01-25-2009, 05:23 PM
#1 |
Oddometer: 1,440
Tire puncture
Hey guys,
I just bought a new rear Tourrance tire and subsequently rode over a roofing nail which hit perfectly in center tire. My question; can this tire be patched with a plug at a shop and used without concern, or am I screwed or "nailed" for the cost of a new tire? THANKS! |
01-25-2009, 05:25 PM
#2 |
Oddometer: 893
I'd throw a plug in it an ride, but that's just me.
01-25-2009, 05:27 PM
#3 |
ride till you puke
Oddometer: 416
My skin is worth another tire, but that is just me.
01-25-2009, 05:33 PM
#4 |
Registered User
Oddometer: 25,012
You can plug it, but the safest repair would be a thick patch on the inside, and you can find patches made for this purpose at most any auto parts store.
I'm lazy and would just pulg it with a snot string and ride. |
01-25-2009, 05:34 PM
#5 |
Red Clay Halo
Oddometer: 11,213
I use a string plug when on the road, but when I get home I yank it, and put a patch/plug in its place.
![]() You usually can buy patch/plugs at some autoparts stores. I also buy vulcanizing cement and use it as well. I like the patch plug because after a few heat cycles the patch bonds completely with the tire, and the plug blocks the hole so rocks and crap can't get jamed back into the tire.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
01-26-2009, 08:30 AM
#6 |
Oddometer: 179
Tire Plug
Had 500 miles on my rear Metzler and found a nail dead center in tread groove. Took the wheel off and took it to Midas or Meineke and they put a string plug in it and told me not to tell anyone due to liabilty. Have been meaning to dismount the tire and put on a proper vulcan patch from the inside but now I have an additional 4,000 miles on it and am just waiting to run it out and replace it in do time. My first 1 or 2 hundred miles I was worried and every bump and clunk I thought it was my rear going flat but 6 months and 4000 miles later it is still holding air and running strong.
01-26-2009, 08:34 AM
#7 | |
Fattest thin man
Oddometer: 3,461
Az
"Write a wise saying and your name will live forever" - Anonymous |
01-26-2009, 12:12 PM
#8 |
Oddometer: 689
Unless you're taking the bike to the track plug it and go...
Nate Ocean Spring, MS 2008 Honda GL1800 2007 Honda CRF150R 2005 Honda CRF100F |
01-26-2009, 01:06 PM
#9 | |
Red Clay Halo
Oddometer: 11,213
I guess what bothers me about string plugs, is that even after 1000 miles of road travel (I picked up a nail on my way to BYOB 08), I could still grab the plug from the inside of the tire with pliers and pull it out with little effort.
01-26-2009, 03:02 PM
#10 | |
Oddometer: 1,440
I will try to do the vulcanization plug from the inside and see... Thanks for all the input and experience; I can't believe this is my first flat after 80K+ miles! |
01-28-2009, 02:30 PM
#11 | |
GPoET&P
Oddometer: 3,760
I figure the odds of the string failing are much less than the odds of picking up another nail. Has anyone ever had a string fail? |
01-28-2009, 02:46 PM
#12 | |
Red Clay Halo
Oddometer: 11,213
Both of those failures were on performance street tires. Both tire carcasses seemed to be thin compared to the chunky tourances I've got on my bike.
01-28-2009, 04:13 PM
#13 | |
Oddometer: 3,325
As long as you keep people out of your tire, you should be OK
If I wasn't here, I'd be somewhere else |
01-28-2009, 04:37 PM
#14 | |
Registered User
Oddometer: 25,012
01-28-2009, 04:38 PM
#15 |
Registered User
Oddometer: 25,012
When using snot plugs, remember to cut the string flush with the tire surface.
