Go Back   ADVrider > Riding > Regional forums > Canada
Old 05-08-2012, 03:46 AM   #4831
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 42,786
Originally Posted by shipwrek12001 View Post
UPS
after receiving bling by UPS, a few weeks later I receive in the mail a bill from them. Do I really have to pay it?
Gotta love their 'brokerage' fees.
Made a $17 item ring in at $62 when they were done.
Nah, nothing wrong with the way they do business. Nope.
Life is not measured by the number of breaths we take,
but by those moments that take our breath away.
George Carlin
Drif10 is offline   Reply With Quote
Old 05-08-2012, 03:55 AM   #4832
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 1,587
In my case the bling was 65$ shipping on the front end was 30$ and the bill in the mail is 42$
shipwrek12001 is offline   Reply With Quote
Old 05-08-2012, 04:01 AM   #4833
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,779
If the only alternative for shipping is UPS, I choose not to buy. UPS Brokerage fees are a blatant ripoff.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 05-08-2012, 04:03 AM   #4834
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,762
Originally Posted by Emmbeedee View Post
Thanks for this, Brian. I saw on F800Riders that you had changed yours so I wondered what tool you had used. I found some drill bits today which look like they'll get the race started (Cue audio - Gentlemen, start your engines!) and once it's moving, use the nail trick like you described.
I dont know if this is a "recommended" way of doing it. I was just careful and it seemed to go ok.
I cut a slit in the old bearing and put it on top of new bearing to push it on.
pelvis_98 is offline   Reply With Quote
Old 05-08-2012, 04:14 AM   #4835
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,779
If you read the Haynes manual, it recommends using two screwdrivers to lever it off, or "tap with a cold chisel under the bearing" or "split it with an angle grinder", all methods likely to damage things. Yikes.
When I put the new bearing onto the stem, I found a short section of chain link fence pipe was the right size to pound the bearing down without damage.
Old 05-08-2012, 04:23 AM   #4836
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,762
I had read some place to cut the bearing with the grinder. I knew i would never be able to do that with out causing damage. Instead i cut it after to use for protection to install the new one.
The fence post would work great, unfortunately my neighbour wasn't so willing to let me cut a small section out of his.
Old 05-08-2012, 05:12 AM   #4837
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,779
The size you need is the one used for the top rail of fence. He'd never notice.
But if you want a piece, we have an extra section you can have.
Old 05-08-2012, 07:02 AM   #4838
peterthefarmer
Venison sausage4sale
peterthefarmer's Avatar
Oddometer: 144
Looking for a drift: time to change the steering head bearings on both of our GS BMWs and the lower ball on the stem is easy to get out if you have a 1/8" drift, as you can punch it off using the two holes in the steering yoke, but those holes are about 1.25 deep and none of the drifts I've found so far is that long.
Anyone have any idea where I can find that kind of tool, or some hardened rod I can use that way?
This is the kind of thing I need, but longer than normal:
This is what the outer bearing race looked like. (Bike handled terribly, of course)
Did you get the inner race out Mike? A piece of drill rod will work (machine shop will have). When your putting the outer race in throw it in the freezer for a couple hours first, makes life a lot easer.
"I'm as stiff as a 'ol horse" said my 92 year old grandpa. I said "Pop you are a 'ol horse"
peterthefarmer is offline   Reply With Quote
Old 05-08-2012, 07:53 AM   #4839
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,779
More good suggestions - thanks Peter. I did get the bearing off the stem on Stephanie's bike but have my own F800 to do, probably this week.
I did put the outer races into the freezer, and in fact the set for the 800 are still in the freezer - must remember that when I go looking for them later!
Old 05-08-2012, 09:13 AM   #4840
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 42,786
I have an old toaster oven in the garage for heating up the lower bearing before I drop it on the frozen stem. Drops in nice as you please.
George Carlin
Old 05-08-2012, 09:46 AM   #4841
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,779
I put mine on the top shelf of the gas bbq set to lowest heat.
Old 05-08-2012, 10:34 AM   #4842
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 42,786
Use what you got.
George Carlin
Old 05-08-2012, 04:01 PM   #4843
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 704
In this house its quite okay to heat one up in the kitchen
Stephanie
'08 BMW F650GStwin (Jutta), '01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
"It's a jet-pack, Michael. What could possibly go wrong?" Gob Bluth in Arrested Development, season 3, episode 7.
dresda is offline   Reply With Quote
Old 05-08-2012, 04:49 PM   #4844
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,779
Wow, sure is easy when you have something like the right tool for the job.
I bought a 9/64" drill bit, ground the fluted section off to make a punch out of it, and it worked! This drill bit cost me $4, but it was worth it.
And it only took me two minutes to punch the bearing off.
Yay! Thanks everyone for the suggestions!
Old 05-09-2012, 09:24 AM   #4845
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 1,972
Yes, a little fuel will usually remain in the bowl. As Ted says, fuel stabilizer is a good idea. I like to add stabilizer to the fuel, then start the engine and shut off the petcock, and run the engine till it dies. That's about as much as you can do short of removing the bowl. Remember that ethanol blended fuels breakdown quicker than good old straight gasoline. Ethanol will also absorb water moisture from the air.
Either way, pull your carb and give it a good cleaning. Then drain your old gas (yes, even if it's a full tank) and refill with fresh.
Originally Posted by heli00 View Post
Thanks Derek.yes, everything was good last fall. I did drained the carb bowl, but I didn't run the motor after that. I suppose just draining the bawl may not be enough. Maybe I should have ran the engine until it would stop, that way all the gas left in the carb would have been consumed. Do you know, once the bowl is drained, is there still gas inside the carb?
I'll start with the pilot for now.
Ovi.
Sent from my Galaxy Tab 10.1 with TapaTalk
_______________
"You can't put the shit back in the donkey." - Tony Soprano
FYYFF
thumpididump is offline   Reply With Quote
Times are GMT -7.   It's 01:30 AM.
