Go Back   ADVrider > Riding > Regional forums > Canada
Old 12-12-2011, 11:53 PM   #4171
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 799
It was taken down at the host site
The faster you go, the smoother it gets
Moab 2012
Rider23 is offline   Reply With Quote
Old 12-14-2011, 05:47 AM   #4172
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,444
Originally Posted by Drif10 View Post
Yeah, learn from my lesson.
On the last page of that link, there's two more links that meat came up with, follow them all, there should be enough info get you through.
On the original removal, I did as I thought: Ground down the heads of a couple of grade 8 bolts just enough so that they'd twist in and bite, then I think I connected those to a slotted puller bar and tightened them down.
Good luck.
Thanks! Doesn't look too difficult. Maybe I'll open it up and find that it's already changed! Doubt it though.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 12-14-2011, 08:29 AM   #4173
Quantis
Quantis's Avatar
Oddometer: 246
Cyclops Headlight
Has anyone heard anything good or bad about these headlights?
http://www.cyclopsadventuresports.co...products&id=94
Looks to be DOT approved so I'm thinking it might be a neat addition for my DR project.
Found some info in http://advrider.com/forums/showthread.php?t=712386
- Stephen
Blog: www.Quantis.ca | I take photos: www.fasttrackphoto.com
RR: Trans Tiaga / North Road | RR: Making the TCAT | RR: Moab 2012 |
Quantis is offline   Reply With Quote
Old 12-14-2011, 09:01 AM   #4174
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,856
- Stephen
if it were me I would be more inclined to go with Baja Designs. Lots of options but their base model for an 8 inch is cheaper than what your looking at and it comes with their outstanding quality that they are known for
http://bajadesigns.com/ProductDetail...8-Inch-Halogen
ps....hows the DR coming along? Carb ?
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 12-14-2011, 09:32 AM   #4175
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,681
I agree. The Baja Design kits are nice. And as much as the HID kits are bright as hell, decent light is possible from halogen. Less complexe because you're only dealing with a bulb, and cheap/reliable, too.
Also worth consideration: I've seen the DOT legal halogen kit from Trail-tech installed on a couple of bikes. Very good value for the $100 price tag. Probalby not nearly as bright, but if you add an auxiliary set of Denali LED flood lights, you'll have plenty of lighting.
http://trailtech.net/suzuki-x2-ds-halogen-kits.html
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 12-14-2011, 09:35 AM   #4176
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,856
Speaking of how a dr is coming along...still waiting to see your "rally dr"
Roaming Rally 2015
Old 12-14-2011, 11:15 AM   #4177
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,613
I said the same thing.
Good luck.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 12-14-2011, 12:45 PM   #4178
thumpididump
MacGyver
Oddometer: 2,681
Yes. I hope to put some time into that project over the winter.
Keyboard Diarrhea
Old 12-14-2011, 07:44 PM   #4179
Quantis
Quantis's Avatar
Oddometer: 246
Forks and steering damper are on. Just need to find some different sized bolts to get the handlebar clamps to mount to the triple clamp properly, then I can mount the fat bars and start to put all the controls back on.
I just ordered a new billet aluminum throttle tube that requires 15% less rotation to get to full throttle.
Carb is sitting right here beside me with the procycle.us rebuild kit. I'm going to sit down one night next week and figure out how it all goes together with the new jets.
Rear shock still needs to be put on but that is easy.
I also have all the stuff to do valve check/adjustments so I need to do that too.
Still on the shopping list are heated grips, Solstice lights, New turn signals (mounted to the barkbusters), and potentially a new headlight depending on how well the old one goes back on.
Old 12-14-2011, 07:54 PM   #4180
thumpididump
MacGyver
Oddometer: 2,681
Did you get a new rear shock, or rebuild?
Could have saved a few bucks on the billet throttle tube. For $15, the OEM tube from a Yamaha R6 goes on without any issues.
If you want a hand with the carb and/or valves, let me know.
I've also got 1 brand new Solstice LED if you'd like to see it.
Keyboard Diarrhea
Old 12-14-2011, 08:21 PM   #4181
bumblebee1
All bikes are dirt bikes
bumblebee1's Avatar
Oddometer: 1,431
He got a cogent. Barely used too.
And what are you planning to do with your one and only life?
bumblebee1 is offline   Reply With Quote
Old 12-16-2011, 01:00 PM   #4182
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 799
Well after a few months of trying to figure out my new ride I finally pulled the trigger
Moab 2012
Old 12-16-2011, 01:23 PM   #4183
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,856
That's not ready to race ......
Roaming Rally 2015
Old 12-16-2011, 01:34 PM   #4184
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 799
I know I know lol
You'll just have to put up with a KLR on your ass for another for months
Moab 2012
Old 12-16-2011, 02:09 PM   #4185
bumblebee1
bumblebee1's Avatar
Oddometer: 1,431
How many dirt bikes can that truck carry?
Times are GMT -7.   It's 05:52 PM.
