Old 01-24-2010, 10:05 PM   #226
Southest US Thumper
Extreme n00b
Southest US Thumper's Avatar
Location: As Far South and West as you can get in the USA
Oddometer: 2,099
Originally Posted by calrider
A little ride yesterday. Hard to believe I live in a city of a million people and stuff like this exists just outside of the city with nobody else around. What are people doing??
Never owned a XR250 or 400 so not sure why I'm here... But that is a sweet picture!!!
It's the Most F5orite Time of the Year!!!
Southest US Thumper is offline   Reply With Quote
Old 01-24-2010, 10:34 PM   #227
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
@calrider :
What you should have done is the bolt itself. Notice how the swing arm bolt is hollow. You drill three small holes , two where your swing arm bearings are and one in the middle where it goes threw your engine case. Tap and plug one end and zerk the other. Then when you load it up with grease you will hit the swing arm bearings and the critical spot where it seizes , the middle of the engine case.
Like this :
Here are some (blurry) pics from a TT user doing the mod.
(thx prwler)
03 Honda XR250R
r00t4rd3d screwed with this post 01-26-2010 at 04:13 AM
r00t4rd3d is offline   Reply With Quote
Old 01-25-2010, 07:24 AM   #228
tri650
Oddometer: 382
Just joined the xr250 club
Just bought a 03 xr250r last night. One owner bike and in very good condition. I took it for a test ride and was suprised at how light it felt - and adequate power. I have seen a few with the baja designs kit so may make it street legal. Bike will get light trail use and doinking around my house. Look forward to watching this thread for any tips, suggestions, etc. I will post a pic soon.
tri650 is offline   Reply With Quote
Old 01-25-2010, 11:08 PM   #229
calrider
I'm Lost Too!!
calrider's Avatar
Oddometer: 692
Originally Posted by r00t4rd3d
@calrider :
What you should have done is the bolt itself. Notice how the swing arm bolt is hollow. You drill three small holes , two where your swing arm bearings are and one in the middle where it goes threw your engine case. Tap and plug one end and zerk the other. The when you load it up with grease you will hit the swing arm bearings and the critical spot where it seizes , the middle of the engine case.
Like this :
Dohh! thanks r00t4rd3d. I don't remember mine being hollow, but I'll definitely take a look at it next time I'm down at my friend's shop. Nice elegant solution.
calrider is offline   Reply With Quote
Old 01-26-2010, 12:20 AM   #230
sixer OP
I suffer from Ainrofilac
Oddometer: 1,220
I'm glad to see this thread is alive. Sadly my XR is for sale. Replaced it with a tw200
"There are no such things as accidents—just two people competing for the same point on the space-time continuum."
Support your local Search and Rescue Teams.
sixer is offline   Reply With Quote
Old 01-27-2010, 05:20 AM   #231
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Anyone have a picture of a 250's stator , the front and back with a good shot of the wire connections on the stator ?
03 Honda XR250R
Old 01-28-2010, 04:09 PM   #232
TaZ9
Happy Adventurer
Oddometer: 278
XR250L swingarm
I have a pristine '92 XR250L and the swingarm comes standard with multiple Zerk fittings. Not sure it it would fit the post '96 XR250R's, but it might be worth checking into.
After reading all the horror stories about seized swingarm pivots, I decided to bite the bullet and try taking mine apart.
Got the bike up on a stand and then loosened the nut. Thankfully it moved. And even better, once it was backed off the swingarm a touch, it turned the bolt. Definitely a good sign. If the bolt's turning, then chances are it isn't badly seized.
So I got the nut off and the next step was to try moving the bolt out with a few sharp hammer taps on the end of the bolt through a brass drift pin. It MOVED! It was no problem getting it out.
So I loosened all the various bolts and pulled out the swingarm and suspension linkage and gave everything a good greasing. I also decided to put grease nipples into the swingarm pivot points.
The first step was to use a centre punch to mark where I'd be drilling:
You can see the two little centre punch marks on the pivot points.
Once the holes were drilled, it was time to tap them for the grease nipples.
The tap on the right is in the first hole I tapped so that I could eyeball and line up the second one with the first one.
Once the holes were tapped, I thoroughly cleaned out the aluminum shavings from the insde of the pivots.
A bit of blue loctite on the nipple:
And there they are, ready to make life easier for me:
Then I greased everything and put it back together again:
There you can see the fitting on the right side of the swingarm. My buddy Doug who's shop I'm using didn’t have any 90 degree grease nipples, but I'll probably replace these with 90 degree nipples at some point so it's easier to get a grease gun on them.
TaZ9 is offline   Reply With Quote
Old 01-28-2010, 08:56 PM   #233
calrider
I'm Lost Too!!
calrider's Avatar
Oddometer: 692
Yeah, the older XR250's had zerks. Seems odd that they eliminated them.
Old 01-29-2010, 07:22 AM   #234
tri650
Oddometer: 382
Tire choices
New 03 xr250r owner. Need to replace the tires. Looking for something that is a 50/50 tire. Have used TKC80's in past and like them. Cant seem to find the size to match what is on the bike. Any suggestions on what will fit that I can also ride on the street? Thanks.
Old 01-30-2010, 05:15 PM   #235
fiep
fiep's Avatar
Oddometer: 1,909
had my XR250RW since 2'98
the only thing original on it is the owner
haven't ridden her in a while
just recently aquired a 91 XR250L
one owner, original 3183mi, still had the original tires
since I am to lazy to read my way thru 100 web pages:
can you please help me uncork the poor thing?
it is bone stock
even to the original smog block
the poo'lil bike says 'thanks'
fiep is offline   Reply With Quote
Old 01-30-2010, 05:18 PM   #236
fiep
fiep's Avatar
Oddometer: 1,909
the dreaded Kenda 270 seems to be a fairly good choice for a light and mild bike like the XR250
put one on my 250L and anticipated all the bad behaviour people complained about in the Kenda 270 thread here
nothing bad happend during my first 200 miles on&off
Old 01-30-2010, 05:48 PM   #237
fiep
fiep's Avatar
Oddometer: 1,909
my 'little one' in action
after she turned blue
and my "(little) two" the first time out together
Old 01-30-2010, 06:56 PM   #238
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
fiep you want to read this for the uncorking :
http://www.thumpertalk.com/forum/showthread.php?t=37645
03 Honda XR250R
Old 01-30-2010, 08:05 PM   #239
midengineracer
Lost, with a GPS
Oddometer: 1,293
it is bone stock
Try 3 pages. The Ramsey mods. Here is a link to but one of the many locations it is available online. If you don't like this one, google "ramsey mods" and you can find it on other sites.
http://www.4strokes.com/tech/honda/mod25rl1.asp
Thomas
2007 Husqvarna TE250 (Athena 300 kit)
2010 Triumph Scrambler
2010 H-D XR1200
Originally Posted by 685
The best accessory for a KLR is another bike for riding offroad.
Originally Posted by AZ-Twin
I need to start riding my bicycle more so I can justify a cool new one.
midengineracer is offline   Reply With Quote
Old 01-31-2010, 11:04 PM   #240
midengineracer
Lost, with a GPS
Oddometer: 1,293
For shame, why replace it with a TW200?
Thomas
2010 H-D XR1200
Times are GMT -7.   It's 11:19 AM.
