Old 02-05-2009, 02:02 PM   #1
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
'87 XR250 + a box of parts = project time
I couldn't pass this deal up, it's titled, didn't cost much at all and it's all there (as far as I could see). Plus, I love a good project!
I was able to score some info from the previous owner (PO) and a couple of receipts that were in the box. The receipt, from Al Bakers XR's Only, says that, in May of 1994, a NIKS rod kit, 76mm piston and a gasket kit were ordered. Another receipt suggests the cylinder was "Bored 120" of an inch - Honed w/ a Rigiotner flex hone: .0015" clearance as per customer's orders, would recomend more" .
Apparently, from what the PO told me, soon after this work was done the bike was not ridden for too long because the bike aparently started smoking soon after the work was done. They took the bike in to a dealer who quoted about $2000 worth of work and they said no. Ever since then the bike's top end and other parts have been sitting in boxes. He thinks the valves weren't adjusted right. I'm not sure what to think.
Did the bike run low on oil? Did an oil line get clogged? After these upgrades were done, was something not done correctly? I'll have to figure these things out. I need to buy a service manual before I get started. I'll probably end up splitting the cases because who knows what's in there after all these years....It will be a little while before I can get started on this project but it will get done and it will get done right. Here are some pictures from today:
The bike:
Couple of boxes:
Top end:
Pictures of the piston:
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 02-05-2009, 02:04 PM   #2
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
So here's where the immediate trouble begins, the cam shaft and rockers don't look good at all.
Rebuild threads:
Old 02-05-2009, 02:07 PM   #3
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
I'll spend the next couple of weeks reading and learning about the bike. I know i've seen a couple of threads about these bikes here. A service manual is for sure going to be needed and, of course, the advice from you folks. What do you guys think happened here?
Rebuild threads:
Old 02-05-2009, 02:21 PM   #4
jgrady1982
jgrady1982's Avatar
Oddometer: 782
To me (complete amateur) looks like no oil. Perhaps an oil line was clogged, starving the top end of oil. Take an air hose to all the oil lines and blow the heck out of them. Also replace all the screens. That could be a good cheap start. Looks like you may be purchasing a new CAM and rockers though. Keep us posted - Jack
jgrady1982 is offline   Reply With Quote
Old 02-05-2009, 02:39 PM   #5
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
Looks like fun. I was broke during the late 80's and early 90's when these bikes ruled the earth or I would have had one myself.
Take off the right side cover and check the clutch and oil pump for wear. It could be as simple as the previous owner busted a ring trying to put it together. That cam and a couple of rockers are finished... but you knew that. 1 and 1/2 thousandths clearance in the bore is too little for an air cooled motor. IMO. It was very common for people to punch these bikes out to a 280cc
Hate gets you nowhere.
Reposado1800 screwed with this post 02-05-2009 at 02:48 PM
Old 02-05-2009, 03:51 PM   #6
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
Both you and the machinist who did the work think this...why do you think the PO had it done this way? Was it maybe recommended by XR's only at the time?
Rebuild threads:
Old 02-05-2009, 04:31 PM   #7
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
So far, I'm looking at replacing all bearings, camshaft, rockers, piston and maybe the valves...Definitely new valve seals and new cam chain. Hoping I can just rehone the cylinder and use another 76mm piston instead of going up another size.
In the end I want this bike to be reliable and bulletproof, so I would assume that it's best to stay with stock engine components. There's lots of aftermarket components for these bikes, which is awesome. Any recomendations here will be appreciated. I can clearly see after a quick search that finding the parts to make this bike run won't be a huge issue, finding some time will be, though!
Rebuild threads:
Old 02-05-2009, 05:05 PM   #8
Jeremy1981
shopping for a ride
Oddometer: 30
Thumb I'm in!
I may not be able to contribute anything useful to the technical knowledge here, but I sure can like a pro!
Jeremy1981 is offline   Reply With Quote
Old 02-05-2009, 06:15 PM   #9
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,972
A complete engine gasket kit will include valve guide seals (it did w/ my XR600). I would stay with stock rockers and cam like you say - the oem rockers for my 600 were ~$41 each.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 02-05-2009, 06:24 PM   #10
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
Thanks for the info, Blake! I've been searching for parts and pretty much everything I need I could get through Service Honda and Xr's only it seems...I also came across this ebay item:
http://cgi.ebay.com/ebaymotors/_Moto...1%7C240%3A1318
Camshaft and rockers all for $129.99 with free shipping...something tells me to steer clear from this, but at the same time I just don't know.... Has anyone here used one of these packages with success?
Rebuild threads:
Old 02-12-2009, 08:18 PM   #11
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
Scratch that idea above...I'm going OEM.
I was looking at the flywheel puller for the XR250 and all it is is a bolt. 22mm x 1.5. Would a high quality bolt of the same specs from the hardware store do the trick or is there something special about these "flywheel pullers" that i'm not seeing?
Rebuild threads:
Old 02-12-2009, 11:52 PM   #12
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,684
were there valve guide seals on the top end when you removed it?? Just sayin because I doin a rebuild and when I got the head serviced they lost the seals and said nothing. And I was thinking doing this what if someone wasnt up to par and rebuilt with no valve seals?? but my ktm has rubber c clip type.
wrk2surf screwed with this post 02-13-2009 at 12:02 AM
wrk2surf is offline   Reply With Quote
Old 02-13-2009, 08:02 AM   #13
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,140
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 02-13-2009, 11:25 AM   #14
Olas OP
the darkness
Olas's Avatar
Oddometer: 4,002
Yeah, the seals, valves and springs all came in a bag...
I received the service manual today so i'll be able to start measuring parts soon, this weekend probably. Also expecting the complete engine gasket and oil seal set from Moose today. I can't wait to get started on this thing, it's going to be fun....i'll make it a point to take lots of good pictures as I go along.
Rebuild threads:
Old 02-13-2009, 01:26 PM   #15
Reposado1800
Juicy J fan!
Oddometer: 5,785
I wouldn't use a regular bolt for that application. That puller is most likely hardened so it won't deform under pressure. If you don't want to buy the puller, drop down by the bike shop and have them pull it off for you. It could be cheaper as they have the tool on the shelf.
Times are GMT -7.   It's 12:46 AM.
