Go Back   ADVrider > Riding > Regional forums > Canada
Old 04-07-2012, 05:08 AM   #4606
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,662
Originally Posted by Deadly99 View Post
Anyone have a Magura clutch bleeding kit or a syringe and hose contraption for bleeding a clutch ?
So close to being able to go for a ride it hurts
Never bothered on mine. Took max 5 minutes to get it good the old fashioned way.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 04-07-2012, 05:14 AM   #4607
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,040
Fair enough, I'll just keep bleeding it the traditional way. It's tricky as the reservoir is so small. Manuel and web gurus all indicate a reverse bleed is the way to go...but I don't have the means to do that so I'll retry the old fashioned way again.
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 04-07-2012, 05:45 AM   #4608
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,662
As a last resort: 5' of hose that fits on the bleeder nipple. Fill with fluid. Crack nipple open, blow on end of hose, GENTLY. It'll do the job, then a straight bleed once the fluid has settled.
Old 04-07-2012, 06:21 AM   #4609
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,140
You can go to a pharmacy and ask for a 20cc or bigger syringe.
Vets (horse, cow) are a good source.
I don't remember how I did mine, but I guess I first manually fill the slave and then used the old way
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 04-07-2012, 06:42 AM   #4610
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,662
Tsc has good ones.
Old 04-07-2012, 07:13 AM   #4611
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,040
Tsc has good ones.
Good tip, on my way
Roaming Rally 2015
Old 04-07-2012, 09:22 AM   #4612
Quantis
Quantis's Avatar
Oddometer: 247
Just a FYI for everyone.
I decided to go check out both Limerick forest and Scotch line Rd. yesterday and they both had these signs all over the place.
Looks like things are closed for the next little while.
Blog: www.Quantis.ca | I take photos: www.fasttrackphoto.com
RR: Trans Tiaga / North Road | RR: Making the TCAT | RR: Moab 2012 |
Quantis is offline   Reply With Quote
Old 04-07-2012, 10:01 AM   #4613
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,040
Tsc has good ones.
Mystery solved, missing the bearing inside the slave
Anyone have an 8mm bearing or know somewhere thats open today that would have one..
Roaming Rally 2015
Old 04-07-2012, 10:34 AM   #4614
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Have you tried General Bearing Service?
(613)238-8100
Old 04-07-2012, 10:37 AM   #4615
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,985
Or Napa in Kemptville, if GBS is not open.
pelvis_98 is offline   Reply With Quote
Old 04-07-2012, 03:31 PM   #4616
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,140
Mystery solved, missing the bearing inside the slave ..
WTF ?
Wich bearing ?
Old 04-07-2012, 05:27 PM   #4617
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,040
WTF ?
Wich bearing ?
http://www.advrider.com/forums/showthread.php?t=779629
Roaming Rally 2015
Old 04-08-2012, 07:16 PM   #4618
dialdn OP
dialdn's Avatar
Oddometer: 669
Thanks for posting. Good of them to put up those signs. Riding this time of year can really destroy trails for not only this season but the next as well.
D
2009 BMW GS Adventure
Follow me on Twitter (@BeemerOttawa)
dialdn is offline   Reply With Quote
Old 04-09-2012, 04:49 AM   #4619
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,985
D
Saw several guys going in with trailers with bikes over the weekend, dont know if they turned around when they saw the signs or not. I did see a group of ATV's going through though.
They do close it up every spring. But the trail that goes past me is drying up quite nicely.
Old 04-09-2012, 07:28 AM   #4620
El Explorador
Radical Explorer
El Explorador's Avatar
Oddometer: 288
What happens to the trails if people ride them early? Digging ruts in the soft earth?
El Explorador is offline   Reply With Quote
Times are GMT -7.   It's 12:26 AM.
