Old 12-15-2011, 10:11 AM   #841
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,705
Sorry Uber..
Side number plates...the white ones...fills a gap quite nicely I notice....
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a fuck what you think.
WIBO is offline   Reply With Quote
Old 12-15-2011, 11:19 AM   #842
makazica
makazica's Avatar
Oddometer: 746
Originally Posted by flatboarder View Post
There is no way of fitting any standard WP MX shock into the Tenere. Neither conventional nor PDS.
These shocks are way too long. You need to start with a smaller shock and try to fit the reservoir somehow.
There is nearly no space for a full size reservoir, but there are ways to fit one somehow:
Note this is a small MX4014 shock and this was the biggest WP shock that would fit the Tenere after lots of internal modifications at the shock. However, the downside is we had to reduce rear travel. This shock has only got 85mm of travel as opposed to 95mm of the stock Sachs shock. This sounds bad, but suspension quality is so much better, it feels like travel is increased considerably.
My idea was to modify the suspension triangle slightly to increase rear wheel travel, but there is no way to do so at that time.
On the other hand, there is no problem of finding triple clamps. You may just use KTM 690 triple clamps:
See triple clamps of the right bike. These are KTM 690 clamps with a tailormade steering tube and stock bearing.
Thanks, I wasn't aware of the potential problem with fitting a pds shock. Non of the aftermarket shocks fit the tenere, Wilbers, Ohlins....?
I knew the forks are not a problem but what exactly do you mean by "steering tube", the part of the frame where the stem goes through? Shortened or elongated? Couldn't you just make a different stem for the standard KTM clamps?
Cause I dont see a point in spending 750 on Off the road triples......
makazica is offline   Reply With Quote
Old 12-15-2011, 11:29 AM   #843
flatboarder
flatboarder's Avatar
Oddometer: 278
Yes, sure. The Öhlins aftermarket shock dedicated for Tenere is a very small but capable shock, fitting best of all aftermarket shocks. But it is not "full size", compared to a MX shock.
The inner tube, I think you are referring to it with the term stem. Sorry for my bad english.
Making a custom stem costs around EUR 100.- over here.
However, the OTR triple clamps are nice and after all, they can easily be legalized, which is more difficult when just using some cheaper triple clamps from different motorcycles.
I had a shop make my own, which was much more expensive compared to the OTR clamps.
flatboarder is offline   Reply With Quote
Old 12-15-2011, 11:36 AM   #844
makazica
makazica's Avatar
Oddometer: 746
Thanks for the info!
Over here (Croatia) you can get a set of triples from an LC4 and machine a different stem for 200-250€...both!
Legalization isn't a problem.....over here at least.....
Your's look nice...all orange anodized and all....good work!
M.
Old 12-15-2011, 08:30 PM   #845
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,545
not all are strugling...great weather in mexico!
Originally Posted by DRTrev View Post
While you guys struggle with Northern Hemisphere weather....I took my XT660Z out for a spin the other day....
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 12-15-2011, 11:16 PM   #846
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,705
Nice moto Eakins....very nice....
Me: Honesty.
Old 12-15-2011, 11:31 PM   #847
payser
payser's Avatar
Oddometer: 128
Over here (Croatia)..
M.
What is "Legalization"?!
crowbar...helps more than words
KTM 950SE,KTM690 Ex2,xt660zx2,KLX250,DRZ400
X challenge
payser is offline   Reply With Quote
Old 12-15-2011, 11:39 PM   #848
Aussie Trev
aka DRTrev
Aussie Trev's Avatar
Oddometer: 5,611
Actually, there's probably many not far from the Equator doing very nicely, I was aiming it at the guys on other threads complaining about the UK, other European and north North American weather.
None of my bikes are leaving the garage today though, too bloody hot!!
And, for a further comparison, I've spent the best part of today organising the beer, champagne, seafood and ice, along with cleaning the swimming pool, for what is expected to be a nice and warm Christmas Day.
Merry Christmas to all you XT660Z riders (and everyone else) from us here in South Oz......
2011 Triumph Tiger 800XC
1982 PE175Z
Full member......Quorn Schnitzel Club
"Just having a crack"
Aussie Trev is offline   Reply With Quote
Old 12-16-2011, 08:58 AM   #849
Sportakus
Sportakus's Avatar
Oddometer: 779
Originally Posted by uberthumper View Post
Great machine....
Jose
Enjoy your family every second... it will be the last...
YAMAHA XT660Z Ténéré 2008
KTM 690 Enduro R 2014
Sportakus is offline   Reply With Quote
Old 12-16-2011, 01:38 PM   #850
dashmoto
Serial Tinkerer
dashmoto's Avatar
Oddometer: 414
Originally Posted by WIBO View Post
Sorry Uber..
Ahh, should have figured that out. They're Polisport ones for an XR400. This is the best shot that I've got handy. Lower mounting hole lines up perfectly with the top pillion peg bolt. I trimmed a bit off the edge of the grey trim panel (by the pillion handle) to make them fit, you can just about see the rough edge in the photo. There's another mounting hole at the top which is hidden underneath the grey panel, I just used a zip-tie through the hole and around the frame.
There's also a clue in this photo as to who I stole the idea of XR400 side panels from ;)
Edit: Look familiar? (Although I think Jenny cut the number board rather than the trim panel to make them fit)
dashmoto screwed with this post 12-16-2011 at 01:45 PM
dashmoto is offline   Reply With Quote
Old 12-17-2011, 12:35 AM   #851
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,705
A ha!!
Thanks for the pics Uber'....Does a nice job I think of filling the gap....
Me: Honesty.
Old 12-17-2011, 01:18 AM   #852
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,036
M.
Legalization is an unknown word here, they only just figured out how to tell
aftermarket exhausts apart from the stock ones. I'm betting no one will be
checking out triple clamps even 20 years from now.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 12-17-2011, 06:47 AM   #853
Dr.Biker
Oddometer: 7
http://biker.smugmug.com/Motorcycles...772783_DQsV4ND
Dr.Biker is offline   Reply With Quote
Old 12-17-2011, 11:38 AM   #854
dashmoto
Serial Tinkerer
dashmoto's Avatar
Oddometer: 414
Off the end of the world:
Old 12-19-2011, 01:35 AM   #855
Ni3ous
Double Axle Rider
Ni3ous's Avatar
Oddometer: 218
My recent ride:
Did you notice that tail tidy ?
Tènèrè Spirit
Ni3ous is offline   Reply With Quote
Times are GMT -7.   It's 09:22 PM.
