01-26-2009, 06:45 PM
#1 |
Broken Roadie
Oddometer: 2,784
New 800GS - 200 miles = broken chain
In the middle of a extended adventure on my R while 2400 miles from home I picked up a 8GS and took it out for a proper fist day of dirty riding....
After riding 200 miles my chain had loosened up greatly, going from properly tight to 4+ inches of play. Kind of weird but since I've been blessed with no chain for years I didn't think much of it. The next day I went back to A+S to sort out some other stuff... anyways they tightened the chain up for me and I set off. I stopped for gas, pulled out, nailed the gas, and BAM! the chain broke. ![]() Lucky for me I was on the way to Ted from A+S's house and he came and picked me up with a trailer. My bikes there and will be fixed tomorrow. Slightly annoying, but shit happens and I'm just glad it didn't happen in a few day when I'm in Death Valley, or next week in Baja, and A+S is all over it. Any thoughts? New chains don't break right? Did I just get a defective one? ![]()
A Roadie in Motion LostRider.com Come to Southern California for a Lost Rider Fly and Ride Adventure! Lost Rider screwed with this post 04-27-2009 at 07:37 PM |
01-26-2009, 06:54 PM
#2 |
Bronze Age Fall Guy
Oddometer: 5,115
That is pretty scary. Glad you are alright.
Hate gets you nowhere. |
01-26-2009, 07:13 PM
#3 |
Mad Scientist
Oddometer: 3,155
What brand is it? Broken plates, or did a rivet work loose?
01-26-2009, 07:19 PM
#4 | |
Broken Roadie
Oddometer: 2,784
sorry no pic of the broken part
01-26-2009, 07:25 PM
#5 | |
Ridin'
Oddometer: 750
I read a report on UKGSer about a similar incident but not with that low of miles. You aren't even due for the first chain lube. I would like to see the broken links.I think it has a Czech made chain. let use know what A&S says. EDIT-wonder if the wheel was misaligned and a tooth cut through the plate
01-26-2009, 08:01 PM
#6 |
There's a final drive joke in there somewhere.
Sorry 'bout that man. Was anything else busted when the chain went? They have a nasty habit of breaking more stuff when they go, and occasionally take out the rider. Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here. Budget Travel the Jamie Z Way |
01-26-2009, 08:11 PM
#7 | |
Nation of Frustration
Oddometer: 9,243
I was going there, but... ahh shucks... why not. Can't BMW make any drive systems that don't fail?
The soul attracts that which it secretly harbors; that which it loves, and also that which it fears. James Allen |
01-26-2009, 08:58 PM
#8 | |
Motociclista Errante
Oddometer: 2,242
![]() Gustavo |
01-27-2009, 06:49 AM
#9 |
Ridin'
Oddometer: 750
For what its worth, I looked at my 800gs chain and its a CZ brand 525 BDZ chain.
I found the CZ chain specs but it doesnt show the BDZ type. CZ specs only shows 525 SDZ type. I wanted to compare specs for a DID chain, but no luck. The CZ website specs show "breaking load" and not "tensile stregnth" CZ motorcycle chain specs here: http://www.czretezy.cz/produkty_a/se...alog_as602.php DID specs here http://www.didchain.com/specs.htm |
01-27-2009, 07:19 AM
#10 |
Just a thought , but the first day you rode it and noticed it had 4" of play( not normal) but continued to ride...you think that may have caused excellerated wear and stress on the plates. Then when it was tightened up , the metal was already fatigued and it just snapped!. I've got a F800Gs and i'm really conciencious about checking the play in the chain( especially if I hear a lot of "chain slap" on offroad use. 3500miles and still on first chain!
( now watch..tomorrow on the way to work my chain will break!!:) Glad it happened where it did. Good Luck Marc |
01-27-2009, 07:22 AM
#11 |
anybody know whats the recommended mileage on these chains before you should changes them?
Marc |
01-27-2009, 07:35 AM
#12 | |
Lazy
Oddometer: 38
01-27-2009, 07:40 AM
#13 |
In a parallel world
Oddometer: 800
This chain probably had a manufacturing defect. Running them slack shouldn't stress a chain, just increase the odds of it jumping the sprocket. Running them tight is much more likely to cause a failure of either the chain or the countershaft seal. Chains should be slack enough at rest that there is still some play when the rear sruspension is fully compressed (unless you have a G450X with co-located countershaft and swingarm pivot centers).
Chain life depends on use and maintenance. A good quality, well-maintained (cleaned/lubed/adjusted) chain will go 20k miles or more if ridden on the street. Taking them in the dirt/mud/swamp/dunes will shorten their life, especially if they aren't cleaned and lubed afterward. 200 miles is a ridiculously short life, hence my diagnosis of defect. I'd say it's a warranty issue with BMW. |
01-27-2009, 08:51 AM
#14 |
Oddometer: 2,039
I am talking only o-ring chains below. I never purchase non-o-ring chains.
I agree with Bucko, but I also have an "anal" gene". I generally replace the chain and rear sprocket on my road burners (Ducati 998 and YZF1000) at 12K miles, but these are high horsepower bikes. On my dirt bikes I will typically go a "season" (one year of use) on a chain and rear sprocket. A year of use on the dirt bikes is probably around 3000 miles. I intend to replace the chain and sprocket on the F8 annually, maybe 7k-10k miles. I would never replace a chain without replacing the rear sprocket with the exception of the Ironman sprockets which seem to last through a couple of chains. Any aluminum sprockets, although a weight saver, are taboo IMO. I have never broken a chain in over 30 years of riding, so I have to believe it is rare. I tend to avoid the so-called case savers which are touted for some bikes because it is easier for a rock to get jammed in there and do more damage than would have occurred without the case saver. I have had chains come off several times when riding in deep ruts which push the chain guide inward, and the chain slips off the rear sprocket.
my favorite bike - R1200GS |
01-27-2009, 08:56 AM
#15 |
Broken Roadie
Oddometer: 2,784
not sure what the other broken part looks like, it's all caught up...
