Old 02-06-2014, 09:31 AM   #346
The Island
Im lost.
The Island's Avatar
Oddometer: 219
Originally Posted by andy3d View Post
going on the cheap!
I added these led lights. 15W each (1500lm) they are brighter than the BMW adventure fog LED lights on my R1200GSW and only $75 each.
I attached with a 0.50c clamp from homedepot and added a switch from trailtech for a few $. They are super tough as I've berried them in the drit a few times!
How do those mofos hook up to the bike? I mean, how do you attach them?
The Island is offline   Reply With Quote
Old 02-06-2014, 10:50 AM   #347
andy3d
andy3d's Avatar
Oddometer: 51
I ran power from the battery to the switch to the lights. I hijacked an already extincting screw.
andy3d is offline   Reply With Quote
Old 02-06-2014, 05:03 PM   #348
The Island
Im lost.
The Island's Avatar
Oddometer: 219
^ Nicely done. I didn't know that you could scroll through the images in your previous post.
Old 02-07-2014, 09:44 AM   #349
andy3d
andy3d's Avatar
Oddometer: 51
I did either! It's a flickr thing - lets you scroll though your photostream. I had to delete the pictures of me doing naughty things!
Old 02-11-2014, 05:45 PM   #350
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Originally Posted by Shaggie View Post
You buy online? Linky??
Sorry mate only just saw your message... easy to get here via Amazon, not sure about NZ however...
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 02-12-2014, 03:17 AM   #351
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,640
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 03-04-2014, 07:40 AM   #352
fire88dog
CaptainStache
Oddometer: 96
powering up?
What is the consensus on powering up aux. lights? I see where guys have used the taillight power wire, I see where some have tied into the small bulb in the headlight housing and also have seen some using the GPS accessory connector at the battery to have ignition power as a trigger wire to a relay. I personally like the idea of using the accessory GPS connector. Any input on this?
fire88dog is offline   Reply With Quote
Old 03-04-2014, 09:56 AM   #353
grandpa_ken
grandpa_ken's Avatar
Oddometer: 222
I used an AS7 Autoswitch triggered by the turn signal cancel button, to a relay, with switched power from a Fuzeblock for my Hella fog lights.
2009 BMW F800GS
2007 KTM 450EXC
grandpa_ken is offline   Reply With Quote
Old 03-04-2014, 10:49 AM   #354
fire88dog
CaptainStache
Oddometer: 96
for clarities sake
I plan on using a relay w main power wired directly to battery. I am primarily looking for input on various "trigger" wire resources. Twisted Throttle sells an adapter for the headlight marker light, and I have seen guys using the GPS accessory adapter at the battery, and also tapping into the taillight power wire. I think the easiest source of this switched power is the GPS connector at the battery using a dealer purchased connector. I am a little hinky about screwing w the electronics, s/a tapping into wire inline etc. due it being under warranty and the mystery, to me, of a canbus system. Thanks!
Old 03-05-2014, 06:23 PM   #355
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 683
Cyclops all the way
Light bar is a 530 Penetrator, lower aux lights, Cyclops Long Range, both 10 degrre for long throw. Headlights are the Cyclops Long Range Extremes running a Skene dimmer, daytime use will be with the yellow covers, one with the 20 degree pattern. Night time I will run one clear 20 degree lens cover and one open at %50. All are LED. Best setup I have ever seen, let alone used. Fill, distance, and perimeter lighting all covered. Conspicuity during the daylight, and clean light everywhere.
www.pssor.com
SOP Dirt-Rider is offline   Reply With Quote
Old 03-05-2014, 08:43 PM   #356
crossplane
Oddometer: 45
Words fail me mate, that's an awesome setup. I was just reading through your build thread for this - great work.
It looks fantastic as well as being practical.
crossplane is offline   Reply With Quote
Old 03-05-2014, 10:00 PM   #357
SOP Dirt-Rider
Oddometer: 683
Thanks!! Last year on the COBDR I had "enough", but I wanted more. Suspension took priority but seeing as I have that all sorted I finished off the lights.
www.pssor.com
Old 03-05-2014, 11:52 PM   #358
BMW-K
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,390
Originally Posted by SOP Dirt-Rider View Post
Pretty sure you got room for at least 4 more quad LED lights.
I'm not quite sure you have the watts to do it though!
PS: yeah, kinda jealous.
2010 F800GS Anniversary - a return to Eden
2011 Yamaha WR250R, 2012 Ducati Monster
2007 R1200GS (Sold)
IBA # 20880. STFU and Ride.
BMW-K is online now   Reply With Quote
Old 04-01-2014, 08:33 AM   #359
clarapellar
Oddometer: 19
Rigid Industries D2 LED driving lights
TT fuse block doing it's job.
This is the wiring setup with the new lights, hyper light brake lights, power-let outlet and a SAE "Y" setup for voltage meter and usb outlet for charging stuff.
Wires running out to the right side. You can see that I have a bundle of wires wrapped up there for the led signals too.
Left Side
This is the true test: Regular head light...
Now with the new lights!
I would say that I am satisfied with how bright they are!
clarapellar is offline   Reply With Quote
Old 04-10-2014, 06:41 PM   #360
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 268
Denali DM Micro
Just installed them and I am really impressed with how bright and how much light they put out! I used the 25 degree flood lens since I was looking to enhance my overall road and trail side view. they are small and light enough to mount directly to the plastic radiator shroud and take up no space, the loom was harder to fit then the lights!
headlights only
headlight and Denali's
Denali's only
Angryrican is offline   Reply With Quote
Times are GMT -7.   It's 04:39 PM.
