Old 11-30-2012, 04:00 PM   #301
EIGHTLUG
Lost on purpose.
EIGHTLUG's Avatar
Oddometer: 32
Originally Posted by fireman.peter View Post
Nice lights & nice work!
What kind of type are they?
Where did you buy it and how much do they cost?
Thanks for the reply!
They are the Rigid Industries Duallys. http://www.rigidindustries.com/Duall...twoduallys.htm
The pair with all the hardware, wiring, and switch was right at $220.00 with shipping.
-Now back to your regularly scheduled thread.
'12 BMW F800 GS TROPHY
EIGHTLUG is offline   Reply With Quote
Old 11-30-2012, 04:03 PM   #302
Avner
Not noob anymore
Avner's Avatar
Oddometer: 136
Thanks for this informacions.
Wich pair would be mostly choosen, one piece of spot and the other flood?
That would be a good choice for fog + driving light - yes.
Avner is offline   Reply With Quote
Old 12-02-2012, 02:09 PM   #303
nomadb
nomadb's Avatar
Oddometer: 152
Extra Stop Light
I am looking to add an extra LED based stop light. Basically when I brake I want this flashing light to turn on.
THE LED group has its own driver circuitry. All it needs is 12VDC to turn on. I want to synchronise this with the brake light.
What I want to add is similar to below,
http://www.valens.com.cn/product_inf...ssId=41&pri=17
I have dissasembled the rear end of the bike today. There were 2 very thin wires going to the original brake light (which is LED based). I am not sure if I can connect a paralel lamp to this thin wires.
I would appreciate any advise on how to add extra brake lights.
Regards
nomadb is offline   Reply With Quote
Old 12-02-2012, 03:09 PM   #304
Moto Mikey
Moto Mikey's Avatar
Oddometer: 448
Regards
I have HyperLights. They are very bright and easy to install:
http://www.hyperlites.com/modbo.html
Moto Mikey is offline   Reply With Quote
Old 12-03-2012, 01:50 AM   #305
nomadb
nomadb's Avatar
Oddometer: 152
I have looked at the web site
I was not able to see any instructions about fitting the kit?
I would appreciate if an inmate can post some details about how to fit the kit.
Or direct me to a related link.
Regards
Old 12-03-2012, 03:22 AM   #306
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,749
I wanted to pull the trigger this week on the touratech fog lights... But just in time they came up with some new "led lights"... If anyone has some comment on them, I'm all ears!
http://www.kohl.de/webshop/product_i...ucts_id=255029
Something like that but it is for the F800GS (the link on the website isn't working)
Loutre is online now   Reply With Quote
Old 12-03-2012, 06:22 AM   #307
Moto Mikey
Moto Mikey's Avatar
Oddometer: 448
Regards
http://www.hyperlites.com/instal/Ins...DF%2022410.pdf
Old 12-03-2012, 01:27 PM   #308
nomadb
nomadb's Avatar
Oddometer: 152
Originally Posted by Moto Mikey View Post
Thank you for the link. The posi-tap seems to make things much easier.
I plan on running the added LED stop lights with the existing tail light. I will try to put a fuse on the line just in case.
Regards
Old 12-03-2012, 05:16 PM   #309
JRWooden
Oddometer: 4,259
Regards
if you draw too much extra current with your lights, the CAN-Bus may shut down the brake-light circuit leaving you with no brake lights at all ... CAN-Bus systems do not have regular "fuses" - instead the computer just turns off the circuit if it detects an over-current condition.
The Hyperlight system gets around the extra current draw problem by just using the brake light circuit as the "trigger" to engage the Hyperlights, while using a separate power tap to actually draw the power to make the lights work ...
either a fuse block or "stealing" from the alarm/tire pressure circuit.
"Proceed with caution"
Old 12-03-2012, 10:00 PM   #310
JSkinner
SeattleRider
JSkinner's Avatar
Oddometer: 32
D2's
I would go with the Dually D2 driving beams. Really bright and great light pattern. Shop around and you can find a better price than below.
http://www.amazon.com/Rigid-Industri...lly+d2+driving
JSkinner is offline   Reply With Quote
Old 12-04-2012, 01:32 AM   #311
fireman.peter
fireman.peter's Avatar
Oddometer: 16
Yes, these D2 are even better then normal Dually, but the price is double.
It is difficult to get these lights in the EU.
Which one are better adapted, spot or flood?
F800 GS- 30 years GS
fireman.peter screwed with this post 12-04-2012 at 02:13 AM Reason: Update the message
fireman.peter is offline   Reply With Quote
Old 12-04-2012, 03:43 AM   #312
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
I've never held one of the D2's but have some duallys on my f8gs. The duallys are big and heavy, the D2's might be massive. Check out shipping weight of 14.2 lbs
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 12-04-2012, 11:21 AM   #313
nomadb
nomadb's Avatar
Oddometer: 152
You are correct. I have prepared a simple drawings as attached.
http://burak.smugmug.com/Motorcycles...7671&k=Ls5q4Sn
A relay will be used to trigger the led driver. LED driver will be connected to the battery. I need to check if I have the correct colors of wires for the existing stop lights though.
From the hyper lite manual it appears that brownwire and gray with black wire should be tapped into.
Regards
Old 12-04-2012, 04:37 PM   #314
JRWooden
Oddometer: 4,259
Looks good to me!
According the the schematic I have the brown wire is chassis ground,
so if there is a convenient location you could just bolt to the frame and avoid having to use that posi-tap.
Old 12-07-2012, 04:04 PM   #315
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,492
Laugh
solid state relay... triggered by the accessories power socket (auto-off) . Great for the camp site...
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Times are GMT -7.   It's 01:59 AM.
