| Welcome, lurker! Even if you don't post, the system can help you find the good stuff faster if you register. |
#46 | |
Polishing Turds
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 3,899
The what now?
How the hell did you get all this together? It just happened, Max, you know? A p-p-p-p-piece from here and a p-p-p-piece from there. |
#47 | |
Catastrophiser
Oddometer: 469
gold mate |
#48 | |
Oddometer: 198
Based on the measurements that I took on my shaft with 15,000 miles the wear on the oil side was definitely less than the wear on the coolant side.
2009 BMW F800GS 2008 KTM 250 xcfw 2005 KTM 450 exc 1957 IZH www.FarkleFab.com F800GS & F650GS heavy duty skid plate and crash bars!!! |
#49 |
Orange Caveman
Oddometer: 5,967
Here's one with 69+ k miles
Definately wears more on the coolant side.
![]() Thats the side where the casting sand is: ![]()
![]() -cp DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt. |
#50 |
Oddometer: 670
Auto parts stores have waterpump lubs for about three bucks . Anyone tryed that ?
Have you used your cryogenic w.p. shaft yet ?
"The more you drive the less intelligent you are !" Repo Man - 1984 |
#51 | |
Oddometer: 1,295
nikasil
I think nikasil has a bit of tooth - seal will go away. I tried to get some help from a local company "Nanosteel" they have a treatment that's glass like but they ignored me. Someone was going to try TiN - did that happen? |
#52 | |
What Snow?
Oddometer: 2,451
I just picked 17-4 stainless, b/c I work w/ it often in Aerospace stuff, and I can get it. Won't rust, machinable and I can get a good surface finish w/o grinding. I made a shaft for my wife's 99 F650 BMW. It has about 10,000 miles on it and still going strong. I've not pulled it apart for an update check, but it's not leaking yet. Similar setup to the LC8. I should have material middle of this week, maybe I can get started on the spacer plate w/in a week once I source bearings and seals, and finalize the shaft design.
My 2006 950S thread. ![]() 2008 950s update 2000 LC4 640e, 2000 Quota, 99 650 Had 03' 525SX, 93' RM 125, 87' kawi Vulcan 1500, 83' XL500 Links. 950/990 tail rack SE, SM, ADV, 950/ 990 SAS plates, LC8 Clutch cover(see through), Magura Clutch coolers, Rekluse Clutch, LC4 Tail Rack, Footpegs, KTM Axle Pusher Find new product updates here! click www.cjdesignsllc.com for the full line of products. |
#53 |
erider
Oddometer: 479
Waterpump shaft ...
Hey CJ -
Code:
17-4 stainless is soft - and will not provide the required hardness for the seal journal. The waterpump seal is a thermo-plastic rubber compound and, unless the 17-4 is 'Malcomized' (case hardening process for stainless) the seal will abrade the shaft quickly. Better alternative would be D2 - and then thru-hardened to Rc 54-56. D2 contains 10-11% nominal chrome and will provide good corrosive attribute. |
#54 | |
What Snow?
Oddometer: 2,451
It would be thru-hardened, ~60Rc, sorry I didn't add that info. So ya, I'd have to grind it after. I guess it's too early yet for this much thinking. Lot of work left to do yet.
#55 |
Talks more than he rides
Oddometer: 979
what about cryo-treating the shaft?
Problem about cryo is that it has to be done in batches to keep it economical, but it definitely would add some extra strength to whatever metal you choose. Send your kichen knifes and brake rotors along to make it worth the effort, I guess
2004 KTM 950 Adventure S |
#56 |
Oddometer: 123
To make Spacerplate and waterpassage holes sealed there might be a solution to use 2 separate o-rings instead of one paperseal. There is only four bolts keeping installation together, i assume that proper thicknes o-ring give much reliable sealing effect because against rising pressure due to nature of of the ring sealment. (damn this is difficult to put in english).
Paperseal requires much more even pressure betveen holding points and there are only four bolts in wp cover. This what i think but i might be completely wrong, I am no pro in this matter. Nice addition to your machined products Cj, would be clutch slavecylinder piston made out duraluminum etc. just my little wishes.
a-- KTM Adv 950 05 Honda Nt 700v Deauville 07 |
#57 | |
What Snow?
Oddometer: 2,451
I hate paper seals. I use o-rings for sealing when needed and so will this.
#58 |
What Snow?
Oddometer: 2,451
No turning back now.
![]() Ready to make some chips. ![]() Before: ![]() After: ![]()
#59 |
What Snow?
Oddometer: 2,451
Cut an adaptor plate this weekend. It's a bit thicker than I hoped for, but it holds a double sealed bearing and "2" oil seals for 2X the sealing surface. I'm going to test fit it tonight to see if it fits behind the header.
If this works next up is to make a shaft. If this is too thick than it should work on a SE or SM 950 b/c the header is routed differantly. Then I'll need to get some thicker stock and make a new version. I'll re cut the stock case to remove the rest of the bearing and seal area. This will be incorporated into the new adaptor plate. There is only so much stock that can be safely removed from the stock cover to thing inward. Adaptor plate, w/ weep slot. ![]() ![]() ![]()
#60 |
Lost again
Oddometer: 2,486
nice bling dood, looking forward to good results
FREE OOBAH I'm smilling..........that alone should scare you ONTARIO ADVENTURE RIDERS Jeep resto 101
