Go Back   ADVrider > Riding > Regional forums > Canada
Old 07-05-2012, 04:23 AM   #4996
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,086
Originally Posted by Dan Alexander View Post
Well I hope he has fun while I sit around dreaming of riding
I'll guess vacum line has water in it,
water won't pass the injector, if water is still in the fuel rail as well.
shipwrek12001 is offline   Reply With Quote
Old 07-05-2012, 05:33 AM   #4997
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,483
Originally Posted by Drif10 View Post
No exhaust can cause poor idle.
I had the can on the bike when trying to idle, just removed it yesterday to get at the subframe bolt that sheared.
With the can removed it's almost as loud as the Two Brothers exhaust I bought for it that is now a fancy carbon fibre door stop.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is online now   Reply With Quote
Old 07-05-2012, 05:36 AM   #4998
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,098
Originally Posted by shipwrek12001 View Post
Hows that picture... I'll be recommending no more coffee brought to your work... LOL
@ Dan
No iddle, then the bike stalls, right? or does the bike stalls at a higher than normal rpm (around 1400rpm IIRC)
In the carb (well, not a carburetor, but I don't know how it's named in english), you have a bypass (use for iddle), easy to take apart(the part with an electric wire) and then clean
Being there, check if it receive power when contact is on or engine is on (don't know if it supposed to have electricity when engine running but at a higher rpm than iddle)
The gas filter ($80 at Max) is also the pressure regulator
I have a old one wich was working (except bike stalling from time to time, but not sure it was the guilty), I'll try to keep it with me this morning... send me an email if you come downtown to get it.
Lastpoint, without a good battery, this bike is not running correctly (and stall)
These engine a shut by an automatic system wich opens engine valve if rpm is lower than1400 (IIRC)
The goal was to help the starter to run the engine (valve being open)... the bad side being the engine will stalls no matter what you do ifyou are lower than this rpm
I go get the filter and go to work!
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 07-05-2012, 05:42 AM   #4999
Oros
Oddometer: 19
I drained the gas and put in a nice concoction of fresh stuff and it sounds better but still won't idle. I had to cahnage a subframe bolt while I was at ity so tomorrow I'll reinstall the exhaust and try it on the road.
One at a time, I would unplug your O2 sensor (bottom of exhaust pipe, behind the bash plate) and try to idle... plug back in and then unplug the air sensor (in the snorkle) and try to idle. The bike should run without either of these attached, and computer will go into factory default mode. This will eliminate those two variables. (O2 sensor is $200+; air sensor is $30)
If you still have the airbox off, something else to do is to clean the injector .. just pulls right out of its little nest (sits in the there via a rubber o-ring). Let it soak for 24 hrs in H*nd* or Y*m*h* carb cleaner .. red, thick, nasty smelling shit. While you are at it, replacing the fuel regulator is useful, too. (It is more of a regulator - less of a filter, so it requires a certain pressure to keep fuel moving).
I was having idle problems on my 01 F (80K miles .. not drowning!) and went through this exercise recently. I had to replace both O2 and air sensors.... runs like a champ now.
Oros is offline   Reply With Quote
Old 07-05-2012, 05:43 AM   #5000
Oros
Oddometer: 19
Two votes for a new regulator!
Old 07-05-2012, 05:54 AM   #5001
Dan Alexander
Oddometer: 7,483
Thanks guys, I was wondering if the o2 would have gotten messed up with the pipe being full of water for a couple of days.
Eric, I'm not sure if i can get downtown today but tomorrow for sure. I'll let you know.
Old 07-05-2012, 06:48 AM   #5002
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,098
I'll be somewhere around, send me a message and I will tell where
Old 07-05-2012, 07:38 AM   #5003
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,857
We need to setup an official betting system. Everyone throws in $5 and declares what they think the issue will end up being, winner takes all (if more than one person picks the "winning" problem then the prize money gets split). Maybe Dan gets half the winnings to help fix his bike ? On second thought screw Dan lets all take a chance at proffiting from his misfortune
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 07-05-2012, 08:27 AM   #5004
Dan Alexander
Oddometer: 7,483
Bastard!
Old 07-05-2012, 09:23 AM   #5005
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,857
Bastard!
Roaming Rally 2015
Old 07-05-2012, 10:17 AM   #5006
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,857
Random cool shit
Roaming Rally 2015
Old 07-05-2012, 02:40 PM   #5007
Rider23
-<EvilTed>-
Rider23's Avatar
Oddometer: 800
I found a picture that shows Deadly can work if he has to
Even the dog found it hard to believe
The faster you go, the smoother it gets
Moab 2012
Rider23 is offline   Reply With Quote
Old 07-05-2012, 02:47 PM   #5008
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,617
Email that to his boss.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 07-05-2012, 03:10 PM   #5009
Dan Alexander
Oddometer: 7,483
I don't see the open beer .. am I missing something??
Old 07-05-2012, 03:12 PM   #5010
Dan Alexander
Oddometer: 7,483
Originally Posted by Deadly99 View Post
Who's first to try that on the bike??
Times are GMT -7.   It's 08:48 AM.
