Go Back   ADVrider > Riding > Regional Forums > Canada
Old 06-02-2012, 06:21 PM   #2236
Pine Sol
Pine Sol's Avatar
Oddometer: 499
just got her fairing on, and just about a thousand little things to do....
Pine Sol is offline   Reply With Quote
Old 06-02-2012, 06:32 PM   #2237
Calgary06
Calgary06's Avatar
Oddometer: 165
Mountain Aire lodge has fuel although their website says "Note:*Due to recent events, the self-serve station has limited Gas and Diesel for sale." so you might want to call them directly. My odometer shows 302km measured from the shell in Cochrane to the top of the mountain and back to Calgary (tuscany).
Have a good ride tomorrow. Watch for ruts (and the divot my head made) in the dirt just below the rocky top bit.
Pinesol - that fairing looks great. Can't wait to see the finished bike.
EEUC
2010 F800GS
Calgary06 is offline   Reply With Quote
Old 06-02-2012, 07:44 PM   #2238
Beema Killa
Beema Killa
Beema Killa's Avatar
Oddometer: 816
That looks rad man. Can't wait to see it done. Gonna compliment the crazy sky high travel nicely.
Beema Killa is offline   Reply With Quote
Old 06-02-2012, 10:44 PM   #2239
Pine Sol
Pine Sol's Avatar
Oddometer: 499
thank you....
finished 99% of everything (F800GS low fender and 690 fairing), spent over 3hrs trying to bleed the front caliper/ ABS and still have no brakes, the rear were pretty straight forward.
guess im not going out for a drive on sunday...
Old 06-03-2012, 07:00 AM   #2240
Durden
Freak!
Durden's Avatar
Oddometer: 477
^^^ Bike is looking sweet Pinesol, cant wait to see the finished product.
As for the forrestry trunk, you can almost always get gas at Mountain Aire Lodge (their website always has that warning), then you can get gas again in Bearberry or Caroline if you need before pushing up to Limestone.
I love that ride, sorry I cant join you guys.
Durden is offline   Reply With Quote
Old 06-03-2012, 10:10 AM   #2241
Shibby!
Oddometer: 1,666
thank you....
Where is the bleed nipple?
Sometimes manufactures put on generic parts which causes them to be on the bottom. Which means standard bleeding will never get the air out. Take off caliper and adjust accordingly if needed.
Have you tried a vacuum bleeder? Syringe for bottom up bleeding?, etc.
I've never done a bike with ABS before though... and personally hope I never =)
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 06-03-2012, 11:06 AM   #2242
1Rider
1Rider's Avatar
Oddometer: 96
Exc 500, 530 and or Husaberg 570 owners- help please!
So, I've had my 950 SE up on kijiji for trade for one of these bikes because I want to go to a smaller Dualsport - I think...
Problem is I have never ridden any of these. I know I will like them better off road, but what about on road?
I love blasting around on the SE, anyone with a 500, 530 or 570 willing to swap for a little on road test?
I'm afraid I will regret selling or trading the SE...
Cheers!
Bob
2009 KTM 950 SE Erzburg- turned into a Jeep!
1Rider is offline   Reply With Quote
Old 06-03-2012, 12:29 PM   #2243
Pine Sol
Pine Sol's Avatar
Oddometer: 499
950SE
i bought my xchallenge as a travel adventure bike... but my heart wanted either a 950SE or a HP2e
Old 06-03-2012, 12:49 PM   #2244
Beema Killa
Beema Killa
Oddometer: 816
I love my 990 adventure. It's a beast on and off pavement.
Pine Sol , the vacuum technique works best for brake bleed. Push from bottom with a syringe and catch the overflow up top. Gets all the air out no problem. No need to pump lever that way and air moves up the way it wants to.
Go to any medical supply place for some tubing in the size you need and a syringe. GOOD LUCK!!
Old 06-03-2012, 03:28 PM   #2245
Pine Sol
Pine Sol's Avatar
Oddometer: 499
i dropped by a horse shop and got a 60ml syringe... made a good mess in the garage, pushed 60ml up the system (glad the bike is mainly plastic, not a fancy paint job).
still no pressure,
i also tried using vacuuming without any success.
when i pull and release the front lever, i can hear a swishing sound coming from this little box (or at least i think its coming from here)
followed those two metal tubes back to the solenoid, but unable to feel any bleed screws on it
i keep checking through google, there has to be a trick that i missing or cant see
Old 06-03-2012, 03:40 PM   #2246
Beema Killa
Beema Killa
Oddometer: 816
Does that bike have dual discs? Is this where they split from? Air must be trapped in there?
Old 06-03-2012, 09:05 PM   #2247
Pine Sol
Pine Sol's Avatar
Oddometer: 499
single disc up front.
the more research i have done, the more it looks like:
either go to the dealer and have them use their dealer thingy to cycle through the ABS solenoid, as per needed to bleed the brakes,
or
disconnect the front ABS and revert back to single hose from master to caliper....
guess i will be looking for a local cable shop for a custom hose....
as the bike is being built for travel, if having ABS complicates the system so much that i cant bleed them at home, then conventional single hose is what i will swap to, its a shame really...
Old 06-03-2012, 10:15 PM   #2248
Shibby!
Oddometer: 1,666
or
Thing is brakes should never need bleeding unless being serviced. How much did the stealership quote to bleed them? I'd look for home remedies so maybe you can keep the feature AND do it in the field if required.
Try googling: site:advrider.com x-challenge bleed
Or check X-challenge specific forums. There has to be an easy fix.
Old 06-04-2012, 08:07 AM   #2249
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,822
Why don't you call Anderwerkes and ask them. If nothing else, they could do the bleed for you and they love custom builds.
Alternately, you could buy a GS911 - it has a cycle ABS function. You probably need one for a RTW trip anyway.
Sent from my SGH-T959P using Tapatalk 2
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 06-04-2012, 01:02 PM   #2250
Pine Sol
Pine Sol's Avatar
Oddometer: 499
cheers, will do, they are closed on monday
Times are GMT -7.   It's 02:27 AM.
