01-31-2009, 10:32 AM
#31 | |
Turn'n Valves
Oddometer: 492
.I punched in your google search term "adjust wheel bearing preload airhead" and didn't see snowbums article in the first page of returns. As someone who is looking for advice during some major wrench'n, I feel his pain when trying to tease out that one description that clicks. Anyway... Thanks for the info but go easy when others don't see what you think is obvious.
Slope'r '94 R100GS/PD '06 F650GSL |
01-31-2009, 01:39 PM
#32 |
G(/)S ... what else!
No offense or flaming intended, just a bit of black humour mixed with some eye-rolling. As I said, Mr. Google knows everything but I admit you need to be able to prescind and talk "machine", let him know what you want, know the key- or buzzwords.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net StephenB screwed with this post 01-31-2009 at 02:30 PM |
02-01-2009, 11:14 AM
#33 | |
Oddometer: 97
Thank you everyone for your inputs... but it looks like it may be time to let this thread die, and for me to PM some of the responders that appear to have performed this procedure on their own before... (minus the "space-shuttle-launching" level of detail)... Good riding to everyone! |
02-01-2009, 09:20 PM
#34 |
Oddometer: 2,051
So - preload torque is aboUt 1 ft - just about the thick end of , err, all play removed.
And dont forget to keep spinning the wheel as you tighten the nut on the end of the spindle - if the bearing tightens up you need a new spacer.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST |
02-02-2009, 12:01 AM
#35 | |
Onward through the fog...
Oddometer: 1,395
I checked some of my old Harley manuals for models that use the same tapered wheel bearings as Airheads, and on some older models they specify a bearing end clearance of .002" to .015". That is right, all clearance, no preload. Which of course will have the BMW string and spring gauge brigade shrieking with horror, but Harleys are not known for chewing out wheel bearings as long as the grease is changed with every tire change. Sometimes I think BMW just think too much and look for complex elegant solutions where brute force and ignorance would actually suffice, in the Harley Davidson manner. Also, if you rebuild your wheel with new SKF bearings, properly seated by heating the hub before installation, there is about a 90 per cent chance the original spacer will give the correct preload on the new bearings. The tolerances in the manufacture of the bearings is so small there is very very little variation from one bearing to another when new. The variable size spacer is mostly to compensate for variations in the machining of the hub, not the bearings, and the hub does not change after it has been machined, unless a bearing outer race spins and chews it up.
'77 Harley Ironhead 6,000 miles across Oz http://advrider.com/forums/showthread.php?t=527966 Reryder (AKA Hopper) 1977 Harley Sportster 81 BMWR100RS 01 HONDA VFR800 99 SV650 Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler Reryder screwed with this post 02-02-2009 at 01:14 AM |
02-02-2009, 01:08 AM
#36 | |
Oddometer: 1,113
I've done it myself. I used a micrometer to measure the "wedding band" and I made a spacer to fit over the axle so I could do the job without fitting the wheel in the forks. Otherwise, no special tools. I fitted the new bearings into the hub with the spacer and the wedding band between the inner races and then slid my tubular spacer onto the axle and the wheel nut and washer tightened up onto the spacer. This was all done on a benchtop, not on the bike so I could feel the play better. There was too much play so the wedding band was too thick. I filed it down carefully using the micrometer to check it was even all round. I reduced it by half thou increments until the play had all gone. That's it. You may be better off buying a selection of wedding bands from your local BM shop, it saves some filing and ensures you don't mess up and have a wedge shaped wedding band that will destroy your new bearings quicker than you can blink. |
02-02-2009, 06:20 AM
#37 | |
Beemerholics Anonymous
Oddometer: 7,354
Some jobs are best left up to someone knowledgeable and trained, rather than attempting it oneself, and perhaps that's the case here. It might be best connecting up to some airheads in your area and, perhaps during a tech day, have someone go through the procedure with you. That graph also took me a little while to interpret - it's not laid out normally so can confuse. But the data is all there. As was said already, bearing life is the max with a little preload. As with most things, there's a downside to having no preload, even though that makes it easier setting up the bearings. The downside is possible handling issues such as "THE WOBBLES". I've had them before and don't ever intend to again.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
