Old 01-16-2013, 04:59 PM   #316
Downer
Downer
Downer's Avatar
Oddometer: 205
How do these impact visibility of the turn signals?
Originally Posted by edfetz View Post
Here is another mounting spot to consider. Well out of harms way under here, plus it gives you a bigger light pattern to approaching cagers.
I got some lights delivered today and am trying to figure out where to mount them. I am worried that if I get them too close to the turn signals on coming traffic won't be able to see the turn signals. Anybody have issues with this or am I worrying about nothing?
“People who want to share their religious views with you almost never want you to share yours with them." Dave Barry
Downer is offline   Reply With Quote
Old 01-17-2013, 07:08 AM   #317
Lager Meister
Work less, ride more
Oddometer: 157
Originally Posted by HighTechCoonass View Post
solid state relay... triggered by the accessories power socket (auto-off) . Great for the camp site...
Got a part number for that SSR? How much did it set you back?
Lager Meister is offline   Reply With Quote
Old 01-22-2013, 10:52 AM   #318
biodieselandon
biodieselandon's Avatar
Oddometer: 358
I would like to know as well. We use those quite a bit in HVAC controls.
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 02-20-2013, 01:40 PM   #319
Dwreker
The Wrecker
Dwreker's Avatar
Oddometer: 52
Gentlemen,
I put some PIAA 510s on my F800. I used the relay that came with it, but I installed the autoswitch AS7 to controll the lights from the turn signal cancel button (that was nerve wracking)...as of now I have the LED for the autoswitch just kind of hanging out, I was thinking about drilling a hole in the plastic piece around the ignition and accessory outlet and popping the LED through that. Anyone done that before? Advice on making it watertight would be great. I was thinking of using some sort of water tight epoxy on the underside of the hole after I push the LED through.
Oh, I also shoved a bunch of wire from the autoswitch down into the gap in front of the battery. Anyone think that will be an issue?
Knowledge me.
Pic of lights
Dwreker is offline   Reply With Quote
Old 02-20-2013, 03:37 PM   #320
solohvs
somewhere around the bend
solohvs's Avatar
Oddometer: 182
GS ADV Switch
I used the AUX switch from the R1200GS Adventure.
The switch is sensitive so don't wire it up the wrong way and ruin it.
It sits above the LEFT hand controls and has an LED for when the lights are ON.
A very clean and reliable set up. The AUX kit for my new R1200GS has the same switch. The factory wiring harness is plug and play.
Not so with the F800GS. My dealer added the switch in 30 minutes once I ran the wires and made all the "normal" connections with the PIAA wires.
The switch is pricy, but it looks great and is easy to get to while riding.
BMW R1200GS Triple Black
Zega Pro Black Hard Cases
Sargent Seat
BMW Nav IV GPS
solohvs is offline   Reply With Quote
Old 02-23-2013, 04:29 PM   #321
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Originally Posted by Sutherngintelmen View Post
I've never held one of the D2's but have some duallys on my f8gs. The duallys are big and heavy, the D2's might be massive. Check out shipping weight of 14.2 lbs
Dually is the same size, 2 more LEDs each lamp. Much better beam pattern too imo
Old 02-23-2013, 04:51 PM   #322
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Good info on D2s. I've been thinking of mounting my Ds on the 4Runner since I bought amber lamps (wanted fog/marker as I've got Kristas running on the bike too.) Was up at MC shop a couple of months ago and saw snap on amber lens covers for Dually (sounds like it will fit D2 as well) would be nice to have options.
Here's an email I got last night - seems there is a new led offer from Clearwater too. These look more compact like their Glenda. Didn't see anything when I linked to www for more info.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen screwed with this post 02-23-2013 at 04:58 PM
Sutherngintelmen is offline   Reply With Quote
Old 02-23-2013, 05:42 PM   #323
epicxcrider
Oddometer: 645
I might put the ds on my Fj and get the d2s for the bike. We will see :)
Old 02-24-2013, 08:29 PM   #324
isaac004
isaac004's Avatar
Oddometer: 837
ADV Monster Lights
I decided to get a pair of driving lights, mostly for day time visibility from other drivers as I am getting ready for a long Alaska ride, but also for those times when I am on the dirt after the sun goes down.
I am cheap, but I also want bright and reliable, therefore I went with the ADV Monster Model 60 flood lights. I have some friends who use these and I have heard nothing but good things about them.
I decided it would be best to mount them onto my Best Rest Headlight guard. I looked at other options but they did not suit me well. The handlebars would not work because then the lights would shine onto my windscreen and catch glare. Crash bars would not work because I think it looks ugly and they would get injured easier in a fall. I saw some nice brackets, such as one that bolts between the beak and the body, but I did not want to spend $100.
So I figured I could swap out a longer bolt in my headlight guard, and it turns out to work very well.
I also ordered the dimmer switch. I can now run the lights at the lowest setting with my low beam for normal use so I don't blind other drivers (it is easy for these lights to blind others, especially on high beam at night). When I flip the high beam switch, the lights go on full blast. I tapped off of the high beam lead through a vent hole in the back of the head light housing. The dimmer switch I mounted to the top of my clutch lever body using 3M VHB tape.
These are BRIGHT, they totally wash out my high beam.
isaac004 is offline   Reply With Quote
Old 03-10-2013, 06:52 PM   #325
chinchinete
Learning to fly
chinchinete's Avatar
Oddometer: 52
Wicked Interesting option
Isaac004: I don't want to spend $100 either. Could you elaborate on the wiring, instaling and things you ordered? I like your set up and would like to have something similar.
chinchinete is offline   Reply With Quote
Old 03-11-2013, 12:08 AM   #326
isaac004
isaac004's Avatar
Oddometer: 837
Sure, but it will take me about a week before I can grab more photos and do a quick write up. The rest of the materials are cheap/basics...splice connector, wires, connectors, relay, fuse holder...all from Radio Shack and similar.
Old 03-11-2013, 02:45 AM   #327
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
Originally Posted by Loutre View Post
Well it is done, I joined the "fog-light club"
Had to do some "accomodation" but they are working now!
but I have 3 screws over, well can't be that important right?
Mc Gyver style: I cut too much cable off so I had to open a powerstrip and take some wiring out. Well the result is there:
Works like a charm
TT LED lights btw
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 04-15-2013, 01:14 AM   #328
Scapadu
Motomaniac
Scapadu's Avatar
Oddometer: 837
Here are mine , Kildala lightbar, great stuff!
Time is not a test for truth.
"I've always been mad, I know I've been mad, like the
most of us...very hard to explain why you're mad, even if you're not mad..." N.M.
Visit Corsica Corsica Photo
Scapadu is offline   Reply With Quote
Old 04-27-2013, 04:48 AM   #329
toro618
toro618's Avatar
Oddometer: 978
Baja Design Squadron LED light. IMO, at 3600 lumins, one light is more than enough.
toro618 is offline   Reply With Quote
Old 04-28-2013, 10:15 PM   #330
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 689
Thumb Stock, Rigid Duallys, and Cyclops Penetrator
www.youtube.com/watch?v=gBmzw5QWV90&feature=youtu.be
Well lit, agree?
SOP Dirt-Rider is offline   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
