02-07-2013, 08:47 PM
#3031 |
Oddometer: 113
Here is a photo of us last weekend in Mclean.
Me on the GS, Kevin2Wheels on the Versys and two friends. Staying in the quad trails was OK...until you got off track. The center bead on the K60 rear does not like snow. On the other hand I am not that good.... I'm a skier so I say bring on the snow - but getting back out on the bike sure was good.
EEUC |
02-08-2013, 10:47 AM
#3032 | |
Silly Adventurer
Oddometer: 2,753
I still have the 98 KTM, although now it is a 2003 Adventure. I bought a different frame for it without the RUM designation, bolted all the '98 components to it, replaced the blown motor with a '95 620 RXC motor, and Bob's you uncle 100% street legal. The bizarre thing is that all of the "dirt" components like brakes, wheels etc have the same part numbers as the competition vehicles.
Rum Runners Yukon, NWT & Alaska Roads and Ruins Scotland Kinbasket Lake Golden B.C. A "Day" of Dirt Biking Rockies East Slopes High and Dry Colorado and Utah "When your only tool is a hammer, every problem looks like a nail" |
02-08-2013, 03:27 PM
#3033 | |
Oddometer: 64
02-08-2013, 07:29 PM
#3034 |
Beema Killa
Oddometer: 377
200km loop today. Stopped out at the gate for Powderface. What a beautiful day. Hey Red Cat! We gotta get out sometime!
02-09-2013, 07:20 AM
#3035 |
Bumpy Backroader
Oddometer: 2,413
Yo! Beema Killa
Hey I was out yesterday also! 350kms mostly bumpy paved roads and some gravel. Was thinking of contacting you, but you being a young fella, figured you'd be working. Too bad. None of my regulars could make it. Probably the best day we're going to have for a while. Maybe next week.
02-09-2013, 09:37 AM
#3036 |
Beema Killa
Oddometer: 377
Yeah it was a great day. I only work Monday to Thursday, so after errands it's usually saddle time on Fridays.
02-09-2013, 03:06 PM
#3037 |
Oddometer: 182
today looked good for a ride until the short blizzard
Got the bike put together and it looked beautiful (the weather and the bike haha). Got cleaned up and it was blizzarding.
02-09-2013, 05:08 PM
#3038 | |
Grizzly herder
Oddometer: 1,036
Wrenchin' Day
I fixed that, which took very little time, but really? Pay attention guys. I also noticed they didn't reconnect the drain hose at the bottom of the air box, grrrr!Hopefully that was all they forgot....... ![]() ![]() These were taken before re-installing my crash bars, and moving the lines back. Under compression the lines get too close to the ends of the crash bars and could snag. Two years with the lines on the inside and zero issues. ![]() The way it was ![]() Line guides I also took off my fuel pump and changed the 2 filters, and they really were ready. Bits of the "sock" filter were accumulating at the bottom of the pump housing. If you have a year on your 990 DO THIS. I'll even come over and help if you like.Here are the old ones. ![]() I enjoyed working on the bike, and it is ready to roll now, come on spring!!
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv Lycan1 screwed with this post 02-11-2013 at 12:57 PM |
02-09-2013, 07:53 PM
#3039 |
Bumpy Backroader
Oddometer: 2,413
And!
We actually pay them to do it. Sort of like using you own Vaseline.
02-09-2013, 08:57 PM
#3040 | |
Grizzly herder
Oddometer: 1,036
I need a bearing puller to do my rear wheel, anyone know where I can buy the proper tool locally as I don't want to buy on-line.
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv |
02-10-2013, 07:32 AM
#3041 |
Bumpy Backroader
Oddometer: 2,413
Usually!
Don't need a bearing puller to replace a rear wheel bearing. Pop off the seals, maybe a circlip, so be careful.Apply WD40 and let sit for awhile. Then from the opposite side, slide a long punch through the axel hole and get it on the edge of the bearing and tap with a hammer moving the punch all around the edges of the bearing. Should eventually start sliding out. Clean up with WD40 or lube with oil and tap the new bearings in. Put the new bearings in the freezer for a while. Helps them slide in easier cause they contract a little. Use a socket to tap the new bearings in. Make sure you tap just on the outer edges of the bearing. Just take your time. If the punch doesn't work try a screw driver. Anyhow, this is how I've always did it.
02-10-2013, 07:51 AM
#3042 | |
Grizzly herder
Oddometer: 1,036
02-10-2013, 10:13 AM
#3043 | |
Silly Adventurer
Oddometer: 2,753
I do know a good mechanic should you need one.
02-10-2013, 12:58 PM
#3044 |
Eat Gunnels!
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,092
You can get a blind bearing puller at Princess Auto but I have always used a punch, too.
I also find that applying a heat gun to the hub helps on removal and install, too. Send from my Droid using Tapatalk
____________________________________________ 2005 GS1150 Adventure - Range Rover, 2002 DR650 SE - Land Rover "Not all who wander are lost" - JRR Tolkien |
02-11-2013, 07:16 PM
#3045 |
Oddometer: 159
I picked a good dealer to buy my bikes from, and I see a trusted family run buisness to do my service work. Family run shops take pride in thier work bing that this is what they live on. I don't trust big dealerships to work on my stuff, so the small dudes fill my needs.
From Jeathrow Bowdean in Western Canada |
