Old 10-22-2012, 03:21 AM   #1381
timg
timg's Avatar
Oddometer: 37
Bluhduh Indicators not working
Hi,
I've just purchased a 2005 XR250 similar to this one;
One problem, when I got it home the front indicators glow all the time when the key is on or the bike is running. When the indicator is turned on it blinks like normal but the other front indicator just glows and vice versa.
The rear ones work ok. I didn't notice this when I looked at and rode the bike before purchase, possibly because is was a bright sunny day, as opposed to my dingy garage today. Hate it when that happens
I thought the obvious thing might be some sort of short or tracking in the switch block between the head light switch and the indicator switch so pulled the block apart but nothing to be seen and with the block apart I still get the 'glow'.
Anybody come across this before? Just thought I'd ask before starting to trace and isolate the wiring incase someone has had the same before knows exactly where to start looking....
Looking forward to getting out for a ....
If its not Orange, its a Lemon!
timg is offline   Reply With Quote
Old 10-22-2012, 08:44 AM   #1382
prsdrat
Oddometer: 733
My TW200's indicators do the same thing. I think it's a safety feature.
Go figure.
"Can't never could."-Grandma Belle Marie Bullock-Shuflin
prsdrat is offline   Reply With Quote
Old 10-23-2012, 01:29 PM   #1383
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
I'm building a "Cheap Skate D/S Minimalist Touring/Woods XR250 for a Full Size Rider"
Here's the link. http://www.advrider.com/forums/showt...3#post19863173
The goal is a $1000.00 budget total after selling the exta parts listed and other goodies... So far so good...
It has a 39" seat height and 22.5" from the pegs to the seat. It's meant for comfort with a 8" wide seating area.
With a 36" inseam I can still flat foot it with a slight knee bend.
It's based on a plated '87 XR250R with a fresh XR250L engine built with R cam. The wide ratio 250L 4-6th gears with a 14/46 final is the gearing plan.
It will use the 250R carb and header with a XL600R 4" SuperTrapp for now. A 34mm Mikuni flat slide will probably be done when money permits.
Other mods being done:
XRL swingarm and cush drive rear 2.15" wide disc brake wheel.
'99 CR500 46mm KYB inverted front end and wheel with a billet upper triple clamp.
XR250L side panels
XR650L 4.0 gal tank and tall soft "custom cut" XR600R seat
XR250L spring on a XR250R shock with a XR650L lower link.
XR250R flywheel, Ricky stator with a 12 volt AC and a 12 volt DC lighting DS conversion.
Here's a picture of it a few weeks ago.
xladv.com
MentalGuru is offline   Reply With Quote
Old 10-25-2012, 07:59 PM   #1384
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,949
Can any of you guys tell me the fuel screw setting for my 2000 . I removed the snorkel , installed a 135 main ,and removed the muffler baffle . The bike seems to have a flat spot just off the bottom , warming it up and raising the idle helped , but maybe I am missing something . I dont have intimate knowledge of these bikes , yet . Any help would be greatly appreciated.
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is online now   Reply With Quote
Old 10-25-2012, 08:10 PM   #1385
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,127
A) MentalGuru, that's a pretty sweet setup for $1,000. I'm guessing that is the upgrades and doesn't include the bike, but either way it's going to be a great trail eater when you're done. What's the purpose of the rear shock/dogbone setup? Why an XR250L spring and XR650 dogbone? Is it height or performance?
B) Stanimal, try all the way in and then out one and a half turns. Fiddle with it from there and write down where you end up.My $.02 anyway.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 10-26-2012, 04:35 AM   #1386
Red_dog
Red_dog's Avatar
Oddometer: 39
.[/QUOTE]
it's an american thing, those 'glowing' indicators work like clearance lights on a truck. my 04 XR250 never did it. if that's the case, buy an aussie switch block, and relay, and indicators, there should only be 2 wires coming out of each indicator, green is earth, other colours (blue, pink, brown etc) are power wires (Forget which one goes where). rock solid little bikes, but for the OP, in regards to the oil change, look up 'XR600 Oil Change' on youtube, there's a big dark fella (Henry i think his name is), does a full oil change and tappet check on his XR600L, there's a little bolt underneath the engine, shifter side, just above the frame, that needs to be drained aswell. watch the Video and you'll see wot i mean.
Red_dog is offline   Reply With Quote
Old 10-26-2012, 04:39 AM   #1387
Red_dog
Red_dog's Avatar
Oddometer: 39
leave the fuel screw alone, did you do the main and slow jet as well? look up 'Scraperslider' on youtube, there's another mod that Gordon does on his 250, called the 'sparkplug bolt mod'...stainless steel bolt, cut the head off, pull the sparkplug boot off (the yellow one), inside there's a screw, undo it, out will come a spring (dont lose it) and a resistor, throw the resistor over ya shoulder, and place said stainless steel bolt shank in- 16.18mm long, and 6mm diameter. will give better spark, and less bogging, i tend to go 2.5turns out of the idle screw (the big black one on the carby) which helps alot, my old girl is pretty loud however, with a top end rebuild and stage I cam she goes alright!
Old 10-26-2012, 07:23 AM   #1388
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,658
Get it warmed up and turn your idle back down. Then slowly turn out the fuel screw until the idle increases. Turn it back in until it starts to stumble again, then go back out a 1/4 to 1/2 turn. Rev the engine a few times and notice if the engine hangs at higher revs or drops back down quickly. If it hangs, turn the fuel screw out a bit until the idle drops back down nice and smooth. It shouldn't drop below normal idle speed either (that indicates it's too rich, turn the fuel screw back in if that happens). Once you're happy with the adjustment, shut it off and turn the fuel screw all the way in, counting the turns. If it's 2.5-3 turns out or more, go up one size on your pilot jet, set the fuel screw to 1.75 turns out (factory spec) and repeat the process. If not, turn it back out the counted number of turns and you're good to go.
A flat spot off idle could also indicate that your needle is too low. Once you get the idle mixture dialed in, if the flat spot is still there, try dropping the needle clip down one notch (raising the needle).
cjbiker is offline   Reply With Quote
Old 10-26-2012, 09:17 AM   #1389
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,949
Thanks guys ^^^^^^^^
Old 10-26-2012, 01:30 PM   #1390
timg
timg's Avatar
Oddometer: 37
Thanks Red Dog
Old 10-28-2012, 01:28 PM   #1391
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,658
Let us know the results. It's good info to add to the collective knowledge.
Old 10-28-2012, 02:06 PM   #1392
jon_l
jon_l's Avatar
Oddometer: 3,150
Can anyone point me to a comparison between the XR250R and CRF230F? I rode an XR250R briefly, and all i can remember is that it was a bitch to kick-start, but I suspect it just wasn't well-sorted. I rode a CRF230F for several hours, and thought it was a hoot.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 10-28-2012, 02:08 PM   #1393
ozarkrider
Discombobulated Sociopath
ozarkrider's Avatar
Oddometer: 5,628
If you're considering the CRF, I'd opt for the CRF250L. FI, water cooled, and very affordable. Not as trail worthy in my opinion as the XR but still a fun bike.
Much depends on your intended purpose.
O'Jay
I'm not weird, I'm Limited Edition!
Life is a sexually transmitted disease and the mortality rate is 100%
ozarkrider is offline   Reply With Quote
Old 10-28-2012, 02:22 PM   #1394
jon_l
jon_l's Avatar
Oddometer: 3,150
The new CRF250L looks like a fine bike, but it's way too heavy for off-road. I have a WR250R, so no need for the "L".
I want a cheap reliable trail bike that weighs a lot less than the WRR, without turn signals, etc.
CBF1000 & PCX150
Old 10-28-2012, 02:28 PM   #1395
ozarkrider
ozarkrider's Avatar
Oddometer: 5,628
The XR's yer boy then. Mine generally starts from cold within 5 kicks. We'll see how it does after the new top end job.
O'Jay
Times are GMT -7.   It's 09:41 AM.
