Old 01-29-2009, 09:11 PM   #1
Spicy McHaggis OP
Darth Peach's cracker...
Spicy McHaggis's Avatar
Oddometer: 3,789
Eh? Ural tire question...why not use what the Beemers use???
Okay so one of the complaints from us Ural riders is tires are either very expensive, too cheap, or hard to find.
So I'm thinking...what do the guys with the 1200GSA's with hacks do for THEIR tires on the tug? Looking at some pics, I'd say they ride with what they usually use.
So...why not do the same for the Ural?
Someone on Soviet Steeds found the Michelin Anakee in 100/90-19 57 H. I believe that is the same size (roughly) as the stock 4.00-19 tires that are on my GearUp now. The 57 H refers to the rated weight (507#/130mph). I just found the TKC80 in a 100/90-19 57 S. Heck, I just found a bunch of dual sport tires that I see the Beemer dudes ridin' with.
How much does a freakin' 1200GSA with a sidecar weigh? Looks like a 2007 GSA is about 560# wet. Add in a sidecar and frame and maybe add 150-200# back into the equation, bringing the total dry weight to around 700-750#. The Ural's total dry weight is about 740#.
We know the Beemer can go faster than the Ural, so the speed rating shouldn't be an issue...right? Would it just be the weight that would be the issue?
So...why can't I use tires for the Beemer on the Ural?
Thoughts?
Spicy
Spicy McHaggis is offline   Reply With Quote
Old 01-30-2009, 04:34 AM   #2
kliff
Retired Ole Phart
kliff's Avatar
Oddometer: 1,119
Use what you want. Your research has revealled some excellent candidates.
Why follow the pack?
kliff
NASRA / MAXX Racing
http://nasra.proboards.com/index.cgi
Scooter Rebels
http://scooterrebels.proboards.com/index.cgi
49cc Scoot
http://49ccscoot.com/
Peace, Eagle, as long as it's a BASHAN, it's cool with me!
kliff is offline   Reply With Quote
Old 01-30-2009, 07:56 AM   #3
heindlengineeringura
svman00
heindlengineeringura's Avatar
Oddometer: 126
It all has to do with load rating and liability issues.
The ural has a Gross Vehicle rating of 1340 lbs, divide that by 2 if you are flying the chair, gives you 670 lbs. So if you don't overload your rig, then you need a tire that is rated for at least 670 lbs.
That being said, a lot of folks will run whatever they want. When it comes to selling a tire, a dealer will sell you whatever tire you want, but when it comes to mounting, that is another story. Liability if they know it is going on a sidecar rig.
We are in the process of resolving tire supply issues for both the Duro and the Heidenau Tires. We just keep working to this and hopefully it will be better soon.
Heindl Engineering, LLC
Ural Dealer in SouthWest Ohio
(937) 787-3686
Heidenau Tires
http://www.heindlengineering.com/Onl...enau_tires.htm
sales@heindlengineering.com
heindlengineeringura is offline   Reply With Quote
Old 01-30-2009, 03:59 PM   #4
Mully
Kineticist
Mully's Avatar
Oddometer: 3,766
Originally Posted by Spicy McHaggis
(snip)
Thoughts?
Spicy
1. The Anakees and TKCs are radials and designed to run tubeless. Ural wheels are spoked and can't be run tubeless, so you'd have to put a tube in a tubeless tire: the radial's characteristic sidewall flexing with a tube installed would create friction between the tube and carcass that could lead to tube failure - not a good thing.
2. There is very little clearance between the pusher tire and the driveshaft on a Ural; probably would have interference. (saw a Kenda 335 last weekend that was rubbing the shaft)
Other than that, run anything you can get on the rim.
mully
"If crime fighters fight crime, and firefighters fight fires....what do Freedom Fighters fight?" - George Carlin
Mully is offline   Reply With Quote
Old 01-30-2009, 06:17 PM   #5
Ivan Rider
Ivan Rider's Avatar
Oddometer: 611
I have been using the same tires on my Ural that I used on my BMW Airhead for years. Avon 400x18 SM MK II. They get 2 times the milage as the Uralshina tire. I had to convert the Ural to 18" wheels to do so but now Avon makes a 400x19 that I'm trying on my New GearUp.
'78 BMW R100/Ural sidecar, '99 Ural Patrol
'03 BMW R1200CLC Solo & Ural sidecar Rig
'06 Honda Big Ruckus Solo & Sidecar Rig,
'08 Ural Retro, '10 Ural ST Solo
http://www.flickr.com/photo s/ivanrider/
Ivan Rider is offline   Reply With Quote
Old 01-31-2009, 08:38 AM   #6
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,708
+1
+1 on the Avon
Yep we have the 19' Avons on ours too. They seem to be lasting a lot longer. We have about 2,500 ks on them and the rear pusher looks great.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Times are GMT -7.   It's 12:05 AM.
