Old 08-27-2013, 04:03 AM   #31
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,274
200 ml is too much, should be 180 ml.
ride till you can't.
1200GS/black
Boxer Cup Replika/red-white-blue
Semper Paratus
marty hill is offline   Reply With Quote
Old 09-28-2014, 11:55 AM   #32
ngng
ngng's Avatar
Oddometer: 70
2009 here. Misread the original how to and filled to 220...whoops, looks like I will be doing this again this week.
What are you all using to lubricate the rubber gaiter? Will the Moly 60 work fine? Do we need to do anything to the speed sensor, other than wipe it down and clean the o-ring?
06 DRZ400SM | 07 Race R6 | 08 1198S | 09 R1200GSA
…and those are just the bikes
ngng is offline   Reply With Quote
Old 09-28-2014, 12:08 PM   #33
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,343
Bluhduh
Use Staburags NBU 30 PTM grease on the front mating surface of the rubber gaitor, Moly 60 is better than nothing but not nearly as resistant to water.
Clean the speed sensor and install a new o-ring with a drop of clean gear lube on it.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 09-28-2014, 12:13 PM   #34
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,343
Bluhduh
The Staburags stuff is hard to find so you may try another brand of water-proof grease that isn't harmful to rubber like Bel-Ray waterproof grease.
Clean the speed sensor and install a new o-ring with a drop of clean gear lube on it, make sure to only use clean oil.
Pull chocks.
Old 09-28-2014, 12:43 PM   #35
ngng
ngng's Avatar
Oddometer: 70
The grease for the mating surface is just to keep the outside elements out right?
I'll pick up a new o-ring for the speed sensor and drain plug this week.
Old 09-28-2014, 12:48 PM   #36
ngng
ngng's Avatar
Oddometer: 70
Found the Staburags on eBay!
http://www.ebay.com/itm/BMW-K100-K75...cffc19&vxp=mtr
Old 09-28-2014, 01:18 PM   #37
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,409
Does anybody flush the gear cases with ATF before filling with fresh GL-5?
I do.
The woods is closing in on me...I need a D6.
def is offline   Reply With Quote
Times are GMT -7.   It's 04:39 AM.
