Go Back   ADVrider > Riding > Regional forums > Canada
Old 04-05-2014, 05:02 PM   #7936
Keating
pre-n00b
Oddometer: 187
Well fuck.
So punched almost 4k on my KLR last season.
OGTC said oil was fresh when I picked it up. Looked nice and clear in the eyeball, so I didn't think twice.
Today when getting the bike ready to roll, I started it up, ran as far as the corner gas station, dumped in some seafoam and filled with premium (ethanol free).
Ride home, did the ole "loosen the oil filter cover bolts, and fire up bike" trick to pressurize and loosen the cover. No problem there.
Removed the plug and drains the oil.
Popped the filter cover off and removed the filter.
Went to remove the tube from the KLR filter. No tube.
Hmm... Doesn't seem like you could put a tube in there.
Compare to new filter. Completely different.
Filter is stamped HF145.
Look up HiFlo part # for KLR... HF123.
No KLR in the bike list for the HF145.
So I've put nearly 4k on the bike with marginal to no filtering and I can't install a proper filter because the required part (filter bypass valve tube) is missing.
Wondering who to punch...
The wife is still a little freaked by the whole thing but what ya gonna do? Stay at home and die in your sleep? - laramie LC4
'04 KLR650
Keating is offline   Reply With Quote
Old 04-05-2014, 05:23 PM   #7937
Berger
Berger's Avatar
Oddometer: 694
Did OGTC do the oil change? Contact them.
Sent from my Nexus 4 using Tapatalk
2014 Triumph Tiger XC
2007 Ural Patrol w/ mods
http://advrider.com/forums/showthread.php?t=723916
Berger is offline   Reply With Quote
Old 04-05-2014, 05:56 PM   #7938
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
Hmm... Doesn't seem like you could put a tube in there. So I've put nearly 4k on the bike with marginal to no filtering and I can't install a proper filter because the required part (filter bypass valve tube) is missing.
Hmm, not a good sign.
Not an expensive part to replace but you have to wonder: aside from the wear it might have had on it without filtration, what else has someone butchered?
The assembly's only $12.62 at Cheap Cycle Parts.
Old 04-05-2014, 06:00 PM   #7939
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,494
OGTC doesn't inspire my confidence. Dropped the bike off this am to have the fuel pump warranty recall checked out and to have the service light clear and codes checked.
On a plus note I will be getting a new fuel pump, though I suspect there is nothing wrong with the one in the bike.
On a negative note I was clear about wanting them to confirm the battery and starter were both good and tell me if there was any codes when they hooked it up to the computer. I explained that the bike would turn over slow then fire and I suspected the battery but wanted to confirm the starter before my warranty expired. Went back to pick up the bike and asked the service guy about this and he hadn't confirmed with the tech who was now gone for the day. It's not like it was a complex request and as I'll be paying to have them clear the service light I'd sure like to know if there were any codes.
BTW can anyone confirm if the service light comes on every 10k or annually?
CanadianX is offline   Reply With Quote
Old 04-05-2014, 06:02 PM   #7940
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
What make/model of bike? Our F BMWs only lit up at every 10,000kms.
Although your avatar shows a KTM and I've seen your 690, I can't believe anyone would take a KTM to them.
Old 04-05-2014, 06:04 PM   #7941
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,494
09 GSA, I'm thinking every 10k. Had the 30k done last year at 28k and suspect they didn't reset it for 40k so at 30k it came on.
Old 04-05-2014, 06:09 PM   #7942
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
No, the light probably went on because you hit 30,000. It's set to go off at the factory service intervals so you can't clear a code before it hits the marker. Clearing it at 28 won't stop the reminder light showing at 30,000.
Old 04-05-2014, 07:03 PM   #7943
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,395
My 07 gsa has no service warning light.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 04-05-2014, 07:05 PM   #7944
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
You're not resetting it with GS911 are you?
Or maybe BMW wasn't using the reminder on the early 1200s. But it was certainly there on our Fs in '08-'09.
Emmbeedee screwed with this post 04-05-2014 at 07:21 PM
Old 04-06-2014, 04:43 AM   #7945
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,494
Ah. Makes sense. I think I need a GS-911 in my tool box all the same so I can read and clear codes and clear the service light.
Old 04-06-2014, 06:10 AM   #7946
Berger
Berger's Avatar
Oddometer: 694
Do you guys void warranty if you clear them yourselves? I am going to go through this with the Triumph eventually, but I bought the proper OBDII connector.
Old 04-06-2014, 07:18 AM   #7947
Keating
pre-n00b
Oddometer: 187
That was certainly the implication.
'04 KLR650
Old 04-06-2014, 07:37 AM   #7948
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,762
It's warming up by the hour...a couple of more hours and it'll be time for my first real ride of the year
FU winter!
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 04-06-2014, 07:47 AM   #7949
Keating
pre-n00b
Oddometer: 187
Thanks Mike, I was fixated on the wear that may have occurred...I hadn't even gone to the "what else is butchered" ponderance...
On the upside, the bike still doesn't burn a stain of oil, which seems to be an outlier case for a KLR in general. so I'm guessing valve seals, rings, etc, are still in good shape.
bBig bearings are a scary thought. The KLR right side exhaust bearing lubrication is questionable, in good condition. The small brass tube feeding it tends to clog and coke up with heat...
I'm going to go short on this next interval. 500km or less. If it weren't for concern of the wet clutch, I'd throw in some 30w detergent oil, or a few glugs of ATF to wash things out.
I'm putting in 5w40 Rotella T6 Synth. ($23 a gallon from ogdensburg, I don't feel like I'm wasting money).
Hopefully the low cold viscosity will get get through everywhere it needs to be.
I'm going to take the old and new filters into OGTC tomorrow. I'm sure I'm not going to get much out of them, in lieu of "possible" damage, but I'm sure going to try to get the oil filter tub assembly out of them.
I'm mostly just pissed I can't ride, at this point.
'04 KLR650
Old 04-06-2014, 07:50 AM   #7950
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,762
The outcome of your visit is, sadly, predictable.
Why, why, why do people bring their bikes there...it very rarely ends up well for the customer.
Roaming Rally 2015
Times are GMT -7.   It's 02:02 AM.
