07-14-2009, 03:38 PM
#46 |
the darkness
Oddometer: 3,588
Engine skittles
So this is where I am at today:
![]() ![]() Getting close!! I am missing a stud that holds the header from the head so I went ahead and order a bunch of nuts and bolts from service honda today. While I am waiting for that stuff to show up i'm going to work on the wheels, tires, and general clean up. I expect to have this bike out on the trails (and the road!) in about 2 weeks. Sweet. |
07-14-2009, 03:41 PM
#47 |
the darkness
Oddometer: 3,588
Question about the decompressor cables:
Are they really necessary? My buddy has a newer XR400 that had all this stuff removed and it seems to be doing fine. If his 400 can be kickedstarted without issue even without the decompression cables i'm assuming the 250 should be fine. Just wondering if I need to take care of anything else if I leave the cables off... |
07-14-2009, 06:02 PM
#48 | |
Racing Like a Noob
Oddometer: 4,280
BTW, I just rode the bike today, its plated, and i rode the 12 miles to the trails/logging roads. I have to tell you, everytime I ride this old beast, I smile..it just gets the job done. I am feeling some of its limitations (bottoming out after nice air) but it still is a great old bike. Good Luck with yours. Don't even worry about putting the decompression cables on. Save the time and money for some other farkles..like bar risers. |
07-15-2009, 05:28 AM
#49 | |
Professional Idiot
Oddometer: 926
Like Oregoncoast, I get a lot of pleasure out of riding my old XR. I have a KTM also, but I find myself riding the XR more. I certainly has limitations, but it also has plenty of strong points - the main one being that it's so easy to ride in any conditions. I'm really looking forward to reading about your first rides on your XR. My XR: http://advrider.com/forums/showthread.php?t=410462 |
07-15-2009, 08:28 AM
#50 |
Oddometer: 192
If you have the auto decompressor on the camshaft I would remove it or grind the small pad off the side of the rocker arm. It is a known problem area and can make it impossible to start. The manual decompressor then becomes essential if you have an accident damaged right leg like mine.
A quick edit, I notice yours has the cable to the kickstart so you can ignore that last bit.
'11 Triumph Tiger 800XC, |
07-15-2009, 11:27 AM
#51 |
Shit Needs a Rebuild...
1992 XR600R (Plated) |
07-15-2009, 12:27 PM
#52 |
the darkness
Oddometer: 3,588
I've decided to leave the manual decomp. installed and get rid of the auto. I just don't see the point in having the auto AND the manual. Thanks for the response on this, guys.
I worked on the bike today some more and loosely assembled most of it. It looks good! |
07-15-2009, 02:53 PM
#53 |
the darkness
Oddometer: 3,588
![]() Everything (except for the exhaust header) is on the bike at this point. I need one exhaust stud to start the bike. I placed my order last night but probably won't see the parts till next week - if they are in stock... Anyone have any ideas as to where I could possibly get a 6mm stud or am I just going to have to wait. I should have ordered this long ago but for some reason I just didn't notice it was missing. Luckily the female threads are intact so I'm guessing it just came out with the nut that is also missing. |
07-15-2009, 03:02 PM
#54 |
the darkness
Oddometer: 3,588
By the way, I was having a tough time getting the exhaust header on there today. The collars did not want to stay in place and were hard to get to fit right. Is there a trick to make this simpler? Do they only fit on there a certain way? I've never had a bike that used these split collars..Or, I should say, i've never had a Honda dirtbike :).
07-15-2009, 03:07 PM
#55 |
Oddometer: 760
I needed an 8mm stud for my 86 and I did not want to pay the $7.99 for shipping an $0.89 part. So I went to the honda dealer and asked them for an 8mm stud of any length. Then got a 8mm die to make sure that the threads were the correct length, cut the stud to length and then ran the die to make up for the threads.
Just an idea. -Jack |
07-15-2009, 03:15 PM
#56 |
the darkness
Oddometer: 3,588
Jack,
Thanks for the idea, i'll check with my dealer tomorrow. |
07-15-2009, 03:27 PM
#57 |
the darkness
Oddometer: 3,588
Well, I just called my nearest dealer and they didn't have any 6mm studs in stock but he did tell me the size I need: 6 mm X 28 mm. I'll be going to the hardware store tomorrow to see if I can find something that works.
07-15-2009, 06:07 PM
#58 |
Oddometer: 760
Hey man,
I'm glad I could be of help! That was just what I did when it came to my exhaust stud question. As long as the dealer has a stud that is longer than what you need your in business, and you may not even have to run a die through the middle to make up for the gap in the threads if you have to cut the stud down. Good luck! -Jack |
07-15-2009, 06:21 PM
#59 | |
r-u-n-n-o-f-t
Oddometer: 12,193
I asked about getting oil pressure quickly at first startup - he just recommended putting the first quart (or half, I forget) in one of the valve inspection nuts.
'12 VFR 1200 . '13 TR650 Terra . IBA #11735 . 1968-present |
07-15-2009, 08:17 PM
#60 |
the darkness
Oddometer: 3,588
Thanks, Blake. I'll give that a try. Hoping to find a stud for the cylinder head tomorrow and *hopefully* fire it up Friday. We'll see....
