Old 10-30-2009, 07:08 AM   #571
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 920
You guys are all just falling into my ploy of getting you to post more pics of your VFR's.
I just prefer a pic of a well ridden, dirty VFR than a perfectly clean spotless one.
onetravdown is offline   Reply With Quote
Old 10-30-2009, 09:43 AM   #572
MapMaster
Human Compass
MapMaster's Avatar
Oddometer: 977
Originally Posted by DevilNinjaDog
Jebus! Is there a walkthrough somewhere that can guide me in the process of removing that stuff from a gen 4? What does it all DO?!! Does removing it alter the engine's performance at all (not HP but introduce flat spots, cause rough idle/hard starting/worse economy/etc)
In reverse order:
The system is an emission related one, it introduces fresh air from the air box to the exhaust headers when off-throttle to allow more complete burning of the exhaust gases. Removal doesn't impact engine performance at all, but some reported less light backfiring on deceleration after removal.
I don't recall seeing a write up of what to remove posted anywhere. Get a shop manual that describes and identifies all of the parts of it. No wiring is involved, there are vacuum lines from the intake to cap off, air supply from the air box to tape over, and chromed tubing to just below each exhaust header to remove. That last part is the most difficult in terms of access, especially for the rear cylinders. You then need to block the just created exhaust opening. Sets of plates were available to bolt into place, whether any are still available or not I don't know. (I also don't know if the same system was used on later models or not, but if so the plates should still be findable. CBR600's used the same plates for the same purposes.) I fabricated some from several layers of thin flashing, cut some new gaskets, and cut the tubing from the existing mounting brackets so I could reuse them to seal the exhaust ports.
As mentioned, removing it will drop a couple of pounds and make access for other maintenance tasks around the engine easier, which is the main reason why I did it. The capped vacuum nipples are where to connect carb stix for synchronizing the carbs. With the PAIR stuff gone, these are much easier to access, as well as the carb drain screws when doing long term storage.
If you're not doing your own tune ups, there's not much benefit from the process, cause while simple to describe, it was a PITA to do.
Cheers,
MapMaster is offline   Reply With Quote
Old 10-30-2009, 10:00 AM   #573
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,413
Originally Posted by fleshpiston
Correct... just mid fairings need to be removed. Right side is a little tricky with the coolant hoses in the way.
Now that I think of it the left side might be obscured too if you still have the "PAIR" (emissions) plumbing installed .... flashlight and long screwdriver will be your friends
Left-side access is clear, even with PAIR equipment installed. I do all my carb synchronization from the left for this reason.
I reached the drain screws on my carbs without difficulty even though I still have the PAIR equipment onboard (I'm too lazy to bother removing it, and if it burns up extra hydrocarbons, so much the better). I don't remember whether I accessed all four drain screws from the left side, or used both sides, though.
I'm going to be yanking my carbs here soon for a thorough cleaning ( engine was idling at 1500rpm with choke full on, and now won't start at all, and I've been putting off cleaning the suckers for a while, because I'm lazy). If I get to it soon I'll try to remember to take pics of the drain screws.
hpsVFR is offline   Reply With Quote
Old 10-30-2009, 11:28 AM   #574
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,477
Thanks guys.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 10-30-2009, 01:02 PM   #575
Twohondas
Twohondas's Avatar
Oddometer: 1,206
It helps when it does not rain for 4 or 5 months.
Twohondas is offline   Reply With Quote
Old 10-30-2009, 07:16 PM   #576
SVader
Lurker
SVader's Avatar
Oddometer: 189
My 04 that appeared earlier in the thread.
I traded it Thursday for an 07 anniversary with ABS.
SVader is offline   Reply With Quote
Old 10-31-2009, 05:12 AM   #577
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 1,071
Nice!.....no better day than new bike day
Gary
Originally Posted by rtwdoug View Post
It was made out of chinesium, which is sort of like metal, only softer
Gas Hog is online now   Reply With Quote
Old 10-31-2009, 09:11 AM   #578
Chad_NC OP
Chad_NC's Avatar
Oddometer: 3,790
The Anniversary edition is still my favorite VFR. I almost put mine up for sale last week, but the wife talked me out of it. I dont get to ride mine as much as I should, and now it will be even less since I took the plate and insurance off of it for a while.
Chad
09 Buell Ulysses XB12XT
09 Wrangler Sahara Unlimited
Chad_NC is offline   Reply With Quote
Old 10-31-2009, 09:22 AM   #579
Constipated Face
Oddometer: 404
Didn't notice any Gen-6 VFRs with frame sliders installed.
Constipated Face is offline   Reply With Quote
Old 10-31-2009, 09:53 AM   #580
fleshpiston
fleshpiston's Avatar
Oddometer: 612
These are made by a fellow that goes by the name of "radar" on VFRD.
They worked very well for my friend when he had a little run in with some deer.......
R&G might be easier to get in Singapore though???
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 11-01-2009, 02:03 PM   #581
Hammerspur
Hammerspur's Avatar
Oddometer: 1,138
Originally Posted by Stupiderlikeafox
I finally got myself a VFR. I've wanted one since the early 90's but always found excuses why not to. Then, one day a two weeks ago I saw a craigslist ad for a low mileage '97. Wants to trade for a dual sport. Goodbye high mileage DRZ-400 SM, hello VFR. Even trade. Best bike ever.
DAMN!!!
I called on that one just after you!
I wanted to buy that bad... oh well, T.S. for me, still looking.
(If anyone can point me toward a nice, reasonably priced one in the So. New England area, I'm listening!)
Hammerspur is offline   Reply With Quote
Old 11-01-2009, 05:00 PM   #582
bl4ckd0g
Time for a Magic Trick
bl4ckd0g's Avatar
Oddometer: 278
That's 'cuz most kits require a keyhole saw cut to both sides of the front fairing. Gen 6 body sliders are not a cheap purchase. Another $80 and you can buy new front fairings.
SWM, searching for the perfect winding road.
bl4ckd0g is offline   Reply With Quote
Old 11-01-2009, 07:24 PM   #583
dougfromindy
I smell premix
dougfromindy's Avatar
Oddometer: 2,330
get frame sliders now or cry later
This is not true. I think R & G kit costs about $200 total, way less than just a single side panel fairing for a 6th gen. I got my R & Gs for $100 on ebay and an R & G coolant bottle on vfrd for $25, so $125 cost if you shop.
Never use any saw on a fairing or no holesaw on a drill motor. Mark a small pilot hole, if its a good spot then use a bigger drill bit next, still good, then use sliders and trace around with a black sharpie marker. Finally finish hole with a dremel tool and a sanding drum bit on it. Mine turned out perfect 10/10 with an hours time. No margin for error on this job so I will admit its a bit nerve wracking. I did it, perfect. My driveway drop meant no body damage just bending the rear brake lever back into place with visegrips.
Big trouble without the R & Gs.
dougfromindy is offline   Reply With Quote
Old 11-02-2009, 06:01 AM   #584
LuciferMutt
Oddometer: 11,477
That's one thing that bugs me about owning a 4th gen. If I drop it/lowside it, the plastics are done. And Honda does not make the 4th gen plastics anymore, and they are getting extremely rare to find used.
Also, even if you wanted to drill through your precious original plastic to install some sliders, there aren't good places on the frame to attach any.
At least it makes me more careful while riding the thing
Old 11-02-2009, 09:05 AM   #585
Constipated Face
Oddometer: 404
Whoa! Your friend sure is lucky. It could have been A LOT worse.
Thanks for the input. I'll check if they're available locally.
By the way, I don't have a VFR, but a buddy of mine does. He said he wasn't keen on installing sliders. Maybe this post will change his mind.
Times are GMT -7.   It's 11:02 AM.
