Old 08-22-2012, 09:12 PM   #1261
rpet
Awesometown
rpet's Avatar
Oddometer: 815
check out xrsonly.com for headlights.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 08-22-2012, 10:44 PM   #1262
ozarkrider
Discombobulated Sociopath
ozarkrider's Avatar
Oddometer: 5,628
Been there already. They don't seem to list bulbs separately. I've gotten an Acerbis DHH kit but it won't fit on the XR. Wants to point to the front fender.
The search continues...
O'Jay
I'm not weird, I'm Limited Edition!
Life is a sexually transmitted disease and the mortality rate is 100%
ozarkrider is offline   Reply With Quote
Old 08-23-2012, 07:28 AM   #1263
bluebox
bluebox's Avatar
Oddometer: 152
Originally Posted by bluebox View Post
I had dramas installing the manual kick starter. The shaft I got off an old 94' had a different gear tooth pitch to the clutch basket. So I need a gear that will fit my bike. I might need a whole new shaft. I am just not sure what they have changed. The mount for the front of the bash plate have been torn off the frame. So I need to do some welding. The oil cooler just needs the mount modified. I am hoping that tapping into some of the pipe work on the left hand side will work. Marks instruction for the 650 say tap into the long oil pipe on the right hand side. But there is too many pipes on the left side already. I am not going to bother waisting the new chain, sprockets and tyres just to wear 'em out fang-ing up and down the hi way to go riding with these 7blokes on big adventure bikes. I will post pictures if I get the bike finished and go on the ride.
Can anyone tell me what those pipes are on the left hand side at the front of my motor? I thought they would be oil but I have doubts now. They are in the way of where I wanted to mount my oil cooler. I welded be brackets to the frame and got my bash plate mounted. I also put the motor back together (complete with broken gasket all stuck back together with guess. ) I ordered gaskets but they won't be here for a while. So I didn't put the sprokets on or the new tyres yet and the oil cooler will have to wait. I am going for a ride on Sunday with the bike the way it is. Wish me luck.
bluebox is offline   Reply With Quote
Old 08-23-2012, 10:39 AM   #1264
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 363
Hi
I guess you mean this stuff
Honda call it AI System .
Thats the emissions Control shit.
You can remove it compleatly but you must then block of all the Connections on the Cylinder , Airbox and Intake .
Engine runs without that stuff , no problem but i don't know its leagal in your country .
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 08-23-2012, 05:12 PM   #1265
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 818
I know somebody needs some or all of this
http://www.advrider.com/forums/showt...6#post19429966
Also have a stock red seat if anyone is interested
2000 XR250R - Tagged
1998 XR400R - To be tagged
2003 XR650R - Sold 2006 Ducati Monster -Sold
'Cause I like to party - Story of 2 XR650s conquering Florida
http://www.advrider.com/forums/showthread.php?t=754094
SpeedoJosh is offline   Reply With Quote
Old 08-23-2012, 05:23 PM   #1266
rpet
Awesometown
rpet's Avatar
Oddometer: 815
My mistake; I meant Baja Designs.
I am running this in my '04 XR250R. Baja Des also has a 100watt version if your stator can handle it.
http://www.bajadesigns.com/ProductDe...-Xr-55wt-glass
Old 08-23-2012, 07:03 PM   #1267
bluebox
bluebox's Avatar
Oddometer: 152
Originally Posted by Schrauberklaus View Post
Hi
If its not needed then its going to come off! Its in the way of my oil cooler install.
Old 08-23-2012, 11:15 PM   #1268
ozarkrider
ozarkrider's Avatar
Oddometer: 5,628
Thanks. That looks like the ticket. Got one on the way.
O'Jay
Old 08-24-2012, 05:48 AM   #1269
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
It doesn't say if it can be converted to a high/lo beam. Do you know if it can?
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 08-24-2012, 06:42 AM   #1270
rpet
Awesometown
rpet's Avatar
Oddometer: 815
I don't believe so. My xR is offroad only, so I haven't tried.
I DID install an on/off switch along with the 55watter (actually a Tusk kill switch) in case the extra current draw would make the bike harder to kickstart.
Old 08-26-2012, 09:50 AM   #1271
Ash-7
Ash-7's Avatar
Oddometer: 23
Here's how the mounting points and tank look like.
Originally Posted by gvthnks View Post
What do the mounting points look like for your tank? It looks like an xr250r tank, but you can't tell from the pic.
Ash-7 is offline   Reply With Quote
Old 08-26-2012, 02:02 PM   #1272
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
The metal tank pictured above is a XR250L tank.
MentalGuru is offline   Reply With Quote
Old 08-27-2012, 11:13 AM   #1273
Ash-7
Ash-7's Avatar
Oddometer: 23
Thanks Does that mean the XR250 of the same year has different fittings? Let me check the flea market....
Old 08-27-2012, 03:01 PM   #1274
gvthnks
gvthnks's Avatar
Oddometer: 536
The xr250r version has different tank mounts than the L version. (yours)
The r version, which is a plastic tank, has brackets mounted to the front of the tank that bolts go through and into the tank. Those two bolts, one on each side plus a strap in the rear of the tank are all that hold an R tank on.
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is offline   Reply With Quote
Old 08-28-2012, 12:50 PM   #1275
Ash-7
Ash-7's Avatar
Oddometer: 23
Thanks a lot, if anyone out there has a bigger (15lt or so) tank please let me know
Times are GMT -7.   It's 05:28 AM.
