch riser would make a difference, not much but a little.
I think I am obsessing over this bike, I have too much time on my hands.
Pig Can Fly.
Old 05-29-2010, 10:43 AM   #97
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 671
Originally Posted by drrags
Just reverse the brake line. You'll have plenty of clearance afterwards.
drrags, did you switch the clutch cable for something longer too? or did you find a way to re-route it to give it more slack? (like with the R12GS Rox install)
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 05-29-2010, 11:03 AM   #98
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,774
I re-routed it. Instead of going between the left fork tube and the frame, it is now routed to the left of the left fork tube. Plenty of slack now.
drrags is offline   Reply With Quote
Old 06-02-2010, 04:37 AM   #99
JRWooden
Oddometer: 3,444
Originally Posted by Betelgeuse
I tried the same thing but didn't like the look of the open holes left behind. Picky, picky, I know. I didn't try it with a tank bag though. I have a Wolfman Enduro that I've used for several bikes and it's worked fine but I don't like the mounting set-up on the 800.... but that's a post for another thread.
Here's a pointer to one of the other threads - on the tank bag that is...
This was how I solved it:
http://www.advrider.com/forums/showp...&postcount=304
JRWooden screwed with this post 06-02-2010 at 05:02 AM
Old 06-04-2010, 06:18 PM   #100
Big Duke 6
Big Duke 6's Avatar
Oddometer: 116
Thumb
That's Slick!!
Big Duke 6 is offline   Reply With Quote
Old 06-04-2010, 06:59 PM   #101
JRWooden
Oddometer: 3,444
My 2nd iteration was to use button head cap screws that are easier to engage and disengage and used just one plasti-lock nut instead of two jamb-nuts.
But yeah, I like the way it works!
JRWooden screwed with this post 06-04-2010 at 07:53 PM
Old 07-01-2010, 05:47 PM   #102
gofast1320
gofast1320's Avatar
Oddometer: 489
Rox Risers
Got my SW-Motech crash bars along with a set of 1.75 rise 1 1/8 stem clamp 1 1/8 bar Rox Risers today and just finished putting everything on. Seems good to go.
Now got to go ride before the deer start moving.
Will report back on how it went with the risers. I do not want to test the crash bars.
gofast1320 is offline   Reply With Quote
Old 07-01-2010, 07:35 PM   #103
gofast1320
gofast1320's Avatar
Oddometer: 489
rox risers
45 miles later. I'm liking them. Got some adjusting to do, but I'm glad I got them.Gotta do something about that seat.
Old 07-03-2010, 05:20 PM   #104
Big Duke 6
Big Duke 6's Avatar
Oddometer: 116
Sargent World Sport Performance Seat
I just added the Sargent WSPS with a side order of Alaskan Buttpad Pillion Type 1 Deluxe. Not perfect but so much better for my old ass! I think this set-up is as good as it gets.
Old 11-18-2010, 09:59 AM   #105
gofast1320
gofast1320's Avatar
Oddometer: 489
Rox risers
What he said PLUS on the brake hose- I just turned that mother around. Swapped ends and its good to go. Plenty of slack there too now.
Times are GMT -7.   It's 04:19 PM.
