Old 02-09-2010, 06:26 PM   #121
rockinrog
rockinrog's Avatar
Oddometer: 2,884
Originally Posted by WoodWorks
Not that mount, but the same position:
http://www.advrider.com/forums/showp...9&postcount=51
David
After looking at your pic... I think they sold me the wrong mount.
There were 2 they said would work and they were out of the one and assured me that the one I posted would work...hmmmmmm
Thanks for the quick reply David. What mount did you use?
rockinrog is online now   Reply With Quote
Old 02-09-2010, 06:48 PM   #122
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
PM'ed ya.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 02-09-2010, 07:03 PM   #123
rockinrog
rockinrog's Avatar
Oddometer: 2,884
Mount
This is the mount they sent me
Name:  P1040163 (Small).JPG
Old 02-09-2010, 07:32 PM   #124
Sydney Rider
Oddometer: 411
Does anyone have or can point me in the direction of pictures that show how the Denali/Vision X lights attach to this mount:
Here you go.... http://www.advrider.com/forums/showthread.php?t=539501
I hope that helps.
Tony
Sydney Rider is offline   Reply With Quote
Old 02-09-2010, 07:52 PM   #125
rockinrog
rockinrog's Avatar
Oddometer: 2,884
Thanks guys.
I think I have a different mount than both of you...I have an Email in to Twisted to confirm that
A. the mount is right or wrong
B. If it is the correct mount how do I connect the lights to it.
Old 02-09-2010, 08:03 PM   #126
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Thanks guys.
I don't know how you'd connect the VisionX lamps to that mount. I think the folks at Twisted Throttle screwed up. Hope they do you right.
David
David
--Curly
Old 02-09-2010, 08:05 PM   #127
rockinrog
rockinrog's Avatar
Oddometer: 2,884
me too
David
Me too David. This would be the second time in 3 orders that they screwed up. What's the saying fool me once... yadda yadda
EDIT: "As for the mounting brackets it appears we have suggested the wrong item for your bike."
rockinrog screwed with this post 02-10-2010 at 09:41 AM
Old 02-16-2010, 09:57 PM   #128
rockinrog
rockinrog's Avatar
Oddometer: 2,884
included mount
Included
Name:  P1040166 (Small).JPG
Old 02-20-2010, 03:44 PM   #129
cula
cula's Avatar
Oddometer: 57
Originally Posted by jessehere
I run heated gear so saving power with the measely 400w alternator was of prime importance for the lighting.
Here is my setup-each Handguard contains one luxeon K2 LED driven @ 700ma with a regulated driver
nice triangle with the stock lights. nice cause they turn with the steering
HID Ballast on gauge support bracket
handguard striaght on
LEDs only
HID lowbeam and the leds together
Full Blast with Highbeam (55watt Philips extreme power) Low 35watt HID and LEDS 2.4 watt x2 luxeon Total power 98.8 Watts
HID in main reflector
I also installed the OEM euro LED turnsignals
Where did you find OEM euro LED turnsignals?
cula is offline   Reply With Quote
Old 02-20-2010, 04:55 PM   #130
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
bmw pn 63137708048 i used 4 of these short led. get em at any dealer
stockeuro uses 2 above & 2 longer pn 63237710574 for the rear
jessehere is offline   Reply With Quote
Old 02-21-2010, 01:30 PM   #131
cula
cula's Avatar
Oddometer: 57
LEDs only
Did you have any problems installing 55w in reflector? (melting, warping, etc...)
Old 02-21-2010, 04:48 PM   #132
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
no why would I? the original h7 is 55 watts also.
Old 02-21-2010, 05:41 PM   #133
cula
cula's Avatar
Oddometer: 57
I don't know, because of the heat. Somebody said that 55W HID has a higher temperature output than the 55W halogen. Well, I guess they were wrong.........
Old 02-21-2010, 06:33 PM   #134
geno_rocket
Oddometer: 144
Temp Output
May be thinking of the color temperature of the bulb - I believe HIDs have a higher color temperature than halogens. The halogens are somewhere around 3,000K, while HIDs are higher
Check out the discussion on color temperature on wikipedia, probably more information than most people can stand (or understand) but it gives you a reference. http://en.wikipedia.org/wiki/Color_temperature While surfing, I also found this gem on the various automotive lighting standards.
http://en.wikipedia.org/wiki/Automotive_lamp_types
geno_rocket is offline   Reply With Quote
Old 02-21-2010, 06:34 PM   #135
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
watts x 3.413 = heat in btus per hour
Times are GMT -7.   It's 04:30 PM.
