Old 02-09-2009, 04:32 PM   #61
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Jackd, due to inflation, it's now the $3000 o-ring
Infra, how did your old o-ring from the last filter change look like? It should be slightly flattened. Too flat means you need to remove the shim. Too round and you need to get rid of the paper gasket and possibly add shims.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 02-09-2009, 05:30 PM   #62
jackd
Oddometer: 3,032
Wow.
I wouldn't doubt that it would now cost all that now. It doesn't take long to ruin the engine - you have a high flow oil pump with a minimal oil capacity in the sump - which leads to most of your oil going overboard in minutes.
On the other hand, the pressure oil going past the cannister to return in the sump is more insidious - you don't know that you have oil supply problems until you see that pretty red oil pressurre light coming on. By then it's game over.
I must admit I was kind of taken aback by the speed with which the old hands of this Forum sprung to action to clarify the 'oil filter change' procedure. By the time I had read the original posting and finished my reply there were several replies which had not been there previous. This must be slightly important to get that response.
Old 02-09-2009, 05:37 PM   #63
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
I would remove the paper gasket. Looking at your picture, the white o-ring does not look compressed enough.
my 2 cents.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 02-09-2009, 05:47 PM   #64
jackd
Oddometer: 3,032
That Scares Me.
All that sealant around that opening and a few specks toward the centre just scares the hell out of me. I remember hearing about engine failures in aircraft which were caused by sealant blocking lubricating passages at critical bearing areas. We actually had airworthiness directives that prohibited the use of certain ones as a result of this. I think that trouble is just around the corner if this crap migrates downstream into the above illustrated engine - use it sparingly or not at all. I don't use it in this location and I only put on a skim on the bases when I replace my cylinders.
Old 02-09-2009, 06:25 PM   #65
kalispell365
on the road to shambala..
kalispell365's Avatar
Oddometer: 126
no need to be that dramatic,i used such a small amount of fujibond on there,there is no chance of problems with such a small amount.i have been building subaru engines with it for a living for years.it is used almost exclusively instead of gaskets on their motors...
kalispell365 is offline   Reply With Quote
Old 02-09-2009, 07:42 PM   #66
WooPig
Oh Glory!
WooPig's Avatar
Oddometer: 545
How could anyone not trust the Dalai Lama?
WooPig is offline   Reply With Quote
Old 02-09-2009, 07:43 PM   #67
robsmoto
Motorcycleton
robsmoto's Avatar
Oddometer: 328
One other thing about the oil filter business that is worth keeping in mind...
There are some airheads that have had failures attributable to poor oil circulation due to improper filter installation - this from postings by various gurus such as Oak, Tom Cutter, Ted Porter, SnowBum, Anton, etc.
There are many more airheads on the road that haven't failed.
robsmoto is offline   Reply With Quote
Old 02-09-2009, 07:55 PM   #68
kalispell365
Oddometer: 126
so true,mr.woo!
Old 02-09-2009, 08:02 PM   #69
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
That's why I have this on my handlebar
My oil sender is also rated at twice the OE sender's. Thus, the idiot light gives me an earlier warning.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 02-09-2009, 08:11 PM   #70
jackd
Oddometer: 3,032
Where Is It?
Opposedcyljunkie -weren't you going to throw a GPS on your handlebars as well? How did that go?
Old 02-09-2009, 08:41 PM   #71
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,530
He couldn't find any vacant space.......................
___________________________________________
Mike
2012 R 1200 GS RALLYE
Gezerbike is offline   Reply With Quote
Old 02-09-2009, 08:48 PM   #72
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
+1 on that Gezer!
It's on the crossbar between the 2 gauges. Haven't taken a photo yet but if you need one, I'll oblige.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 02-09-2009, 08:51 PM   #73
jackd
Oddometer: 3,032
Bluhduh I Was Hoping....
I was hoping that he would post a recent pic of his bars - I'm looking for ideas. I just scored a stock BMW clock for my GS but it won't fit on mine because I put bar risers on last season and now the stock hardware doesn't work. Darn.
Old 02-09-2009, 09:04 PM   #74
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
Will take a photo later...
My GPS mount is a TT so it mounts on the crossbar. It was much more difficult to find a spot for a Ram mount.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 02-09-2009, 09:24 PM   #75
Infracaninophile OP
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,513
Wow
Didn't expect so much input on the oil filter issue. I'll search around the airheads forum as well.
Will take it apart if I need to. I have not put the oil back in the engine yet due to my bad ankle. It's a 5 minute job to pull the cover off and measure the depth.
Wow. This is one area where the oilheads rock. A simple screw in canister that takes 2 minutes to do.
T.
Infracaninophile is offline   Reply With Quote
Times are GMT -7.   It's 01:29 AM.
