Old 09-07-2010, 06:29 PM   #16
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
This does not sound good. I would take the bike in for warranty service. Even if the dealer does not find anything, a record will be created that you have reported a problem.
I would do this before doing any diagnosis on your own because because this could be something bad.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 09-07-2010, 07:38 PM   #17
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
I spoke to George over at Beemers Uber Alles this evening. He suggested it may simply be a problem with the rad cap. Reasoning that the coolant gets hot, expands into the catch tank, and is possibly getting caught (no pun) there unable to get drawn back in to the system when cool. The cap looks OK and I have it soaking for now. I'll try putting everything back together tomorrow PM, bleed the air out of the system, and test it close to home. George's also thinks there is the possibility of a bad water pump. I sure hope not. Not looking forward to having the bike down for so long.
"An expert is someone who has made every mistake possible within a very narrow field of inquiry"
-Niels Bohr
lmclamore is offline   Reply With Quote
Old 09-11-2010, 10:03 AM   #18
JRWooden
Oddometer: 4,249
Originally Posted by JoelWisman
P.S.
The factory method does not always work for getting the air out of the cooling system and the bike does not self bleed at all.....
Joel:
One of the other inmates pointed out that there is a T30 sized cap screw that "vents" the cooling jacket. It is located on the front of the cylinder housing about two inches above the starter on the left-hand cylinder. I don't think the manual mentions this screw, but ... I'm not sure why else it would be there besides helping drain/flush/fill the cooling system?
Any thoughts?
Old 09-11-2010, 10:16 AM   #19
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
I am waiting to find out if my bike will be ready today. Morton's BMW (Fredericksburg VA) also assessed my problem as a bad radiator cap. The hour in traffic to get home will be a good test.
-Niels Bohr
Old 09-13-2010, 11:20 AM   #20
supershaft
because I can
Oddometer: 9,116
Anything is possible but joel hit it mostly on the head in that they can be a mofo to bleed. The bottom line is to watch it after you change coolant! Do not go by what is in the expansion tank!
Old 09-13-2010, 04:26 PM   #21
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
My dealer also went the "bad radiator cap" route, replaced it, topped her off and 150 miles later...everything is working as it should.
-Niels Bohr
Old 09-13-2010, 07:24 PM   #22
ThinAir
Oddometer: 67
Hack Method of refilling
Right or wrong, after I replaced my wife's 650 twin's radiator I too ran into the red triangle and found the fluid level low from not properly bleeding the system. I simply let the bike idle with the radiator cap off, while watching to make sure the bike was not overheating, and just filled the radiator a little at a time until it maintained a level near the neck of the fill area. Yes it burped out some fluid from time to time and got some drips here and there, but once I did that then filled the reservoir after placing the cap back on the radiator, it has been fine since. Simple, effective, and probably way wrong!!
ThinAir is offline   Reply With Quote
Old 01-24-2013, 09:30 AM   #23
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,766
Any follow up on this method?... How did it end up?
Anyone got more stories of bleeding the coolant system?
EnderTheX is offline   Reply With Quote
Old 05-26-2014, 04:53 PM   #24
RidingAgin
RidingAgin's Avatar
Oddometer: 402
Originally Posted by JoelWisman View Post
P.S.
After 2 service bulletins describing different methods of bleeding, BMW finally said "too hell with it" and made a special tool to do the job that costs a tunn.
We now have that special tool, but before we got it, I came up with a method that has always worked for me.
1: Slowly fill the system from the radiator till it is full to the tippy top.
2: Open bleed screw pictured in posts above till air stops coming out, then retighten.
3: Fill radiator back to the tippy top and replace radiator cap.
4: Start bike and idle for a few minutes, open bleed screw for a few seconds and retighten.
5: Rev engine to 4,000 rpm or so and rock bike slowly from side to side with rpms high, then hold straight or center stand and open bleed screw for a few more seconds (coolant will be HOT, don't remove your dermis).
6: Shut off bike and allow to cool down (at least 30 minutes, carefully open radiator cap and fill to tippy top, replace radiator cap.
7: Start bike and allow to idle till cooling fan comes on.
GOOD: If it took a long time for the fan to come on, the whole radiator is too hot to continuesly touch from behind, and the fan is blowing off a lot of heat, go ride, everything is working!
BAD: If the cooling fan comes on pretty quick, the back of the radiator is not to hot to continuesly touch everywhere, and the fan is not blowing off a lot of hot air but rather just warm air from the hot motor and exaust surfaces, you failed, repeat steps above.
Once the system acts normally, fill the catch tank to the maximum line while the bike is hot and cooling fan is cycling on and off. Go for a few rides allowing the bike to cool completely between and check that coolant in the catch tank has remained above the minimum line.
Congradulations, you've just bled the air out of a cooling system that is sometimes a bitch to do so :)
I followed this procedure, and it worked well on my 11 F650GS twin. For draining, i pulled the lower hose at the radiator and opened the vent screw. I did tip the bike to the right to get some additional fluid out (and shook it a little). When filling the radiator, have the bike on the side stand to lean it over to get more fluid in.
Just finished a 15 mile test ride test ride after buttoning up the bike, operated fine. Thanks for the write up.
08 R1200GS, 11 F650GS twin
RidingAgin is offline   Reply With Quote
Old 06-01-2014, 10:25 AM   #25
JRWooden
Oddometer: 4,249
For draining the coolant the manual suggests removing the lower coolant tube from the oil cooler and letting the coolant drain from there ...
tube is held in by one torx ... and sealed by an o-ring.
Be careful not to loose the o-ring when you pull out the tube
Times are GMT -7.   It's 10:13 PM.
