Old 01-13-2009, 03:46 AM   #1
kktos OP
on a bright side of life
kktos's Avatar
Oddometer: 2,345
F800GS - show us your lights
Hi,
we were thinking mounting aux lights on the little one.
Perfect location could be on the blinker mounts.
Anyone mounted lights already ?
Where ? How ?
Show us your babe, please.
Vita brevis, ars longa, occasio praeceps, experimentum periculosum, iudicium difficile
08 R1200GSA Red 21" woody's
morocco 2006 | morocco 2007 | Traces of Kimangao: An HP2 in France, Spain and Italy | Morocco 2008: a F800GS test ride | where the destination is Anamur - Turkey via Greece...
kktos is offline   Reply With Quote
Old 01-13-2009, 07:45 AM   #2
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
2.4 watt LEDs and 35w Philips HID
I run heated gear so saving power with the measely 400w alternator was of prime importance for the lighting.
Here is my setup-each Handguard contains one luxeon K2 LED driven @ 700ma with a regulated driver
nice triangle with the stock lights. nice cause they turn with the steering
HID Ballast on gauge support bracket
handguard striaght on
LEDs only
HID lowbeam and the leds together
Full Blast with Highbeam (55watt Philips extreme power) Low 35watt HID and LEDS 2.4 watt x2 luxeon Total power 98.8 Watts
HID in main reflector
I also installed the OEM euro LED turnsignals
jessehere screwed with this post 01-13-2009 at 07:50 AM
jessehere is offline   Reply With Quote
Old 01-13-2009, 10:14 AM   #3
kktos OP
kktos's Avatar
Oddometer: 2,345
very neat !
well done job !
Old 01-13-2009, 12:49 PM   #4
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,432
Question Looks great ...
Tell us (who know too little about LED's) more about your LED set-up ...
Where did you buy the LED's ?? Regulated driver ?? How are they wired ??
Thanks - Larry
Honda
GsVs is offline   Reply With Quote
Old 01-13-2009, 01:19 PM   #5
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
Thanks - Larry
Here is all the info you need to put together the conspicuity LEDs-
The simple wiring diagrams are on the data sheets below.
I wired them into the canbus plug (under the faux tank) so they turn on automatically and turn off 30 seconds after the key is turned off.
# Part............MFG..................Price .........Qty
02008B-700 ...LED DYNAMICS $19.79............ 1
HL11K-W .......Dialight ..........$18.40 ............2
...............................Total: $69.49
above is all you need. Two light engines and one driver = 3 pcs.
Part # are above
the LED light engines comes complete with 3 different interchangeable lens.
here is the website
http://www.futureelectronics.com/en/Pages/index.aspx
70bux total includes 2 day shipping
now just get a hole saw (the size is Diameter = 34.7mm (1.37”)
and have at it. or find a another mounting spot...just make sure you post pictures and tell us all about it
here are the data sheets
http://www.leddynamics.com/LuxDrive/...-PowerPuck.pdf
http://www.dialight.com/Assets/Broch...XLUMHL11K2.pdf
Edit -Oh yea You get 3 snap on lenses with the light engines(LEDs) (a spot , a Flood & an oblong beam) I chose the oblong lens and rotated it until I had the traingular pattern, then siliconed it to the Light engine, to seal it and to be sure it wouldnt pop off.
Old 01-13-2009, 04:14 PM   #6
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,432
Thumb Research
Thanks for the information .....
LED's are cool !!
Part # are above
here is the website
now just get a hole saw (the size is Diameter = 34.7mm (1.37)
Honda
Old 01-14-2009, 06:33 AM   #7
pacix
pacix's Avatar
Oddometer: 22
Sounds interesting. Any picture available to see the results?
http://f800gs.creatuforo.com/
pacix is offline   Reply With Quote
Old 01-14-2009, 07:32 AM   #8
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Scroll up a little, pacix.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 01-15-2009, 12:22 PM   #9
pacix
pacix's Avatar
Oddometer: 22
David
They were blocked at work, but perfect from home.
Old 01-15-2009, 06:31 PM   #10
DiabloBlanco
Intl' Hops Inspector
DiabloBlanco's Avatar
Oddometer: 301
Jesse.
You are a genius. Trying to decide which handguards to go with and after seeing this I may just go back to thinking OEM as opposed to TT or Barkbuster...
I see you put the spoilers on both top and bottom.. I always thought they weren't voluminous enough, but with two spoilers... hmmmm.... notice any better wind protection with them? I know the BMW's with just one spoiler are pretty panned for their lack of wind protection, so does this solve that in any way OR if I want both lever AND wind protection should I look elsewhere?
Also, would those lights work with handguards that lack a relatively flat front angle? (like TT that rake back).
-Jordan-
Summer 09 Venezuela to Minnesota: Summer http://www.advrider.com/forums/showthread.php?t=449804
The goal of course is everywhere
US (MN, WI, IA, KS, OK, MO, TX), Mexico, Belize, Guatemala, El Salvador, Honduras, Nicaragua, Costa Rica, Panama, Colombia, Venezuela. 11 down, 184 to go.
DiabloBlanco is offline   Reply With Quote
Old 01-15-2009, 08:51 PM   #11
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
Originally Posted by DiabloBlanco
Jesse.
I am now- very happy with the wind protection as my thumbs were hanging out without the bottom spoilers. The OEM handguard backbones seem so strong I am not even buying spare levers (~$80 bux each ) I will keep my little
visegrip handy just in case.
I would recommend using the wunderlich handle bar adjusters to easily adjust the Bars, handguards,lights, levers, mirrors and gps when going from street position to off road (standing).
the wunderlich adjusters can be seen here on the bar clamps (cheap too)
The LED light engines need to be relatively level but can be adjusted by rotating them with the oblong lens. your could also mount the LEDS eslehere on the bike. Dialight also has multi LED engines check there website
Old 01-16-2009, 03:07 AM   #12
mrpete64
Oddometer: 584
waterproof??
I think your idea of mounting lights in the handle bar protectors is a great idea. One question...are they waterproof?
Mr. Pete--->
mrpete64 is offline   Reply With Quote
Old 01-19-2009, 02:16 AM   #13
kktos OP
kktos's Avatar
Oddometer: 2,345
no more installation ?
my friend installed lights recently. I'll take some picts and post them.
result is very classy. but the lights are a bit cheap.... so much for enlightment
Need to find better lens.
Old 01-31-2009, 02:40 PM   #14
border
collie
border's Avatar
Oddometer: 6
Aux lights for F650GS twin
I made a mount for my Aux lights from a cooking pan that I bought at Ross. I mounted the Trail Tech 2" 16 watt HID lamp to work with the high beam. I have the beams angled to high and outside so that I have some light in twisties. I can't seem to attach photos. Where can I get some help? http://picasaweb.google.com/boyd.ran...eat=directlink
border screwed with this post 01-31-2009 at 03:05 PM
border is offline   Reply With Quote
Old 01-31-2009, 03:38 PM   #15
Magile
"What exit?"
Magile's Avatar
Oddometer: 448
Originally Posted by kktos
Anyone mounted lights ? Where ? How ? Show us your babe, please.
Okay...
Bud Light?
Cheers, M.
Magile screwed with this post 02-01-2009 at 05:38 AM
Magile is offline   Reply With Quote
Times are GMT -7.   It's 01:00 AM.
