Old 02-09-2009, 03:05 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,703
320mm Brake upgrade for G/S
OK after hashing out whether to ad another disc, or some other method of upgrading brake I decided to go w/ a 320mm brake upgrade. I think stock is 260mm. As Of now I cannot comment on the improvements as you can see I have no front tire.
This uses the stock caliper and just relocates the calipers outbound a bit, comes with a spacer for the rotor and needed bolt to mount the caliper and disc. I got this from Seinbenrock. It is suggested to get another brake line but the old one will work.
One thing I don't like and has nothing to do w/ function is that the bracket which mounts to the fork needs to have the mounting bolts recessed into the bracket. I may have this done later.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-09-2009 at 03:12 PM
Old 02-09-2009, 06:53 PM   #2
johno
johno's Avatar
Oddometer: 2,911
Thats a strange looking disc
Looks like a floater, but its not.
Should definately work better though.
Down in the land of the confused(mainly me)
johno is offline   Reply With Quote
Old 02-10-2009, 04:10 PM   #3
One Less Harley OP
Oddometer: 4,703
It's a solid disc which have been laser cut at a few locations to take care of heat expansion and probably help keep it from warping.
I had the aluminum countersunk for the mounting bolts. A much neater look.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-10-2009 at 04:19 PM
Old 02-10-2009, 07:14 PM   #4
woodgrain
In-Dented Savant
woodgrain's Avatar
Oddometer: 809
How much for the Siebenrock kit?
Woodgrain
woodgrain is offline   Reply With Quote
Old 02-11-2009, 05:39 AM   #5
One Less Harley OP
Oddometer: 4,703
USD Cost- $311.98 plus $41.40 shipping from Germany.
Probably cheaper to get someone to make another bracket for a four pot caliper, but might have to change brake lines and possibly the MC. The stock brakes aren't that bad w/ standard tank and unloaded...not great but adequate.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-11-2009, 09:24 AM   #6
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Or, for a lot less, you can use a 2000 or so K1200R (re-badged Brembo) 4-pot caliper (34/32mm) on a stock disc with great stopping power:
Use a left caliper with bracket for the G/S location behind the fork leg.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 02-11-2009, 10:09 AM   #7
England-Kev
Oddometer: 3,602
Are there any options for four potting an ST front end?
England-Kev is offline   Reply With Quote
Old 02-12-2009, 03:29 AM   #8
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,185
The ST use the same calipier so the 4 pots conversion would work
Caddy82rats is offline   Reply With Quote
Old 02-12-2009, 03:37 AM   #9
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,477
Anybody have a link to more info on this mod? e.g. does stock bracket work? Shims...? Does master cyl need to be re-thought? etc...
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 02-12-2009, 04:34 AM   #10
StephenB
StephenB's Avatar
Oddometer: 2,044
On a stock GS you only have to shave a bit (4mm) off the mounting brackets of the caliper, otherwise it is plug 'n play. I made no changes to the m/c. I think mine is stock GS 12mm.
Dunno about doing the mod on a G/S but I assume you need a custom bracket.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 02-12-2009, 03:26 PM   #11
One Less Harley OP
Oddometer: 4,703
Took the bike out for a test ride w/ the 320mm rotor, don't know what pads are on the stock caliper, but getting the front wheel to chatter and lock up is not a problem now. First ride and I like it so far. Nice upgrade w/ no fuss on installation.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-12-2009, 03:28 PM   #12
One Less Harley OP
Oddometer: 4,703
For stephnb's conversion notice it's for a GS no a G/S, but the principles of the conversion are the same.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-13-2009, 11:29 AM   #13
jellycow
Back on track!
jellycow's Avatar
Oddometer: 909
I've had the same HE disk on my former r100gs. Combined it with a 4 pot calliper. The shear stoppingpower (well, for 2v-alikes ) Used the left side calliper from a r100r and just had to take about 5,5mm off the spacer. Easy fix, good result.
Now, by the time the disk on my G/S is worn and the 2 reserves after that I'll have saved enough money to buy the HE for G/S and so it'll be done.
BTW: it is just about floating, the lasercuts are in such locations that there is some room for the disk to move, just as on a really floating disk.
R100GS rescue: only the brave put it on hold for now
Workshop credo: if it ain't broke, fix it till it is.
jellycow is offline   Reply With Quote
Old 02-13-2009, 06:15 PM   #14
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,900
Nope, the BMW 4-piston caliper does not work on a G/S nor ST.... I can tell you that for sure.
Boxerworks sells a machined adapter to do this mod, but the caliper ends up almost below the wheel and looks to be in a bad place for off-road riding.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 02-13-2009, 07:10 PM   #15
One Less Harley OP
Oddometer: 4,703
Solo, that conversion looks hoaky as hell....hope it's not your bike. Yeah I knew the four pot wasn't plug and play even with shaving the caliper as the spacing for the mounts are different.
I really am enjoying the 320 disc, it's been fun today hearing the front tire squeal and locking it up. Never could do on the R1150RS. If I could only get the wobble taken care of, still fighting with that, along with a wheel hop, dyan beads didn't fix that. I'll try and get the wheel spin ballanced tomorrow. Gotta fix the wheel hop and wobble. But Not ready for buying a rear shock, cann't affoard it right now.
I've got some calipers coming from an early RT (117mm spacing for the mounting bolts, like the G/S) and will still look closer at the spacing, but I'm thinking even w/ the shallow rotors some spacers will need to be made, then have to make sure the calipers don't hit the spokes. Carrier spacers wouldn't be any big deal to make.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 09:03 PM.
