Old 11-05-2012, 02:07 PM   #1201
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 300
Originally Posted by ramar View Post
The real changes I still don't know, the YZ front is still in my terrace. It is from YZ 450 2006, used for supermotto so it's a bit harder but I think it will be ok for the heavy bike like Tenere. YZ 2006 triple clamp. I used e press to take out the original steering stem and I am going to put the Yamaha one on the same place. The forks are a little bit higher than the stock but I can correct this in the triple clamp. Single 280mm brake disk, YZ brake caliper. The rear shock I will replace with olins and will use 3.5mm boons. About the clutch and other cables, will see. I saw in the Spanish a guy did it without problem, so I will tell you more after month.
Like to see pics once you get it all together. We're using YZ 250/450 46mm forks on our BMW Dakar suspension swaps and it handles like a dream. Was always wondering when/if someone would finally update the 660 suspension. Congrats and good luck!
nomad5326 is offline   Reply With Quote
Old 11-05-2012, 10:35 PM   #1202
flatboarder
flatboarder's Avatar
Oddometer: 278
We already had several WP conversions documented here.
It is not new, but certainly interesting.
Phil
flatboarder is offline   Reply With Quote
Old 11-06-2012, 02:29 AM   #1203
dashmoto
Serial Tinkerer
dashmoto's Avatar
Oddometer: 414
WP48 front, Nitron rear...
(formerly 'uberthumper')
www.dashmoto.net
dashmoto is offline   Reply With Quote
Old 11-12-2012, 05:19 AM   #1204
Tytus
Oddometer: 5
Hello from Romania.
http://www.youtube.com/watch?v=KRbL4...ature=youtu.be
Tytus is offline   Reply With Quote
Old 11-14-2012, 08:30 AM   #1205
ramar
Oddometer: 20
I did it. The new forks are already fit on my Tenere. I using Yz 450 2006 forks, (46mm top, 49mm bottom) triple clamp was from was from WR 450 2005. The size was 44mm / 48mm and I machined it 1mm top and 0.5mm bottom to be able to put the forks in. I using the original Yamaha steering stem. Bolt it without problem, only on the top clamp i have to put 1mm spacer between the stem and the clamp(the original stem was top 25mm, the new is top 23mm. The front wheel is from YZ 450.I also changed the handle bars with 28mm. What is left is a brake caliper(YZ 450) oversize brake disk 270mm, brake hose line YZ and I am done. I did today a test drive(without front brake, just to see how it is - what a difference, now the front is not diving as before. I need to change the rear shock because now is so soft(compare to the front) and lift it with new bones (35 mm) The YZ front forks are 40 mm longer than the stock. I should be ok with the new bones on rear. a proper test drive I will make next week when everything is done.
https://picasaweb.google.com/1111224...81618871834834
https://picasaweb.google.com/1111224...81512729350066
https://picasaweb.google.com/1111224...81431440527554
https://picasaweb.google.com/1111224...81357028095666
https://picasaweb.google.com/1111224...81279734916178
https://picasaweb.google.com/1111224...81038497049474
https://picasaweb.google.com/1111224...80854171181746
https://picasaweb.google.com/1111224...80780675217026
ramar screwed with this post 11-15-2012 at 02:17 PM
ramar is offline   Reply With Quote
Old 11-18-2012, 10:57 AM   #1206
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,156
Hi all
Haven't got one yet but found one over here 3500 on a 2012 with 13000km ally bash plate new tyres and other bits only problem is the guys having charging problems , it isn't !!!! he's fit a new battery and still the same !!!
Can anyone give me a heads up on fixing and about how much ????
Still at that price i think it's cheap , what do think ????
Cheers Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 11-18-2012, 11:13 AM   #1207
flatboarder
Oddometer: 278
Originally Posted by PHILinFRANCE View Post
Hi all
Cheers Phil
Common problem. Get this (110 EUR version and carefully check cable connector to it (which is the actual reason for the failure). Might need to be exchanged as well. Yamaha used to change the complete wiring harness for warrantied cases of this problem.
Good luck! Phil
Old 11-18-2012, 11:20 AM   #1208
PHILinFRANCE
Oddometer: 1,156
Cheers Flatboarder
When you say Yamaha did the full wiring loom , is this necessary ???
Phil
Old 11-18-2012, 11:30 AM   #1209
flatboarder
Oddometer: 278
Cheers Flatboarder
Phil
Not at all, but they somehow needed to exchange the mentioned connector which required them to change the
whole loom :)
Regards, Phil
Old 11-18-2012, 02:06 PM   #1210
stoic bloke
stoic bloke's Avatar
Oddometer: 64
Hi Phil, the charging fault is a tenere thing, especially for the early ones.! Ive copied and pasted a conversion i did on mine 2 1/2 years ago. It's on the forum of all things 660 -www.xt660.com so here goes
the regulator failure's a bit of a bummer, but not a hard one to sort out. mine did not fail, i just did not want to left stranded with a flat battery and an edc light on!
about 20,000(now 35,000) miles ago i replaced mine with a more suitable unit off a yamaha fazer 600, secondhand on ebay i gave 14 all in.
it has 5 wires; black, red & 3 whites. cut off the inferior connector and connect with corresponding colours, the whites [generator phases] are non specific to the regulator [any order]. now my connector probably is the weak link, perhaps in the future i will hard wire to the loom, soldering & heat shrinking to create a perfect join. if a failure happens just resolder and seal
because the 'new' reg has about 8'' of loom it's easy to point the wires down to stop any water ingress, secure the loom out of harms way. the reg needs a slight adjustment to align the holes, better to ream out the mounting plate wih a drill etc and jobs done. now start the bike, check the battery voltage, should be above 13v with a voltmeter. any probs give me a shout.
bernard
reg with removable connector
stoic bloke is offline   Reply With Quote
Old 11-19-2012, 12:52 AM   #1211
PHILinFRANCE
Oddometer: 1,156
Hi Bernard and thanks , looks straight forward enough even for a numb brickie like me i'll be going down to see the bike sometime this week
Phil
Old 11-19-2012, 01:44 AM   #1212
dashmoto
Serial Tinkerer
dashmoto's Avatar
Oddometer: 414
Cheers Flatboarder
Phil
The (common) failure isn't (initially) in the Reg/Rec, it's the connector melting due to shorting, due in turn to the connector not being assembled properly in the factory.
Obviously for Yamaha fixing stuff under warranty, they're not going to get dealers to replace the connector, so they did the whole loom. If the bike's not under warranty (I presume it's a 2008 bike) then Stoic's solution is probably the easiest.
www.dashmoto.net
Old 11-19-2012, 02:29 AM   #1213
pmsystem
pmsystem's Avatar
Oddometer: 53
Even if I never got a problem like that (so far! ) since this year I decided to bring with me (during the trips to north Africa, not always!) a replacement regulator with all the cables plugged into the connector, so, in case, I'll cut off the old one and add the new. Yes I had to spend 110Eur but now I'm more relaxed.... ;)
Cheers
Paolo
PMSystem
http://www.pablito.it
pmsystem is offline   Reply With Quote
Old 11-19-2012, 11:23 AM   #1214
PHILinFRANCE
Oddometer: 1,156
It's a 2012 , but i don't know if it's still under warranty but 110 sounds a good deal !!!!! looks like i'll be the owner of a white tenner ...................he'll have sold it knowing my luck !!!!
Old 11-20-2012, 01:12 AM   #1215
pmsystem
pmsystem's Avatar
Oddometer: 53
2012 should be ok. With no problem.... anyway the wires and the connector plugs are too small for the amount of the electric power... to be honest, if you travel to countries where the assistance is not present or very difficult to find, I'd buy it, even if is a 2012 model....
Cheers
PAolo
PMSystem
Times are GMT -7.   It's 08:10 PM.
