Old 02-14-2009, 09:25 AM   #1
2uprtw OP
Oddometer: 645
Spare relays for long trip
I am in the process of re-stocking our spares and was wondering which relays on an 1100gs can fail and cause a trip to come to a halt?
Brian
www.2uprtw.com
2uprtw is online now   Reply With Quote
Old 02-14-2009, 09:31 AM   #2
space
a.k.a. Jake
space's Avatar
Oddometer: 2,613
Assuming it's the same as the 1150, all the relays are of the same type except for the ABS relay.
I suggest bringing a spare of the common kind and not worrying about the ABS relay since it's not critical.
space is offline   Reply With Quote
Old 02-14-2009, 09:47 AM   #3
GSbiker
new and un-improved
GSbiker's Avatar
Oddometer: 11,750
Has anybody had a relay fail? I don't think I have ever heard of that happening.
TRLcam
GSbiker is online now   Reply With Quote
Old 02-14-2009, 10:26 AM   #4
dlew
Daypass Adventurer
dlew's Avatar
Oddometer: 2,142
i've had two fail. they were triggering hid driving lights and they had water damage after either riding in rain or bike sitting in rain. it probably wasn't from washing because it's only washed once or twice a year and i don't soak it like it would be soaked from rain.
the relay was under the seat and i re-oriented it so it's facing down and i haven't had a problem again but i'm sure moisture could do it.
2005 R1200GS
1993 R100GS PD
1986 R80 G/S PD
dlew is offline   Reply With Quote
Old 02-14-2009, 10:55 AM   #5
2uprtw OP
Oddometer: 645
I read somewhere (but cannot remember where) that the starter relay can fail and that there is a relay for the fuel pump which may cause problems. But when I checked on realoem I only found a part number for the starter relay and there seems to be nothing specific for a fuel pump relay.
Brian
www.2uprtw.com
Old 02-14-2009, 01:03 PM   #6
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,866
The load relief relay eventually becomes erratic on high mileage machines. I did an autopsy on my failed one and found the main contact eroded away (which i what I would expect for that application). It operates everytime the starter is called to run and carries a fair amount of current. Carry a spare and you will never have a problem - remember Murphy's law?
Old enough to know better....
Young enough to try it again
GS Addict is online now   Reply With Quote
Old 02-15-2009, 06:06 AM   #7
2uprtw OP
Oddometer: 645
Alright guys, thanks for the responses. I'll probably pick up a couple of spare relays just in case.
Brian
www.2uprtw.com
Old 02-15-2009, 08:40 AM   #8
Maineiac
Kennebago Express
Maineiac's Avatar
Oddometer: 53
Just had relay fail on my '04 GSA w/26K - happened after N.S. trip.... rain, rain, rain. FWIW, local dealer said it's not uncommon.
Maineiac is offline   Reply With Quote
Old 02-15-2009, 10:41 PM   #9
DrWatson
DrWatson's Avatar
Oddometer: 463
nothing failed yet after 322,000km. A long time ago had the drivelight relay stick on for a bit, but removed it, gave it a couple of taps and was good to go again - happens when was running 330W on high beam.
Personally I wouldnt bother carrying a spare. If in the very unlikely event one failed, it may be due to some other problem causing it. Carry a compact digital multimeter (about the size of a packet of cigaretes). Relays can be got just about anywhere, and if not the correct fit, running some jumpers temporarilly will do the trick.
Nic.
DrWatson is offline   Reply With Quote
Old 02-16-2009, 06:21 AM   #10
space
a.k.a. Jake
space's Avatar
Oddometer: 2,613
This happened to mine at 60k. The most notable symptom was that the headlight would occasionally stay on after I'd switched off the bike.
Seeing that a relay weighs less than 10 g, you may as well bring one.
Old 02-16-2009, 09:12 AM   #11
bananaman
transcontimental
Oddometer: 7,515
Nic.
+1
I had a cheap radio shack relay on my fog lights. It worked fine for the entire ride to Ushuaia, and then back in Wisconsin a few weeks after I got back, we had torrential rains and it got waterlogged and quit. Otherwise, the jumper-cable trick would work for your starter.
You, Brian, are becoming a master BMW mechanic. I have complete confidence that if you had a failed relay, you'd either do a field repair that MacGyver would envy, or you'd find some other bike/vehicle to canabalize.
If I was you riding your bike by now I would probably not be sleeping at all, and for emergency, I'd probably have an entire spare bike in one of my side cases.
I am Charlie.
bananaman is online now   Reply With Quote
Old 02-16-2009, 09:16 AM   #12
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,866
Nic.
For a less than $20 you can buy the correct relay (about the size of an ice cube and easily packs in the fuse enclosure)
Are you saying you are willing to dick around in the dark with jumpers & connectors after having to find something that might work in some nowhere town where nothing is open on Sundays..........I don't get the logic
My riding time is worth more than that.
Old 02-16-2009, 02:52 PM   #13
vintagerider
vintagerider's Avatar
Oddometer: 1,966
It's not about the ride it's about adventure and local color
Gs Addict said "
Are you saying you are willing to dick around in the dark with jumpers & connectors after having to find something that might work in some nowhere town where nothing is open on Sundays..........I don't get the logic"
That's how you find adventure and local color.
vintagerider is offline   Reply With Quote
Old 02-16-2009, 03:53 PM   #14
Hotspice
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,533
Count me among the ones that have had relay's fail. Never a factory one though, just ones I've added.
I always used to carry one spare. Then one night out at O-dark-thirty my HID's went out on me in the middle of BFE . No biggie, I pull over, grab the flashlight and start troubleshooting. Sure enough it seems like the relay so I grab my spare and put it in.
Nada, zilch, zippo.. , some other part of my install must have failed and there's no way I'm fixing it where I'm at so I limp home with stock 1150GS lights.
The next day I ripped things apart and couldn't get the lights working. I test & try the original relay and nothing, ditto with the spare relay. Just for kicks I grab a THIRD relay and things fire up fine . Sure enough, my original one AND my backup were bad.
Now I carry TWO spare relays, just in case.
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 02-16-2009, 04:54 PM   #15
DrWatson
DrWatson's Avatar
Oddometer: 463
GS addict,
if you wish to carry spares, good for you. How many other spares will you carry? How do you determine what spares?
I carry all the basics that are likely to stop me, likely to fail, and can be done on the roadside - spare cables, plugs, alternator belt, fuel filter, clutch lever.
I have tyre repair and crash repair items.
Relays are very reliable these days - i dont bother carrying spares. You may even find that for example the ABS relay is the same as another, so you could pull the abs to get something else going! Even if you couldn't, a bit of jumper wire will bypass a relay to get the motor running if required, so long as the underlying cause of the failure is addressed first.
Carrying all the spares you like may not help, unless you know what your doing and have the tools to do so.
if it really goes bad, set up your tent, or join the locals for some fun... call your boss and say your stranded for a few days and let the adventure begin.
Nic.
Times are GMT -7.   It's 05:08 PM.
