Old 02-09-2009, 02:46 AM   #1
galbo950 OP
galbo950's Avatar
Oddometer: 588
17/19 wheel combo - what width rim?
Getting a spare set of wheels for the more road orientated trips. Curious as to what size width rim I should run on the 19 inch front and 17 inch rear? Its for a 950SE.
galbo950 is online now   Reply With Quote
Old 02-09-2009, 07:05 PM   #2
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,093
2.5" X 19 front & 4.25" X 17 rear is standard
I went to a 5" rear wheel and 160 size tire for my 950A because I like the way my 625SMC handled with stock 5.0" X 17 rim & 160 rear tire. A 5" will allow 160 or 170 size tires.
"In the end, it's not going to matter how many breaths you took, but how many moments took your breath away"
mcmann is online now   Reply With Quote
Old 02-10-2009, 10:42 AM   #3
Gedjack
Oddometer: 94
So did i, the handling is great. I have the 160 tyre on mine.
Gedjack is offline   Reply With Quote
Old 02-11-2009, 07:04 AM   #4
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,623
Here is more info on the 19/17 set-up and the more standard widths:
http://www.advrider.com/forums/showt...hlight=19%2F17
Old 02-12-2009, 04:05 AM   #5
wee tee cee
Oddometer: 170
with the bigger rim and tyre,does the back wheel slot back in or is it tight at the caliper.my 625smc was a bugger to e-install.
wee tee cee is offline   Reply With Quote
Old 02-12-2009, 08:13 AM   #6
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,658
Cool2 it's only muny...
I am way curious about the 17/19 deal, both for handling and for height issues. Read the other posts already.
I think I'd go with a set of Conti Trial Attacks.
I do wonder about how well the bike would handle in the dirt, though I mostly do mild dualsport stuff, fire roads, some desert stuff, slow technical forest trails and roads.
I'm just smitten how well the 950 ADV handles with the stock wheels compared to my R12GS when I think about it bike to bike.
That said, I don't want to sacrifice alot of off-road capability.
Decisions Decisions...
I got the scoop from Zach at Woody's:
I'll break it down for you-
Front rad hub-299 Stock hub-270(pretty much any color)
Rear rad hub-299 Stock hub-260
Front 19x2.5 Silver- 195 black is 220
Rear 4.25x17 silver-229 black is 249
SS spokes and nipples 128 ea wheel
Superlace and true- 99 ea. wheel
Sprocket carrier wrubber dampeners- Rad-199 stock is 180
Full wheel set high end is -1725 for the set with sprocket carrier low end is 1380 without sprocket carrier!
Thanks, Zach
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 02-12-2009, 11:39 AM   #7
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,623
Depending on how aggressive you are in the dirt you will be giving up quite a bit of dirt performance and offroad tire selection.
I have two sets of wheels and use my 19/17 strictly as a Street set-up. I consider it my SM set up. I really like the Conti Trail Attacks on the road. They handle well and stick very well.
However, I do not consider any tire in the 19/17 range, besides a TKC 80, a dirt tire.
What I did was score a used set of wheels off the flea market and made those my dirt wheels, then took my old beat up wheels and had Woody convert them to the 19/17 set up. Saved a bit of money that way.
My 2 cents!
Dirt set-up:
Street Set-up:
Old 02-12-2009, 12:02 PM   #8
ABYSS
KTM
Oddometer: 1,198
you
will love going to a 17x19 combo. Also FYI you can get a 950 SM center stand and install it and not have any issues getting it in the air.
I got mine form Woodys..
http://www.smugmug.com/gallery/58838...65657895_MUyXL
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 02-12-2009, 12:09 PM   #9
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,658
Thumb
[/URL]
how much delivered?
good tip on the stand
Old 02-12-2009, 12:34 PM   #10
ABYSS
KTM
Oddometer: 1,198
I went full bore
and got the billet hubs and oversize spokes it was around 1700 OTD with shipping. The best thing I ever did. I saving up to send my original hubs in and have them laced as well it will be a good bit cheaper but then I will go with the TKC 17x19 for dirt as well.
Maybe = NO
Old 02-12-2009, 01:27 PM   #11
galbo950 OP
galbo950's Avatar
Oddometer: 588
Wheels ordered
Well the decision was made and i ordered the follwoing:
Front: 19 x 2.5 RAD Hubs with Excel Rim.
Rear: 17 x 4.25 RAD Cush Drive Hub with Carrier and Excel Rim.
The set up is costing me $2039 AUD. Would've been cheaper if I went for SM Pro rims but after doing a bit of research apparently the Excel are a stronger rim. Should have them within 4 - 6 weeks.
Old 02-12-2009, 04:14 PM   #12
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,623
Nice!
It's expensive, but I think you will be pleased. I can swap between the two sets of tire in about 20 min taking it easy.
Old 02-12-2009, 04:26 PM   #13
vf-17
vf-17's Avatar
Oddometer: 184
$$$$$ well spent.
05.5'KTM 950ADV. Orange with Akras. & 19/17 Black capo's from Woody's... ZUMO 550
05'KTM 450EXC.(plated)
00'KTM 400EXC.(plated)
97'KTM 360
96"XR 400
BIG orange KTM motorcycles and BIG orange Tennessee football....GO VOLS!
vf-17 is offline   Reply With Quote
Old 02-12-2009, 07:18 PM   #14
ABYSS
KTM
Oddometer: 1,198
do yourself a favor
Get a second set of brake rotors and a second rear sproket that way when you swap out you wont have to spend any time transfering them.
Maybe = NO
Old 02-12-2009, 10:34 PM   #15
galbo950 OP
galbo950's Avatar
Oddometer: 588
Swapping Rotors
That was the plan, just priced KTM genuine disc in Oz, not cheap and I cant seem to find anything after market here. The sprocket is easy to source though. Was planning on dropping the rear sprocket to a 42T.
Times are GMT -7.   It's 05:04 AM.
