Old 02-08-2009, 02:17 AM   #1
mrpete64 OP
Oddometer: 611
800 GS inline gas filter?
I am interested in finding out your thoughts on using an inline gas filter on my 800 GS. I use a honda goldwing gas filter on my KLR 650. Works great.
Thanks for any of your insight(s).
Mr. Pete--->
aging hippie
mrpete64 is offline   Reply With Quote
Old 02-08-2009, 06:38 AM   #2
Bikebits
Scramblin' man
Bikebits's Avatar
Oddometer: 241
It's easy to put an inline filter on a carburetted bike like the KLR. Cut the line, splice it in and go.
Problem is, the F800 is fuel injected and has pressurized fuel lines. I'd touch base with the techs at your BMW dealer to see if they would anticipate any problems. I'd mostly be worried about the capacity of the filter to flow gas.
Dave
'06 Triumph Scrambler Trans-Labrador veteran
Bikebits is offline   Reply With Quote
Old 02-08-2009, 06:40 AM   #3
MonsterJ
I have motopsychosis
Oddometer: 262
+1
Isn't the in-tank filter enough?
-Nooner
Temple, TX -> Cape May, NJ -> Mobile, AL -> ECity, NC -> Kodiak, AK -> Mobile, AL -> Sacto, CA -> Cape Cod, MA -> New London, CT -> San Francisco, CA -> Juneau, AK (summer of '13) -> where to next?
MonsterJ is offline   Reply With Quote
Old 02-08-2009, 07:07 AM   #4
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Fuel Filter
No problem putting on an in-line filter. As long the fuel filter is rated for fuel injection as well as all the hoses and clamps. Lots of folks did it on the 1150s to avoid having to pull the pump to change filters. At least on the 1150 I didn't find changing the filter that bad. Wouldn't want to do it on the side of the road though. Takes an hour or so in the shop if you have new o-rings. The installed ones swell and need to dry out so they will fit back. Easier to just toss a new one on.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 02-08-2009, 07:28 PM   #5
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
The 800GS already has a pretty good filter in the fuel injection pressurized feeding system. No need for another fuel filter. That's overkill.
Old 02-09-2009, 06:39 AM   #6
Motoriley
Motoriley's Avatar
Oddometer: 2,686
Filter
The rational is that an external filter is much easier to change on the road. Apparently one bad tank of gas can clog up the works.
Old 02-09-2009, 08:11 AM   #7
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,305
Am I just lucky? Never had that happen on my GS's which have done serious miles in 14 different countrys. I only know 1 person who has had this happen.
ride till you can't.
1200GS/black
Boxer Cup Replika/red-white-blue
Semper Paratus
marty hill is offline   Reply With Quote
Old 02-09-2009, 08:29 AM   #8
Motoriley
Motoriley's Avatar
Oddometer: 2,686
Filterin'
I never worried about it either. Didn't get too far into the wilds on my 1150gs but never had aproblem in 80000kms with the filter either. Changed it at 50000kms I think and that was it.
Old 02-10-2009, 12:35 AM   #9
mrpete64 OP
Oddometer: 611
Thanks for your insight(s). I guess I will just let a sleeping dog alone!
Mr. Pete--->
aging hippie
Old 02-10-2009, 10:54 AM   #10
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,576
if you want the advantages of an external filter you'd have to remove the pick up filter on the fuel pump. Since it's the first in line it will always clog before the external filter will.
If you are that worried about getting bad gas use a filtered funnel when you fill the tank.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Times are GMT -7.   It's 09:28 PM.
