Old 04-02-2011, 06:36 AM   #151
Olas OP
the darkness
Olas's Avatar
Oddometer: 3,583
Hi. What sort of trouble are you having? Can you not get all the marks aligned to where they should be? Does the bike run as it sits? Is the cam chain new?
The timing is not adjustable and is pretty easy to set...You have to have the piston at top dead center when you are doing this and the chain tensioner must be held back out of the way. It's hard to explain it, look to see if you can download a manual online for another XR/XL (like a XR600, XL250, etc...) the timing procedure for those bikes should be very similar if not the same.
FS: Street Legal American Trail Killer!!
Rebuild threads:
'92 XT600
, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 04-10-2011, 02:25 PM   #152
sigep69
Oddometer: 2
what about the valve clearance when i took it apart there was a lot of clearance and when i put it back together the guy that helped me thought it should only have 3thousants clearance
sigep69 is offline   Reply With Quote
Old 08-16-2011, 08:35 PM   #153
Olas OP
the darkness
Olas's Avatar
Oddometer: 3,583
Something red followed me home the other day...
Rebuild threads:
'92 XT600
, '87 XR250R
Times are GMT -7.   It's 02:01 AM.
