02-08-2009, 09:51 AM
#46 | ||
I remain calm
Oddometer: 20
02-08-2009, 10:11 PM
#47 | |
Oddometer: 354
tire changing
1. Start the tire removal process at the valve stem (or the rim lock if it has one) 2. Finish the tire installation process at the valve stem. The reason for doing it this way is so the bead can drop into the center well of the rim and have maximum slack. If the valve stem is in the way...
Dan It's never too late to have a happy childhood. -- Tom Robbins How I spent my summer vacation - Alaska 09 BMW F800GS 99 KLR 650 A13 |
02-09-2009, 11:01 AM
#48 |
Oddometer: 53
other care package items
Before this thread turns into a tire changing lesson. Some other care package items it have carried over the years in whatever bike I was riding at the time:
1. Assortment of zip ties. 2. Spare fuses. 3. Assorment of nuts and bolts (bike specific). 4. Small Rag (usually wrapped around the tools). Nice not to put greasy hands into your riding gloves. 5. Electrical tape, and duct tape on long trips. These may be more general kit items and not so F8 specific, but sometimes the obvious gets overlooked. I heard about the key ring issue and thought that it could be changed on the road?? maybe not so easy as first thought. Also, the sacrificial plastic radiator holder/mount. It is relatively cheap$ and it designed to break away in a crash to help save the rad from damage. But, once it is broken, it may be hard to rig up some way to support the rad. Sooo, the actual replacement part will be part of my kit. |
02-09-2009, 02:09 PM
#49 | |
Oddometer: 204
I think it's safe to say that some safety wire or creative zip tie engineering will get you home if you break the mounts and are still holding water, which was the case with mine. I didn't even know I had broken the mounts until I washed it the next day. Everything stayed in place for the most part. BTW ... I had to wait for mine to come from Germany when I ordered it because there were none in the US so I ordered 4 extra. I don't know if that's still the case. They're at my Farkle Fab site if anyone needs one in a pinch.
2000 KTM 300exc |
02-10-2009, 03:33 PM
#50 |
NoMoTDM still Gary
Oddometer: 3,709
A good mod that I think to make, is a 2 prong electric plug connected directly to the battery using heavy gauge wire. Mine exits near the steering head and I use it for the GPS, electric vest, airpump, margurita mixer, etc, as needed. Most importanly a set of jumper cables with like wire and plug along with alligator clips.
