Go Back   ADVrider > Riding > Regional forums > Canada
Old 08-26-2012, 07:29 AM   #5221
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,654
Originally Posted by Emmbeedee View Post
The seal wasn't actually leaking; it was pushed out of place which caused the leak. And chain tension was ok so I think the thicker oil is the culprit.
So, like I said: Your fault.
Maybe Dresda should consider not letting you touch her bikes for a while...
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 08-26-2012, 09:15 AM   #5222
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
You offering?
Old 08-26-2012, 11:26 AM   #5223
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,654
You offering?
I don't do house calls.
Call my people and we'll see if they can slot you in.
I think I have a time available in early November....
Old 08-26-2012, 01:36 PM   #5224
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
No thanks. At least if I do it myself, you know who to blame.
Old 08-26-2012, 02:03 PM   #5225
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,092
I thought we determined that.....
shipwrek12001 is offline   Reply With Quote
Old 08-26-2012, 02:18 PM   #5226
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
You should talk. At least I didn't wreck a countershaft bearing. That takes talent.
I was just unlucky; others use 20W50 with no problem. I couldn't predict Stephanie's seal would come out. And mine didn't, with the same oil in it.
Old 08-26-2012, 04:12 PM   #5227
shipwrek12001
Shipwrek
Oddometer: 2,092
that doesn't take talent,, thats pure neglect how I did that,,, pretty expensive too. So the bearing is on the wall of shame for a reminder...
Old 08-26-2012, 06:43 PM   #5228
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,037
Thought your wall of shame was full already ?
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 08-26-2012, 07:24 PM   #5229
shipwrek12001
Shipwrek
Oddometer: 2,092
ah-hem,,,, i have 4 walls eh!
Old 08-27-2012, 07:41 AM   #5230
mfgc2310
Oddometer: 137
20W50 - Bad!! - IMHO and experience
Exploding crankcases aside my experience is that 20W50 is to heavy - maybe 20W40 would be better choice, 10W40 is probably ideal.
I put that real expensive AMSOIL 20W50 and the KLR would blow it out the exhaust, the cheapo 10W40 castrol - no problem.
I think that 20W50 stuff is for the Harley motors that hardly turn over 3000 RPM. What looks OK pouring out the bottle, is real thick when that piston goes by in the blink of an eye.
mfgc2310 is offline   Reply With Quote
Old 08-27-2012, 07:51 AM   #5231
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,037
Totally depends on which tires you are using
Roaming Rally 2015
Old 08-27-2012, 08:37 AM   #5232
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
I agree, with the benefit of hindsight. 10W40 is back in both bikes.
Old 08-27-2012, 09:07 AM   #5233
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,499
Totally depends on which flux capacitor you're running, and the condition of the Johnson rod....
P.S. check the crankcase breather vent...a know issues with DR's, if it gets blocked will blow out counter shaft seal.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames screwed with this post 08-27-2012 at 09:24 AM
juames is offline   Reply With Quote
Old 08-27-2012, 09:51 AM   #5234
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,037
Originally Posted by juames View Post
and the condition of the Johnson rod.....
Roaming Rally 2015
Old 08-27-2012, 02:49 PM   #5235
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Finally got around to checking the F8 charging problem and the stator is toast. Oh well, that is the first thing we've ever had go wrong on the F650/800 bikes aside from expendables like steering head bearings, etc.
Sure glad I still have a DR to ride.
Times are GMT -7.   It's 12:07 PM.
