Old 01-14-2009, 09:29 PM   #1
RidingAgin OP
RidingAgin's Avatar
Oddometer: 340
Cool2 2008 BMW R1200GS Final Drive Fluid
NOTE: Recent posts now have the fill level at 180ml not 220ml for 2005 and later 1200 FD. Also, now BMW recommends change at 12K miles. June 21, 2009.
Questions arise about the need to and the time to change the fluid in the R1200GS Final Drive [FD]. Since I have a 2003 R1150RS with easy access to the final drive fluid change, I don’t know why BMW decided to go for a lifetime design in 2007 on the GS [and others?] that didn’t work, so BMW added the drain on the bottom again in 2008 [But glad they did]. Having the 600 mile check done at the dealer, accepting that was to be the last change it would ever need was a hard one to swallow. I was spending too much thinking about and decided to just do it and take a look at the fluid. I am glad I did.
Since I did not find out any FD change information for the 2008 spelled out, I thought I would document what I did and maybe it will be useful for others. I do have the JVR Productions and other notes on FD fluid, but none on the 2008 GS that satisfied me.
Before changing the FD fluid, determine if you will be filling via fill plug or the ABS speed sensor.
Be sure to have, Gear Oil [I used BMW 75-90 Synthetic], a spare O ring for both the ABS speed sensor and/or washer for fill plug, and O ring for drain in case they need to be replaced. The crush washer should be replaced. Being “lifetime” designs, I think the O rings could be reused for at least 2 years or longer. Remove the ABS speed sensor before removing the drain plug, to assure you have access to fill up the FD.
With bike on center stand, remove rear wheel. No need to remove back plastic mud guard. Use T-50 in cross pattern method in loosing the wheel. [Bolts ccw to remove]. No need to remove rear brake.
Figure 1. Rear Drive Assembly with rotor, brake, etc.
Figure 1a. View of the Fill plug and ABS speed sensor.
Figure 2. Enlarged view of Speed Sensor by rear brake caliper.
ABS speed sensor.
Figure 3. ABS Speed Sensor with wire retainer and clip.
Remove T-25 screws to ABS speed sensor and wire retainer. Also a clip holding the wire should be pulled off the frame to allow movement of ABS speed sensor to the side and away from the rotor.
Place catch pan under the drive, then use T-45 to remove drain bolt on bottom.
Figure 4. FD Drain plug with magnetic insert
Attached are photos showing fluid at 6067 miles with a 600 mile change [per dealer]. The fluid was dirty, a little bit more than I expected.
Figure 5. FD gear fluid drain.
Figure 6. FD Gear Oil.
Figure 7. FD Gear Oil with side light on fluid
Be sure to clean drain plug as it has a magnet inside of it to collect metal. All metal particles in my drive were very fine, but did fill the drain plug’s cavity. I used Q tips and paper cloth to clean all of the metal particles.
Figure 8. < dirty
Figure 9. < cleaned
Both the O rings on the ABS speed sensor and drain plug looked ok. So I decided to reuse them. Be sure to put some fluid on the O rings before re installing the ABS sensor and drain plug.
Tighten Drain plug to 20 nm or 14 # ft.
Add 180ml to Final Drive thru the hold where the ABS speed sensor is. A bottle from Sally beauty supplies works [mentioned in other year’s article]. This take time, take a few breaks and move the rotor to move the fluid around within the FD.
Figure 10. Sally beauty supply bottle, about 2.00 US $.
Note: I did a check on the fluid that came out and it looked like about 220 ml. The side of the container near the dent was the level.
Figure 11. Old fluid in empty container for fluid quantity check.
Install the ABS speed sensor and wire retainer, 2 screws, torque to 4 nm.
Be sure the clip on the wire is reattached to the bike frame [swing arm].
Figure 12. Note clip on wire.
Figure 13. Assembled back into bike arm.
Replace the rear wheel. Leave the threads dry [no anti seize required]. Tighten to 60 nm or 44 #ft. Tighten in cross pattern evenly with hand felt torque, till torque wrench time. Done.
I hope this is useful to the owners of 2008 GS models. I plan to change my Final Drive fluid every 6000 miles or every year.
As a disclaimer, your net liability claim is limited to what you paid for this information.
If you would like a better document, a word file, with better images PM me.
RidingAgin 01-12-2009.
Note: the earlier post had red x's. I did not see them with Firefox, but was able to edit them out with IE.
08 R1200GS
RidingAgin screwed with this post 06-21-2009 at 09:11 PM Reason: Bad link for photos
RidingAgin is offline   Reply With Quote
Old 01-14-2009, 09:54 PM   #2
Gravehunter
Gravehunter's Avatar
Oddometer: 747
Interesting but all i can see are red X's.
2005 BMW 1200GS
Gravehunter is offline   Reply With Quote
Old 01-15-2009, 09:33 AM   #3
blksilverado
blksilverado's Avatar
Oddometer: 64
I've got a 2009 Adventure, and I filled my rear drive using the fill plug which is just the the left of the speed sensor. I see the plug in your picture with the sensor pulled out ( @ approx. 11:00 on the drive unit ). Makes it much easier, no worry about any damage to wiring or components.
2007 HD Ultra Classic
blksilverado is offline   Reply With Quote
Old 01-15-2009, 08:41 PM   #4
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,418
Fill Plug!
Yea, on the 08s there is a fill plug. No need to pull the speed sensor.
RED CAT is offline   Reply With Quote
Old 01-16-2009, 03:57 AM   #5
2Evil4U
2Evil4U's Avatar
Oddometer: 996
My '07 ADV has the drain and fill plugs as well. Super simple.
ADV Relay Louisiana State Coordinator: Thanks to LiteHeaded, Juice Box, RagnCajn and the gang at DSRL for doing all the work!
2Evil4U is offline   Reply With Quote
Old 01-16-2009, 06:57 AM   #6
ACK HP2
ACK HP2's Avatar
Oddometer: 213
I was wondering why BMW would add a bottom drain plug and still have to be filled thru the sensor hole? Never did check the fiche, but it's there. Doesn't help me any, but good to know if you didn't. Don't forget, you'll still want to lube the splines now and then.
2007 RT-P
Riding this one 'till I drop...........
ACK HP2 is offline   Reply With Quote
Old 01-16-2009, 10:39 PM   #7
RidingAgin OP
RidingAgin's Avatar
Oddometer: 340
I did see recommendations to clean the sensor, but my sensor seemed fine. Maybe that mindset caused me not to even look for a fill plug. Glad to get the inputs.
I'd like to know what the lube the splines interval should be. I did a quick look thru the Maintenance Schedule [printout from the local BMW dealer for the 08 12GS] If you go thru water, it makes sense, but otherwise...
08 R1200GS
Old 05-31-2009, 10:00 AM   #8
Groucho
Hexhead Hoon
Groucho's Avatar
Oddometer: 470
I was in WTF Mode when I noticed that my FD drain plug wasn't where JVB's video and the writeup linked in the G-Spot FAQ said they would be... Search Function 4tMFw!
Excellent writeup, and thanks!!!
"When in doubt, gas it. It'll either solve the problem, or remove the suspense."
2008 BMW R1200GSA Schnellpanzerkampfmotorrad
1977 Moto Guzzi 850-T3 FB
Groucho is offline   Reply With Quote
Old 05-31-2009, 07:17 PM   #9
JR356
JR356's Avatar
Oddometer: 3,169
Please note the new BMW recommended fill amount is now 180ml when doing a fluid change.
See postings here and other BMW forums!
http://www.advrider.com/forums/showthread.php?t=466921
Check reply #17 on page 2 for the official BMW bulletin.
JR356
JR356 is offline   Reply With Quote
Old 06-01-2009, 02:40 AM   #10
brianstanfill
has adventure
brianstanfill's Avatar
Oddometer: 151
Just in time
Used this thread this weekend for the first service. Thank you RidingAgin, and thanks BMW for a drain plug at the bottom and a fill plug at the top... who woulda' thunk it
Brian Stanfill
Tour of the Americas: August 16, 2010 - present
brianstanfill is offline   Reply With Quote
Old 06-01-2009, 06:57 AM   #11
SplatteredBugs
SplatteredBugs's Avatar
Oddometer: 50
Great info, thank you!
SplatteredBugs is offline   Reply With Quote
Old 06-20-2009, 07:10 PM   #12
Risokyo3
"Its suppose to do that"
Risokyo3's Avatar
Oddometer: 61
Filler plug
Can someone tell me what the torque value is for the filler plug, I have an 08 model.
Jim
Risokyo3 is offline   Reply With Quote
Old 06-21-2009, 09:18 PM   #13
RidingAgin OP
RidingAgin's Avatar
Oddometer: 340
I can't find anything written on the 08. I do have a CD for the R1200GS and maybe due to all the permutation of FD design, it has slipped. In my R1150RS shop manual from Clymer, that Final Drive fill plug is at 23 nm or 17 ft lbs. It looks similiar to the GS but in a different location. It was on the outside for the 03 R1150RS.
08 R1200GS
Old 06-21-2009, 09:27 PM   #14
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,494
It is documented here as well: http://www.jimvonbaden.com/R1200_Final_Drive.html Read the whole pictorial.
The drain plug is 8nm.
Jim
Old 06-22-2009, 05:49 AM   #15
Risokyo3
Risokyo3's Avatar
Oddometer: 61
Thanks for the reply guys.
Jim
Times are GMT -7.   It's 04:08 AM.
