Old 08-29-2011, 06:21 PM   #781
sion
sigh-own
sion's Avatar
Oddometer: 3,588
about a month ago, I boogered up my engine...see here:
http://www.advrider.com/forums/showp...ostcount=39364
today, I ordered the rest of the parts (a wiseco piston kit, a K&L cam chain and the needed but unrelated throttle cables) from ebay. will hopefully be here within the next week...at which point I'll begin reassembly. I'll post up some pics when I do the work.
the top end is easy to work with on these bikes, but I've never had the bottom end apart, so wish me luck.
I say, there's no such thing as a bad day's riding. -metaljockey
whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301
sion is online now   Reply With Quote
Old 08-29-2011, 09:18 PM   #782
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
The bottom end is pretty easy too...just have the manual handy and just don't strip any threads!
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 09-08-2011, 08:35 AM   #783
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
So, quick question about the clutch side screen filter. I am almost positive that my 2003 XR250R has never had the clutch cover off, so along with that the screen filter on that side has not been checked. It's a pretty low hour bike, only around 1000 miles (PO put an speedo after he bought it new). How dirty will this screen be after break in, and a few oil changes in between that? Should I clean it now or leave it for this winter?
Rebuild threads:
Old 09-09-2011, 03:42 AM   #784
sion
sigh-own
sion's Avatar
Oddometer: 3,588
ok, so I've begun the chore of replacing the holed piston...took the jug off and took it into work to clean up the slight scoring that had occurred. after honing, the cylinder now measures 73.482 mm. the stock size piston I bought is 73mm. the next size up is 73.5 mm. I'm thinking I should get the 73.5 mm piston and hone out the cylinder a little more to accommodate it rather that use the stock sized piston. how big do I want to hone out the cylinder for the 73.5 mm piston?
Old 09-10-2011, 03:51 PM   #785
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
Taken today up at 12,800 ft:
The high point you see in the center of this pic is where the above picture was taken, redcone:
Rebuild threads:
Old 09-10-2011, 05:34 PM   #786
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,534
Wow, my XR gets pretty wheezy at 6000', did you have to get off and push at 12000'?
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 09-10-2011, 07:36 PM   #787
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
It's a 250 so you can't expect it to be a powerhouse up that high but in first it'll climb anything. The right jetting helps!
122 main, 42 pilot, raised the needle clip by one and fuel screw is about 1.25 turns out.
Rebuild threads:
Old 09-13-2011, 02:54 AM   #788
tortugo
Oddometer: 41
Can anyone tell me tales about long distance travels on an XR250R?
I recently purchased one of it and I'm tinking to make some offroad travels arround Pyrenees.
There are some photos for you to enjoy!
Salut!
tortugo.
- Stella Alpina 2007 (Bardonecchia - Italy) -
tortugo is offline   Reply With Quote
Old 09-13-2011, 12:54 PM   #789
beat
Double Dutchie
beat's Avatar
Oddometer: 88
i was reading a blog the other dat of people from the uk and drove to south africa on it...
so it shouldn't be a problem
beat is offline   Reply With Quote
Old 09-13-2011, 04:41 PM   #790
creaky
creaky's Avatar
Oddometer: 186
You will want .0015 to .002 piston to wall clearance. Since the bore is out of spec anyway, might as well bore it to 77mm and make a 277cc out of it, well worth the effort.
'98 BMW F650
'96 XR400
'98 Moto Guzzi V11
"Once you go over the hill, you start picking up speed!"
creaky is offline   Reply With Quote
Old 09-13-2011, 08:52 PM   #791
sion
sigh-own
sion's Avatar
Oddometer: 3,588
creaky, I much appreciate the clearance numbers...but I'm gonna stick with the 73.5 mm piston for now. I'm already into it for $400 worth of replacement parts as is...I dont really wanna spend more $$ getting it properly bored, then have to work on the carb, etc...for what, maybe 2 or 3 more hp?
Old 09-14-2011, 05:36 AM   #792
creaky
creaky's Avatar
Oddometer: 186
I agree that since you already have the parts, go ahead with the plan. However, it would be a good idea to mic the bore to make sure that it isn't out of round or tapered out of spec.
'98 BMW F650
'96 XR400
'98 Moto Guzzi V11
Old 09-14-2011, 02:30 PM   #793
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
Anyone have a stock muffler tip laying around that is not in use that will fit a '03 XR250R? Looking for the complete tip set up, if you have one let me know and let's make a deal.
Rebuild threads:
Old 09-14-2011, 05:44 PM   #794
Brewster
Brewster's Avatar
Oddometer: 43
I have one I'll give you. You do realize the diameter of the tip is like ........ half an inch! Very restrictive and will probably warrant installing smaller jets in the carb. I'm assuming your bike was jetted for a more "open" exhaust.
If you want it email me at "bruce enns at cox dot net"
cheers
Brewster
Brewster is offline   Reply With Quote
Old 09-15-2011, 04:52 PM   #795
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
cheers
Email sent. Thank you!
Rebuild threads:
Times are GMT -7.   It's 06:17 PM.
