Old 06-09-2013, 02:24 AM   #331
dpm
Oddometer: 164
easiest-ever HID install!
seems like a good place to put this...
vendor was "topofking" on ebay.
Clears the fork and the brake line on my 650 by more than 1/4", dunno how it would do on an 800. A tiny, tiny ballast that may have other uses or placement.
NO canbus issues, strikes instantly every time. Doesn't get too warm either.
To fit? Drill hole in bulb cap, push wires and nut through, fit rubber washer and split washer, tighten, connect. Done!
dpm is offline   Reply With Quote
Old 06-09-2013, 02:40 AM   #332
GeeK_InsiDe
Moore Gas!!!
GeeK_InsiDe's Avatar
Oddometer: 339
The TT anti-fog aux. lights
Great for aux. lights in the night but not for the fog
GeeK_InsiDe is offline   Reply With Quote
Old 06-09-2013, 07:26 AM   #333
thleon
Theo
Oddometer: 51
Nice!!! the vendor seems that has no more this product how can search it on the net?
thleon is offline   Reply With Quote
Old 06-09-2013, 08:35 AM   #334
dpm
Oddometer: 164
this one's current:
http://www.ebay.co.uk/itm/35W-Slim-H...-/130773961936
Old 06-09-2013, 02:05 PM   #335
prasta
prasta's Avatar
Oddometer: 36
Thumb
Originally Posted by Magile View Post
Okay...
Bud Light?
Cheers, M.
speechless...
outside the wire since '81...
prasta is offline   Reply With Quote
Old 06-09-2013, 02:09 PM   #336
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,663
Originally Posted by prasta View Post
speechless...
you are 4 years late to the party mate
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 06-20-2013, 04:02 PM   #337
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,663
Mounted some Tecno Globe LED Lights. I already had foglights and liked them, but needed something to brighten my night. I did hook them directly to the battery with a switch so that I can use them when I'm camping with the engine Off.
Just the lights on without lowbeam.
Old 06-20-2013, 05:17 PM   #338
Full Power
Oddometer: 1,472
Nice tidy install.
Did it actually ship from Britain, or more probably from somewhere in asia ?
Great price for a ballast. Which H7 conversion bulb did you fit ?
I am trying to find one that isn't blue, or greenish.
Ideal would be a VERY bright 4000K... mimic the illumination of a halogen, but with MORE LUMENS.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 06-20-2013, 11:43 PM   #339
dpm
Oddometer: 164
ballast shipped from China, arrived in about ten days IIRC. I'm using it with a cheap 4300k burner that had originally been in better-half's previous car.
It's white on the road at night (but the halogen HI is noticeably yellow) but looking at the lamp in daytime it seems a tiny bit coloured. Turquoise perhaps? Funny thing is I never recall those burners looking like that on the car so it could be an artefact of the lamphouse or maybe the ballast is pushing it a tiny bit harder. Either way, intensity is NOT an issue...
Old 06-21-2013, 03:57 PM   #340
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Osram retrofit LED W5W 4,000°K
Ok so this is about the most boring lamp (W5W) in the bike... but finally an offering from a recognised manufacturer.
Osram state they are 'for offroad use only' but they have a diffusion lens which evenly spreads the directional LED beam. I went for the 4,000°K version as it's least likely to attract attention from the overzealous European authorities. It's a little bit brighter and whiter than the stock bulb and it's nice to know it will likely last the lifetime of the bike. No CAN-bus errors (the F800GS seems not too sensitive with the low wattage bulbs).
Works great in the headlamp as a position lamp, not so great in the numberplate, as the lit area of the bulb is nearer the end of the bulb than the incandescent W5W so an insufficient amount of light comes through the clear part of the housing. So, apart from the H3 headlamps, the numberplate is the only non-LED bulb on my bike.
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 08-02-2013, 12:07 AM   #341
Full Power
Oddometer: 1,472
Mine arrived in about week and a half, installed ands works great, fires up every time, no issue. had to push the headlamp housing fully forward in the adjuster screw slots so ballast clears front of fork tubes.
Supposed "4300K" HID bulb looks a tad blue-ish, in comparison to Halogen High beam, a few spurious yellow-gold-greenish artifacts, all in all an effective road illumination, sharp cut-off.
Old 02-03-2014, 10:11 AM   #342
bklynz00
bklynz00's Avatar
Oddometer: 145
Piaa Lights F800GS
Finally installed.. whew what a head ache but done. I personally love the look!!
The Ultimate Driving Machine.
bklynz00 is offline   Reply With Quote
Old 02-03-2014, 11:55 AM   #343
cuonawv
cuonawv's Avatar
Oddometer: 100
El Cheapo LEDs
Cheap, but very effective. 15w per, flood beam. $30 per the pair from ebay.
Sam Gardner
Santa Rosa, CA
2012 F800GS
cuonawv is offline   Reply With Quote
Old 02-04-2014, 02:05 AM   #344
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,634
You buy online? Linky??
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 02-06-2014, 08:57 AM   #345
andy3d
andy3d's Avatar
Oddometer: 51
going on the cheap!
I added these led lights. 15W each (1500lm) they are brighter than the BMW adventure fog LED lights on my R1200GSW and only $75 each.
I attached with a 0.50c clamp from homedepot and added a switch from trailtech for a few $. They are super tough as I've berried them in the drit a few times!!
http://www.ledsupply.com/led-kits/le...ng-kit-15-watt
andy3d is offline   Reply With Quote
Times are GMT -7.   It's 10:04 AM.
