Old 12-31-2012, 06:44 PM   #1471
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,720
Originally Posted by wfopete View Post
Ok new owner...sort of. I have a 86 XR250R model but just bought a 2001 XR250R for my nephew. Paid $1k for it. Needs some TLC (mostly cleaning and inspection stuff) but looks like a decent scooter. All original but has been sitting for a couple of years. Still has OEM tires/chain.
Anyway, hate to ask this but much of the rubber and seals on this bike has dried/deteriorated/rotted (shock bumper, tires, air filter foam, even the o-rings on the chain have rotted off). So I plan to replace that stuff plus check valve clearances, change the fluids/filters, grease the linkage and steering stem bearings.
Anything else I might be missing?
BTW, what is the deal with the kickstarter placement on these things? Mine sits off the kick starter shaft by about .5 inches. Is it typical for the kickstarter not to go all the way on the kick start shaft on these bikes?
Sounds like a good deal! My kickstart is the same way. I pulled it off and tried to install it so it's flush with the end of the shaft... Nope, that's the way it goes. I looked at all the pics I could find online of the XR kickers, and it seems like they're all like that. Just make sure the bolt is tight and you'll be good to go.
Good luck getting the swing arm bolt out if it hasn't been greased already.
cjbiker is offline   Reply With Quote
Old 12-31-2012, 07:12 PM   #1472
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by t.read View Post
Mine after an attempt to race a Hare Scramble against a bunch of nearly new KTMs, Hondas, Yamahas, etc. today.
Nice.
Keep trying may just surpise you.
It's still a great woods weapon for enduro use or technical use.
xladv.com
MentalGuru is offline   Reply With Quote
Old 12-31-2012, 08:47 PM   #1473
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 483
Yeah, can't wait.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 01-01-2013, 10:46 AM   #1474
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
Question
I was thinking about replacing the Decompression Lever with a CRF clutch and hot start assembly and tie the Decompression Lever to the Hot Start lever. Any of you boys done that? Thoughts?
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 01-01-2013, 11:03 AM   #1475
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
I will be using one.
Right now I use a XL600R modified clutch/choke perch.
The choke lever is used for decompression.
The hot start lever should pull easier then the choke lever does.
xladv.com
Old 01-03-2013, 02:02 PM   #1476
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
Since I'm a n00b at fixing my own bike I may not ask this question correctly.
I'm in the process of making the bike street legal. I decided I did want to add a battery for a variety of reasons but not important to my question. I purchased a regulator/rectifier to convert from AC to DC (the wiring diagram on that is another issue...). Anyhow, from the below wiring diagram, I'm trying to figure out which 2 wires go from the rectifier. I am guessing it is the Yellow and Pink wire since these go to the AC Regulator. I just need to figure out which wires on the rectifier accept the yellow and pink wires. Am I on the right track?
2007 Honda XR650L
Old 01-03-2013, 05:15 PM   #1477
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,965
IMHO , buy a something like Baja Designs kit and save yourself some time and possible grief .
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is online now   Reply With Quote
Old 01-03-2013, 06:27 PM   #1478
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,720
Here's a good write up on wiring up your own DS kit on the XR. He's marked up the schematic to show how and where to install the regulator.
http://www.thumpertalk.com/topic/867...-the-tusk-kit/
Old 01-03-2013, 06:35 PM   #1479
sion
sigh-own
sion's Avatar
Oddometer: 3,588
I've done this exact mod on my 02 xr...its very easy and nicely inexpensive
I say, there's no such thing as a bad day's riding. -metaljockey
whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301
sion is offline   Reply With Quote
Old 01-03-2013, 08:03 PM   #1480
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
I'm a moron!! I originally read that thread and used it as a reference and totally forgot about the wiring diagram!! Thanks for the reminder.
2007 Honda XR650L
Old 01-04-2013, 08:25 AM   #1481
fiep
fiep's Avatar
Oddometer: 1,918
what is the difference between XR250s in 84 and 85
tank decal
swingarm decal
color fork boots
also
for these years I heard 'XR200 and 250 are the same bike just a differnt bore'
just don't want to believe this
but how can I tell apart the parts unless they are bolted to the correct bike?
fiep is offline   Reply With Quote
Old 01-04-2013, 09:01 AM   #1482
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
tank decal
swingarm decal
color fork boots
also
The 84-85 XR200R are RFVC engines based on the XR250R. The XR200 built before '84 and after '85 were 2 valve engines.
'86 and newer XR200's use the same basic frame and body parts as the '84-'85 XR250R and XR200R's.
xladv.com
Old 01-06-2013, 02:33 PM   #1483
fiep
fiep's Avatar
Oddometer: 1,918
thanks, good to know
just got permission to rebuild not only an 84 and an 85 XR250 but
an XR200 as well
Old 01-06-2013, 02:46 PM   #1484
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,965
an XR200 as well
Permission ?! From the democrats ? Or ?
Old 01-06-2013, 03:07 PM   #1485
fiep
fiep's Avatar
Oddometer: 1,918
no, no rats
from my lord and master
Times are GMT -7.   It's 11:05 PM.
