Old 06-11-2014, 08:50 AM   #676
Chest Rockwell
Oddometer: 4
Broke mine in over the weekend - great space savings for on the bike camping gear. Easy win.
Chest Rockwell is offline   Reply With Quote
Old 07-18-2014, 12:33 PM   #677
smithe
Oddometer: 403
Anyone made bread of any sort with theirs? I was going to do a test of some bannock tonight after work while I am cooking up some burgers on the grill in the back yard. Trying to decide if I should use the regular stove or the simmering one.
*Edit - I made some this evening with the regular stove and a little 7" pan I have. Just flour, baking powder, salt and water. It cooked FAST, talking under 5 minutes! If I hadn't been watching it I would have burned it badly, as it is it got a few dark spots on both sides. I made it a little too thick and the middle wasn't 100% done but it was hot all the way through and I actually liked the consistency of the middle with the slight crispiness of the outside.
When I go to do it again tomorrow, I will just occasionally lift the pan up and am also going to try it on the simmer stove. My very picky sons both ate it up very quickly which is a good sign.
'12 Tiger Explorer
'93 KLR650
smithe screwed with this post 07-18-2014 at 07:10 PM
smithe is offline   Reply With Quote
Old 09-08-2014, 07:45 AM   #678
photomike
Top-notch MoFo
photomike's Avatar
Oddometer: 53
Originally Posted by Oatmeal Bonewell View Post
So I clicked 'Send Money' on paypal and the box hit me in the back of the head. That was FAST. Thanks, Shady. I can't wait to try them out.
that's funny!
photomike is offline   Reply With Quote
Old 09-08-2014, 09:46 AM   #679
circusinthesky
SemperFidelisTyrannosaur
circusinthesky's Avatar
Oddometer: 359
How do you add more fuel when the stove is still lit? Can you simply pour more from the Heet bottle? That sounds like a bad idea. (Pouring on more fuel, not the stove.)
circusinthesky is offline   Reply With Quote
Old 09-08-2014, 09:50 AM   #680
ShadyRascal OP
Master of None
ShadyRascal's Avatar
Oddometer: 6,755
That is a bad idea. I have played with squeezie bottles with the flip up lid that will squirt a fine stream. Even that gets messy with burning alcohol getting all over. Best to just let it burn out, add more, then relight---the stove will be warm and will begin generating quickly.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is online now   Reply With Quote
Old 09-08-2014, 09:54 AM   #681
circusinthesky
Oddometer: 359
Okay, thanks. I also notice that it is hard to see the flame at times in this sort of stove. People should make sure its definitely out before adding more.
circusinthesky screwed with this post 09-08-2014 at 10:10 AM
Old 09-08-2014, 09:56 AM   #682
ShadyRascal OP
Master of None
Oddometer: 6,755
If you lift the pot off the stove, at the end you'll see the alcohol boiling in the bottom.
Old 09-08-2014, 12:51 PM   #683
circusinthesky
Oddometer: 359
Okay, I read about 20 pages, but I didn't see a follow up to someone's question about a metal ring to block some of the holes. It sounds like a great idea....some sort of band which can be rotated to block 1/3, or 1/2 of the holes, in order to lower the temp. Was there any more on this topic?
Old 09-08-2014, 12:55 PM   #684
ShadyRascal OP
Master of None
Oddometer: 6,755
Some guys I think have made their own, it's not something I plan on. The aluminum bottles I use to make these stoves have changed; I have a couple cases left and that might be the end of it---I'm not sure a this point.
Old 09-08-2014, 01:09 PM   #685
hugemoth
hugemoth's Avatar
Oddometer: 3,032
Consider using aluminum water bottles. They work just as well and are heavier gauge material. I pick them up for $1 a piece at the Quartzsite flea market. They are rejects from the company that prints company logos on them.
Old 09-08-2014, 02:36 PM   #686
phreakingeek
phreakingeek's Avatar
Oddometer: 552
just sent a paypal for one of each stove.
thanks,
jeff
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
-Hunter S. Thompson
phreakingeek is offline   Reply With Quote
Old 10-19-2014, 10:56 PM   #687
Raven457
Oddometer: 27
Order sent.... will be using to supplement my Trangia kit so I can cook two things at once.
Raven457 is offline   Reply With Quote
Old 10-20-2014, 05:06 AM   #688
phreakingeek
Oddometer: 552
i've used both the regular stove and the 'simmer' stove on several trips since I bought them. They work great and are so compact I was able to reduce the size of my pack quite a bit.
I opted to use a folding stove with it and a folding wind blocker to end up with the ultimate in compact cooking. I decided to get the slightly heavier steel folding stove instead of the sterno aluminum stove. Just seemed a little more sturdy. Just a word of caution though, this alcohol stove gets hot enough to burn off the paint in some areas...just be prepared to wipe it down before you pack or you'll have black stains on everything.
folding stove:
folding surround
-Hunter S. Thompson
Old 10-25-2014, 05:11 PM   #689
Raven457
Oddometer: 27
thanks for the fast delivery, Steve!
Old 11-02-2014, 08:39 PM   #690
hrdrckclmr
this is gona hurt
hrdrckclmr's Avatar
Oddometer: 92
Just ordered one of each been putting this off for far to long.
hrdrckclmr is offline   Reply With Quote
Times are GMT -7.   It's 08:02 AM.
